Question about Tally T6215 Matrix Printer
HAMMER VOLTAGE ISSUE
Been using the same Tally for over ten years and this morning, for the first time, gave a "hanner voltage' reading. What is this?
2 Suggested Answers
LineMatrix
  • 34 Answers
SOURCE: Tally Printer the error is some times Hammer
In the T6215 Maintenance Manual the fault message: Hammer Voltage has been replaced, in the T6218, with:
Hammer Voltage 1
There is a new fault message for the T6218. It is:
Hammer Voltage 2
Explanation: A high resistance coil fault has likely occurred in one or more of the hammer coils
Note: This fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Corrective Action:
Check the hammer bank for defective hammer coils.
Confirm that hammer drive board is functioning properly.
Posted on Apr 26, 2010
Faulty Hammer voltage-2 earr
There is most likely a fault with one of the hammer coils, this would need investigating, other possible causes;Faulty / damaged ribbon cableFaulty main boardUpdate firmware, the error should change to a more meaningful error with later firmware
Dec 16, 2011 | Tally 6306 Matrix Printer
Tally 6306 Matrix Printer hamer voltage 1 Error
Hammer voltage 1 is generally the logic board. One of the driver fets have gone bad. If you have schematics for the board you can fix otherwise a new board is required. Moving the temp cal is a bad idea. can cause a fire real easy.
Oct 01, 2011 | Tally 6306 Matrix Printer
Talley 6306 showing fault: hammer voltage 2
Hammer Voltage 2:
A high resistance coil fault has likely occurred in one or more of the hammer coils. Note: this fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Solution:
Check the hammer bank for defective coils.
Replace the Controller Board
May 04, 2011 | Tally T6218 Matrix Printer
I GOT PROBLEM IN TALLY 6303.ERROR CODE IS HAMMER VOLTAGE 1 FAULT, CAN U HELP ME WHUCH IC OR CHIP FAULTY
It could be the problem with your Hammer bank/ Hammer bank cable or MLC, Some cases dusty hammer bank .
Sep 25, 2010 | Tally 6306 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Hammer Voltage 1
Hammer Voltage 2
Corrective Action:
Apr 05, 2010 | Tally T6218 Matrix Printer
The 6306 L showing HAMMER VOLTAGE 1 ERROR WHAT SHOULD I DO
ERROR IS BECAUSE OF DRIVER IC FAULTY IN LOGIC CARD
PLZ CHANGE THE HAMMER DRIVER IC IN LOGIC CARD
Dec 13, 2009 | Tally 6306 Matrix Printer
Tally 6218 hammer voltage 2
Hammer Voltage 2 is the worst error you can get on the Tally T6200 series...
Explanation:
hammer coils.
bank temperature. Check blower underneath ribbon Deck.
Corrective Action:
Check the hammer bank for defective hammer coils qty 7 per hammerbank.
Aug 25, 2009 | Tally T6218 Matrix Printer
Showing hammer voltage 2 error
the problem comming from logic board. need to change the logic board and hammer bank cable at the same time.
Apr 05, 2008 | Tally T6218 Matrix Printer
Hammer voltage 2
it prints for about two minutes then starts slowing down and then stops printing showing an error of : hammer voltage 2
Sep 05, 2007 | Tally T6218 Matrix Printer
Open Questions:
Tally 6215 Printer printing problem: The printer is able to print okay as long as there are hard coded PAGE BREAKS (form feeds). PROBLEM: We have files that are thousands of lines and rely on the printer to do the page break. On March 16,2011, The printer setting for paper size was changed from it't true size of 12x8.5 to 12x11.38 in order to get the printer to print the hard coded page breaks correctly. PROBLEM: When there are no hard coded page breaks, the printer prints 8 separate lines on 8 sheets and then resumes printing a full page. This pattern continues as long as there are no hard page breaks in the file. The problem with the Tally printer all began when the driver was updated to handle the 64 bit OS. Since then, a service person was called, and with Joan's help, they were able to band-aide....not fix the issue. Joan has a very good description of what we are dealing with now in her email below along with a test file. This band-aide also involves some manual updates to the file we are trying to print and is causing alot of time to be wasted.....and these are on smaller locations like Metro North. This will not work for the large NY projects. Additional Information: Basically what you have now is the paper size fudged to some odd size, with the printer itself still being set to 12x8.5. So any form feeds..manual or by special character codes in the text file work ok, but when you have more lines than can fit on the 12x8.5 paper size and the printer needs to advance to the next sheet, it prints a single line on the page until it gets to the correct line count of the fudged paper size and will resume printing a full page again.
Feb 28, 2017 | Tally T6215 Matrix Printer
Tally T6215 Matrix Printer Logo
14 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
