LG Tromm FR1352NCZ have the following error "dE2"
The door is continuously locked with power or with removed power supply
  • 489 Answers
SOURCE: TROMM LG WM-2277HW
You may have a broken door latch switch that doesn't tell the computer that the door is actually closed.  Before you actually replace the latch switch, make sure the wire connectors are securely attached to the latch assembly.
Posted on Sep 29, 2008
  • 5 Answers
SOURCE: LG Tromm washer WM2688HWM tE error code. Very easy
LG Tromm Washing machine te error. The manual says to call for service. Not much help there. The reason for the error is the thermistor circuit (resistive element that becomes less resistive as it increases in temperature). The thermistor acts as a heat sensor. In many cases, the error occurs because the wireing harness is too tight at the bottom of the drum and one of the wires in this circuit becomes disconnected with all of the movement of the drum (unbalanced load, normal cylcing etc).
1. Unplug the washing machine from the wall. The thermistor circuit is at line voltage (110 in the U.S.) and it will bite! So do this first before proceeding.
2. Move the washer out so you can get access to the back of it.
3. Remove the stainless panel (the one that is not painted, it is large (aprox. 16x18 inches). It is held in place by 4 phillips screws.
4. Locate the thermistor connection block near the bottom of the machine, at the center of the wash drum. It is the small white connector that has two wires running to it. One wire is dark blue, the other is light blue. Insure that neither wire has pulled out of the connector. If either of them have, repair the connector and provide enough extra wire ( aprox. 2") to provide cable relief.
5. If the cable connector and wires are ok, there are other solutions here that recommend either cleaning or replacing the thermistor.
Good luck to you.
Posted on Aug 04, 2009
  • 497 Answers
SOURCE: Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
Posted on Sep 15, 2009
SOURCE: on my frontload LG tromm I have the error code EO it will
There is a filter on the bottom left of the machine. If you pop the door off you can drain it with the hose, then spin the black filter out of the housing. This may help. Keep a wet/dry vac handy.
Posted on Dec 21, 2009
  • 489 Answers
SOURCE: We have LG Tromm WM
You have a broken door switch and needs to be changed. The part number is 6601ER1004C. You will also need the door seal spring removal clamp tool to gain access to the back of the door switch. Without this tool, you will have a very hard time reinstalling the door seal spring.
Good luck.
Posted on Jul 12, 2011
What is error IE in LG FR1352NCZ washing machine? TIA
This IE error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Apr 24, 2017 | LG Washing Machines
My LG front loader is displaying de2, what can i do ? thank you
The dE2 error code indicates that the washer door is closed, but not locking.
Nov 29, 2016 | LG Washing Machines
De2 error code already replaced door switch sensor still getting samecode
possibly the door seal or the door itself could be misaligned causing the door not to close properly.
May 16, 2016 | LG WM8000HWA 5.1 Cu. Ft. Mega Capacity...
What is CE error code on LG TROMM WM1814CW
According to page 21 of the owner's manual, the following are known error codes: IE= Water Inlet Error, OE=Drain Error, UE=Unbalance Error, dE=Door Error, tE=Thermistor Error, FE=Overfill due to Faulty Water Valve, PE=Water Level Sensor Error, CE and LE=different Motor Errors, and PF=Power Failure.
its a motor error
check the brushes
Jan 03, 2015 | LG WM Washing Machines
Lg tromm washer
The DE or DOE (Door open error) error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Aug 22, 2014 | LG 4681EA2001D Original Water Pump Drain...
Lg tromm wd 85485 error code cl mean ?
Possible that the drain valve is clogged if the inlet line is working and so you need to remove the drain and back flush.Also check after the power plug is removed for few hours and see if the fault resets to start the machine only to show the error a few minutes later. if so clean the drain lines, check the inlet flow and the door switch.
Dec 15, 2011 | LG Washing Machines
LG Tromm washer, what does error code ''CL'' mean?
Hello there and welcome to fixya
THE cl is not a error code at all
it SIMPLY MEANS THAT THE CHILD LOCK FEATURE HAS BEEN ACTIVATED
not to dismiss the feature simply press and hold the wash and rinse buttons for a minimum of 5 seconds and release Your machine may be different so you may have to press a different series of buttons like if theree are 2 buttons with the unlock or lock picture on them or shows a child or something like this but it should be 2 buttons that are neded to unlock ok
Hope this is very helpful
Best regards Mike
Dec 15, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
Error message dE
HELLO,
WHAT THIS SIMPLY MEANS IS THAT THE DOOR OF THE WASHER IS NOT PROPERLY CLOSE OR LOCK.
WHAT YOU ARE TO DO TO FIX UP THIS PROBLEM IS, FIRST OF ALL PUT OFF THE WASHER FROM POWER SUPPLY THEN PUT IT ON AGAIN AFTER SOME TIME, THEN OPEN THE DOOR OF THE WASHER AND CLOSE IT BACK AND / THEN MAKE SURE THAT THE DOOR IS PROPERLY CLOSE OR LOCK.
GOOD LOCK AND THANKS FOR USING FIXYA.
Nov 23, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
