Question about Sewing Machines
Do you have a manual for Brother PS-53 sewing machine please. I don't remember how to position the needle in the middle of the foot.
    President:
  • 1,197 Answers
Hi u can download the user manual from the below link.... just scroll down and u ll find a link for ur user manual
http://www.brother.com.au/homesewing/products/products.asp?ProductID=128&SubCategoryID=11
kindly rate my service..... good luck
Posted on Jun 20, 2009
  • 975 Answers
Go to this link to download free your manual ,
click here:
Am helping a neighbor who has a cheap Brother sewing machine, the needle does not seem to be centered, the default is to the right. I can center it by changing the needle position.
Some machines do not have a centered needle as a default. That is just how they were made. If she can reposition the needle to the center, then that is a pretty good option. Most older machines with the offset needles default do not have a centering option. (I have an old Nelco that has an offset default--works just fine but I just have to remember that when stitching, the seam line will not be in the center of the presser foot.)
Jun 06, 2017 | Brother Sewing Machines
How to change Brother compal galaxie 870 sewing machine needle default that starts on the left to default to the middle
Some machines have the left setting as the default. Those machines have the bobbin case that is installed from the left side of the machine. For most purposes, this default cannot be changed to center. Machines that have the bobbin case installed from the front of the machine generally have the needle center default position. However, it appears to be a newer model machine (post 1970), so there is a good chance your machine has a needle position setting.
Brother Compal Galaxie 870 Service Manual free download schematics...
Brother Sewing Machine Manuals Instruction and Repair Manuals
Feb 10, 2017 | Brother Sewing Machines
How to change needle position
Needle Positions on the SEWING MACHINE - YouTube
? 1:37
https://www.youtube.com/watch?v=OhN7w6DqX_Y
Oct 5, 2014 - Uploaded by Cindy Fetzer
8:52. How to Change Needle Position (filter bag machine) - Duration: 20:39. by Peter Wang 935 views. 20:39. BeginnersSewing Course - Day ...
Adjusting the default needle position, Brother PC 420 ...
? 6:53
https://www.youtube.com/watch?v=Xfq-GW88DsA
May 17, 2014 - Uploaded by Spamnot Nospam
Do you have trouble with the default left needle position making the needle of your Brother PC 420 sewing ...
Guide to Understanding Sewing Machine Needle Position
Jan 01, 2016 | Sewing Machines
Needle position won't hange
When you turn the machine on does the needle bar initialize? I.e. Move to the left, then to center.
Nov 03, 2013 | Brother SE400 Computerized Sewing Machine
Brother pe770 - needle threader is stuck in the down position while trying to thread it
Hi Kay,
I found the manual, in case you don't have one, HERE. On page 30, it has an illustration showing two buttons, and the presser foot lever. If you press the button once or twice, it will raise the needle.
> Press (Needle position button) once or twice to raise the needle.
> The needle is correctly raised when the mark on the handwheel is at the top, as shown below. Check the handwheel and, if this mark is not at this position, press (Needle position button) until it is.
Get the manual if you don't have one, that will give you so much more than any here can do, but I think that should solve you trouble, Please rate and comment, Thank You,
Joe
Sep 17, 2011 | Brother PE770 Computerized Sewing Machine
Missing brother PS 53 sewing machine foot pedal where can I purchase a second hand one
i just got my brother sewing machine serviced and they replaced what needed to be replaced(spotlight in australia)
Aug 29, 2010 | Brother LS-1717 Mechanical Sewing Machine
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric.
    * When you insert your new needle, make sure it’s positioned correctly (usually with the flat side
    away from the bobbin, but consult your manual), that it goes all the way into the holder, and
    that the screw is securely tightened.
    If this doesn’t seem to be the problem
    * Check your pressure foot
    Make sure it’s attached securely.
    * Change your pressure foot
    Your pressure foot may be bent, causing your needle to hit it.
    * Don’t sew over pins
    A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
    * Don’t pull your fabric as you sew
    You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
    * Check your needle plate
    Make sure it's securely in position.
    * Change your needle plate
    If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for
    sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
    * Check the position of your needle
    Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Sewing Machines Logo
513 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
