Question about Panasonic KXDT343 Phone
Light indicating an extension is in use not lit up
  • Panasonic Master
  • 2,460 Answers
The light is either not programmed, or the extension is disconnected.
In the first case, press PROG the button and dial 1 plus the extension number and ENTER. In the second case, the digital phone has to be in place and idle before the light will go out.
Posted on May 27, 2014
Troubleshooting the superset 4025
If *ALL* the buttons are lit up solid then try rebooting the phone (unplug the phone line & plug it back in). However, if only one or 2 lines are lit up solid then that is an indication that those are companion key appearances of other extensions that are presently set to "call Forward Always" mode. You will need to visit the physical home location(s) of those lines to un-forward them. Hope this helps.
Apr 18, 2014 | Mitel Superset 4025 Corded Phone...
Message indicator
The Message Waiting indicator light is typically a notification pushed from your PBX to your phone, as your voicemail does not actually reside on your phone, but rather centrally on your PBX system itself. If you are not always getting MW indications on your phone, it could be an issue with your PBX/Extension configuration. I would check with whomever set up your phone system and have them take a look at the configuration on the PBX for your particular extensions.
Cisco CP-PWR-CUBE
Dec 19, 2012 | Avaya 9508 Digital Deskphone - digital...
How do you recharge jump start system
put a battery charger for a car on the + and - leads and this will recharge it if you do not have the correct power pack recharge transformer
Jan 09, 2012 | Stanley Black & Decker Stanley J5c09 500...
I've misplaced my users manual for my Stanley J5C09 jump starter
Go to www.baccusglobal.com and link the Stanley link and then the "manuals" link and it should be there
Dec 27, 2010 | Stanley Black & Decker Stanley J5c09 500...
How many lights should be on my westell model327w?
The Westell has several lights on the front that have various meanings
Power = When lit, this light indicates there's power to the router. It should be solid green.
Ethernet = When lit, this light indicates that the modem is communicating with your computer. This will be on only if you're using the Ethernet cable to connect the modem to your computer
Wireless = When lit, this light indicates that the wireless function of the Actiontec is working. This will only be lit if you're using the wireless function.
DSL = When lit, this light indicates the modem is speaking to the central office (phone company). When working, the light should be solid green.
Internet = When blinking, this light indicates that you're receiving information i.e., you're able to browse from site to site. This light will be blinking as you're receiving information.
Sep 16, 2010 | Computers & Internet
Nedd the passkey to pair to my blackberry
Problem :
Passkey to pair
Solution
PUT THE HEADSET IN PAIRING MODE
The headset indicator light will be steadily lit in purple when in pairing mode. To place the headset in pairing mode:
If the headset has never been paired with another device, simply open the headset boom. The indicator light becomes steadily lit in purple.
If the headset has previously been paired with other devices, first ensure those devices are turned off.
Then open the headset boom and the indicator light flashes in blue. After about 5 seconds, the indicator light becomes steadily lit in purple.
DEFAULT PASSKEY is 0000 (four Zeros)
Rate my solution please
Aug 19, 2010 | Motorola Mobility H700 Wireless Headset
Toshiba phone model DK2010-SD; can't retieve messages
The reason it rings the other extension is because that extension lit the message light.to cancel press intercom # 409
Mar 27, 2009 | Lands Phones
Partner 18 light on extension stays on
Also make sure station DND (Do not disturb)is not on.
Feb 23, 2009 | Lucent PARTNER18 Corded Phone
My GE instajack is not working. It had a greeen signal, now it has a red signal.
Most likely, the extension unit cannot communicate with the
indicator light is solid base unit for one of the following reasons:
red • Base unit has yet to be installed. Install base unit. (Refer to
the Set Up section.)
• Extension is too far from the base unit. Relocate either the
base or extension unit to another electrical outlet. If
indicator light on extension
unit remains solid red, reprogram the link code on extension
unit
Follow these steps:
• Press and hold the button on the right side of the base
unit until the indicator light changes to solid red.
(Approximately five seconds.)
• Release the button, then the indicator light will blink orange.
This creates a new link code and places the base unit into
program mode.
• Follow steps (2) and (3) in the Additional Extension Units
section for all extension units.
• Press and release the button on the base unit to take it out of
program mode. The indicator light will change from flashing
orange to solid green.
Oct 10, 2008 | Computers & Internet
Blue light will not stay lit
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Jun 30, 2008 | Motorola Mobility H700 Wireless Headset
Panasonic KXDT343   Phone Logo
128 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
