Question about Fujifilm Finepix S2980
Flash not working
The flash not working on camera when turn on there is a flash symbol with circle round and line through it but can not get flash on at all done camera reset and custom reset
Some time internal flash does not work in my nikon D3100 camera
When in program and manual mode, you will have to set it to flash. Make sure the circle around the electric bolt on the screen does not have a line through it, and it should work. There is usually a button with the symbol on it somewhere around the lcd(I'm not very familiar with your model or I'd tell you where) or it may be in the on screen menus if it's not a button around the screen.
Mar 15, 2012 | Nikon D3100 Digital Camera
How do i get the flashed turned on
First, check to make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Slide the switch away from the flower toward the mountain to take it out of macro mode. The flash won't fire in macro mode.
Then, if the flash still doesn't fire, take a look at the flash mode. Press the up-arrow button to bring up the flash menu. If it's currently set in the lightning-bolt-in-a-circle-with-a-slash-through-it symbol, you've got the flash turned off. Set it to the lightning-bolt-and-"A" for automatic flash or the lightning-bolt for forced flash.
If the flash still doesn't fire, then it's broken.
Sep 10, 2011 | Vivitar ViviCam 5024 Digital Camera
My nikon d90 pop up flash is not working but the pup up is poping up
Hi Reggie,
Usually the pop up flash will extend when the program calls for it or the user has manually turned it on, and it will fire without an issue. Page 70 of the manual goes into detail how it is set up and uses graphics which won't work very well here. Unless you have the "circle with a line though it" over the lightning bolt "flash" symbol, the flash should fire when needed.
It is possible that the flash lamp has failed, and may need to be replaced. Contact Nikon Service & Support or other reputable camera shop to help you with that.
I hope this helps & good luck!
Mar 24, 2011 | Nikon DSLR D90 Digital Camera
How do i get the flash to work
Ascertain that the camera has an alternate buton to activate the flash. In situaiton that camera has an automatic flash would take effect whenever envrionmental conditions either lightening requirements were observable. refer to the cameras user guide to familirise with feature functiosn.
Mar 02, 2011 | Vivitar V5024 Digital Camera
How do I turn the flash off?
On the top of the camera, near the wheel, there are 2 small round buttons, the one nearest the wheel has a lightning bolt on it, this button scrolls through flash modes. Change it to where the mode is a lightning bolt with a circle and diagonal line through it and flash should be disabled.
Jul 16, 2010 | Kodak EasyShare C340 Digital Camera
The symbol is a round orange circle with ! sign inside and lines
Brake pads require checking
This warns you early so you don,t ruin discs
Dec 24, 2009 | 2007 Mercedes-Benz SLK280 Roadster...
Describe how to turn on the flash
On the control button (large button on the back) at the top is a symbol that looks like a lightning bolt with an arrow tip. This is also the UP arrow. When you press it continually, the flash options will be noted by symbols.
No indicator - Auto
Lightning bolt - Flash forced on
Lightning bolt followed by SL - Slow Synchronized flash
Lightning bolt with the circle and line through it - Flash Forced off
You can refer to the manual for your camera at:
http://www.docs.sony.com/release/DSCS500.pdf
Use of the control button is on Page 17.
Thanks for using Fixya.
Dec 05, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Camera fails to flash every time we take a picture
1.Turn off the camera.
2.Install a set of new or fully charged batteries into the camera. then turn it ON
3.Press the Flash Status button to scroll through the flash options until Fill Flash (the lightning bolt icon alone, with no other letter or symbol) is displayed. This forces the camera to use the flash. a86196b.jpg
4.Take a picture. [If flash still doesn't work contact Kodak support line 1 800 235 6325 (23KODAK)]
Nov 16, 2009 | Kodak EasyShare C875 Digital Camera
How do i get my flash to turn back on
Hi! To turn On the flash you just need to press the flash button on the top of the camera., Flash button is like a down arrow or lightning icon., make sure that the flash symbol is set to A -icon or eye- icon or may be a down arrow symbol., if you see on your LCD a circle icon with a down arrow it means your flash is off., Gudluck!
Oct 19, 2009 | Kodak EasyShare Z650 Digital Camera
Fujifilm Finepix S2980 Logo
105 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
