Question about LG Televison & Video
Picture momentarily freezing
The picture occasionally freezes for a moment and looks slightly pixilated. ? Sounds a bit like norman collier as well.
    Top Expert:
  • LG Master
  • 74,831 Answers
Do a firmware update. Corrupted firmware can cause this type of problem. Electro help
Posted on Apr 22, 2014
4 Suggested Answers
SOURCE: Vertical Lines on Screen
I believe I have the problem component identified. It is U15 on the main board. The part is:
MTL015GF
0616A140V1
The manufacturer name is Myson Century. At this time I can not find a replacement. If anyone out there can suggest where to get this part I'd appreciate it.
Posted on Sep 01, 2008
JOHNSONELECT
  • 113 Answers
SOURCE: Picture on all 4 TV's in house randomly pixilate/freeze.
you have a low signal problem or if you have rj 59 in your home you need rg6 for at and t signal
Posted on Aug 27, 2009
AJIN G
  • 6694 Answers
SOURCE: I have a UltraVision LCD
hi,
You have to check the power supply of your tv first . If any one of the electrolytic capacitor in the power supply board is fauly then this problem can occur. One more reason is that, the back light inverter bord. It uses hight voltgae inverting transformers. If any one of the transformer's winding is short the it will make popping sound. If so there is no repair possible with this inverter board you have to replace this board with a new one. First of check the power supply is there is any budged electrolytic capacitor (pointed by the read arrows) like in the picture. If so replace the same will solve the problem. If not it is the inverter board. It will look like one in the picture.
OK
Posted on Sep 04, 2011
Occasionally some portion of the screen on my Polariod TDA-03211C TV/DVD combo will momentarily display a low-resolution (large pixels)freeze frame. This may happen 3 or 4 times in the space of 2 minutes,...
There cloud dust on the lens of the dvd player in your TV try to LENS cleaner which is available in any electronic stores and also check for any scratch on the disk this is main cause freeze frame..
Good luck.....
Jul 24, 2008 | Televison & Video
Korg pa800 256mb styles set
I wouldn't recommend doing that, because your OS system could freeze occasionally
Jan 29, 2014 | Korg PA800 61 key Arranger Keyboard Kit
Freeze picture
hi this fault could be either software or main board problem
regards
shaun
Jan 25, 2014 | Toshiba 32AV502R LCD TV
Hang problem
Computers, no matter the make or the model, have a tendency to freeze up. This typically occurs when you overload the RAM on the computer and the laptop can not process any more information. When your laptop freezes, you are not left with many options, so you'll you need to restart the system.
1.Press and hold "CTRL," "ALT" and "Delete" at the same time. Wait and see if a prompt window loads. If one does you can select the program causing the crash and close it. This allows you to return to using the laptop.
2.Push and hold the power button until the system turns off. Typically, you need to hold the power button down for a few moments before the laptop shuts down.
3.Remove the power cord from the laptop if the power button does not turn the computer off. Occasionally this can occur, in which case you need to find an alternative way of cutting the power.
4.Flip the laptop over if the power button is not turning the computer off. Find the battery compartment on the bottom of the laptop and remove it from the computer. Momentarily the computer shuts down. Leave the battery out for a few moments.
5.Insert the battery back into the computer and press the power button. Shortly, the computer restarts and begins to load the operating system.
I hope you find it very helpful.
Aug 26, 2011 | Computers & Internet
My digital tv keeps freezing it is an Alba TV and we live in bournemouth and it says we don't have coverage at the moment but we get all the chnnels its just every now aqnd again the picture jutters and...
Because you are receiving digital transmissions, if the signal is too weak your picture will break up and pixilate. In the days of analougue you would just get a snowy picture. If you are getting the channels, you might want to consider investing in a booster and a digital antenna. Install the booster as near to the antenna as possible to get the best out of it.
Jan 23, 2010 | Televison & Video
Aug 27, 2009 | Vizio L37 Television
Trouble with Tuner 2
From experience, I suspect that the dish has lost it's optimum "focus" on the satellites, and your signal has dropped. In your case, tuner #2 just happens to need a little more signal than tuner #1 - and that's revealing the root problem.
If you can have a second person handy, use the signal meter function and view the signal. Then one person should move the dish a bit (likely upward a hair). If the signal goes up with just the slight movement of the still tight dish, that's the problem.
If so, it's time to align the dish.
May 14, 2008 | Samsung SIRS4120R Receiver
Televison & Video Logo
Computer Repairing
Computer Repairing
