Question about Sewing Machines
The needle down position is no longer working and when I use the reverse mode it automatically will go into a knot. Is there a simple reboot solution?
SOURCE: Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Posted on Jan 23, 2009
kent581
  • 87 Answers
SOURCE: Needle stop switch will not control needle stop position
I can tell you its always on the upper shaft in the kenmore and it's on the right by the handwheel. The shaft has a wheel that rides through the sensor for shaft position sensing. It can actually go bad. If your machine zigzags ok, its not the shaft sensor becuse it knows where the shaft is to z.z. so it could be jsut that function on the board. Ive seen that.
Posted on Mar 18, 2009
app_3rp12544
SOURCE: Needle stop up/down no longer works on Viking 118
sometimes the bobbin winder gets left closed, and that will make the machine run slowly and with no up/down button.
Posted on Jan 09, 2012
SOURCE: machine embroidery needle changes position
truthfully I think their something wrong with the computer in the machine because
the bobbin locked up. sometimes when a sewing machine jams it can make
the machine jump time.
but the needle moved positions, some part of the machine is changed during the
jam up, even tho you reset it.
embroidery machine are expensive, my suggestion is to have the machine checked
Posted on Apr 05, 2012
Testimonial: "I've read about the timing being knocked off when the needle jams in the up/down position and other bobbin situations but didn't think it applied to left/center needle position change. Thank you....I will take it in for a thorough maintenance/reset."
yeroc
  • 397 Answers
SOURCE: how do I move the needle to the middle position ?
First if the machine is hitting something and breaking the manual will not help with timing issue, Machine IN ANY CASE should never come in contact with anything except thread. If Possible use your phone camera or something to take video and send to me
Posted on Oct 10, 2012
My needle arm is stuck in the down position, won't raise manually. Newbie
Not knowing the brand and model of your machine makes diagnosis difficult. In most machines that have the bobbin case inserted from the front, you can try releasing the bobbin case and removing it. When my machine jams, removing the bobbin case releases all those threads that are twisted and knotted inside that are "holding the needle captive."
Oct 03, 2015 | White Sewing 1418 Mechanical Sewing...
Model #385.1764180 the reverse no longer works. Is there a quick fix?
Mine was doing same thing. Open up from side and see if a little oil will help. Also, keep pushing down the Reverse button and make sure your needle Iis up, push down the V Reverse and see if it works again. A lot of grease inside these macbines have gotten thick. Keep trying to use it, guarantee it will start back. Mine works all the time now.
Sep 25, 2015 | Kenmore Sewing Machines
I have juki 1541industrial machine . It started sewing upside down . Instead of nice stiching on top show side it on bottom. Any ideas
This is caused by the tension between the bobbin and needle threads being out of balance. If the knots between the stitches are on the bottom side, then you need to tighten your needle thread tension a little at a time until the knot is in middle of fabric. The reverse of this is if the knots are on the top, then either your bobbin tension is too loose or your needle thread tension is too tight. If this occurs, then loosen your needle thread a little at a time to see if knot goes down in middle of fabric. If it does not, then you need to increase the tension on your bobbin thread. This done by taking bobbin case out and tighten the small screw located in the middle of the spring on the side of the case. You only need a slight, steady pull on the bobbin thread - the more you put on the bobbin, the more you are going to have to put on the needle thread.
Feb 13, 2015 | Juki Sewing Machines
My sewing machine model is B 750 QE. Always starting to sew the lower thread keeps knotting up it drags down the fabric and the cogs come on the screen..So I looked at the instructions and followed the...
1. To solve your knotting problem. Learn to always trap or grasp your thread ends for the first few stitches.
2. When the dogs are down, sometimes you have to grasp and jiggle or turn the hand wheel while re-engaging the feed dogs.
3. It sounds to me as if you aren't making sure that the take up leaver is in the top position before you press the "foot button down" Make sure you press "needle up" before you press foot down. That way the dogs should be in the correct position for you to get the fabric under there and proceed. In the mean time... I would strongly recommend you go back to your dealer and take some lessons. It sounds to me that when you learned to sew... you were not trained the proper procedures.
Oct 01, 2013 | Bernina Sewing Machines
Machine embroidery needle changes position
Apr 05, 2012 | Sewing Machines
Automatic needle threader stuck in lower position
So sorry I don't have an automatic threader so I'm no help in this department. Good luck!
Oct 26, 2011 | Singer 3116 Simple
How do you lengthen stitch. The stitches are so close together it looks like a satin stitch. I have no manual for it. thanks!
your machine should have a stitch length dial on the right hand side above the flywheel, it might have numbers from 0.5 to 3 or 4, higher number for longer stitch (effectively this moves the foot and feed dogs faster in relation to the needles to make the stitch longer).
If you have the Serge Pro SW432 that your enquiry is linked to and you have not used a serger before, then definitely get hold of the manual, you will need it. Sergers are very different to sewing machines - once you've mastered one, its easy, but there is a learning curve.
Firstly, ALWAYS extend the thread aerial up, you'll see loads of images of sergers sitting nicely with the aerial in the lowered position, great for moving them to avoid damage. But they won't work well, a serger seams at 1500 stitches per minute and the thread streams off the cones so you need to ensure there is a good clear feed via the aerial to the tension dials.
Buy good quality thread cones and keep it out of the sun and dust. Cover your machine when not in use (lower the aerial first). You could start with white, grey and black thread as this will cover a lot of fabric prints/colours etc. To change thread colour, you will need to cut and knot on the new thread for the two loopers (right hand side cones) - do this about 6 inches above the first thread guide, and then chain off to feed these through down to the needle plate, when you see the new colour come through okay, stop. Repeat the process for the needle thread or threads (3 or 4 thead depending on what stitch you are sewing) but stop chaining when the thread knot is above the needles. Stop, loosen these tension dials and pull the thread down, cut out the knot with scissors and thread the new colour through the two needles. Use threading wires if you have them, or tweezers. Pull both these and the two looper threads together under the pressure foot, lower the foot, turn your tension dials back to 5 and chain off. The thread sequence is important, mostly top looper, bottom looper, then needles, this is so much easier demonstrated than explained.
If you can find a classroom/shop offering overlocking user lessons, go take a couple, its well worth the money. Otherwise go to you-tube and watch all the videos you can search on sergers, threading, etc.
Good luck with your serger, please respond with 4 thumbs if this has been helpful to you. :-)
May 19, 2011 | Simplicity Serge Pro SW432 Mechanical...
My machine drops stitches, bobin hangs up, thread knots up. I have cleaned the bobin case and feeder. What can I do to fix the problem?
This may sound very simple, but try putting in a new needle. If the needle is blunt or has a burr on it, that could be the cause of your issues.
If it is a drop in bobbin style machine you may also have a "needle nick" on the plastic bobbin case. The thread can get caught up on those little knicks causeing it to get caught up or fray.
You can pollish down the little knicks with a very fine sandpaper to smooth them out.
Apr 21, 2011 | Elna 2007 Mechanical Sewing Machine
Bottom (bobbin) thread knots up as I am sewing? please tell me what I need to do. I'm very frustrated!!!!
check the needle to see if it's damaged-roll on flat surface to see if it rolls correctly
if the needle makes a popping sound going into fabric it is blunt
check the top thread & bobbin tension
some sewing machines knots up in bobbin area when the top thread comes off the thread take up lever
here's a tip how to tell if thread & needle are compatible
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
also check to make sure that the bobbin is not warped
Oct 01, 2010 | Singer 3116 Simple
Sewing machine motor will not run after attempting
Overload Viking:
The machine has a built in overload protector, if your needle can’t penetrate, it may stop the machine from working for a few minutes. Just wait it will reset automatically. Then, try a Sharp needle (denim needle is ideal) and be sure to Never Never reverse sew on heavy fabric, your needle will bend and hit the needle plate, use the FIX button for knotting (it really does work).
Mar 15, 2009 | Husqvarna Designer I
Sewing Machines Logo
14 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
