Question about Vestax Handy Trax Turntable
Vestax Handy Trax Turntable skips toward the end of very LP played. Does anyone know how to resolve this issue?
  • Vestax Master
  • 5,158 Answers
Generally caused by a worn stylus, or incorrect pressure. Increase the weight - pressure, by adjusting the weight on the end of the arm.
Posted on Apr 27, 2014
2 Suggested Answers
SOURCE: Vestax Handy Trax
Since the Handy Trax Comes with a Sapphire needle, upgrading to a diamong one will give a better sound http://www.turntablelab.com/dj_equipment/1/131/4962.html
Posted on Jan 04, 2009
Humming with vestax
hummm , does it also hum with the other gear shift out, especially tl and ledlights, if so it't a ground loop, but often is just the earth of the turntable not well connected
Apr 14, 2014 | Vestax Handy Trax Turntable
Clibrate pitch Vestax PDX d3S
It's a variable , since it's depended on more parts, but just clean it first and gently turn it until the platter moves correct,assuming you
mean to correct the variable resistor(potmeter) . If the value was everywhere the same, then you don't need a variable resistor:)
Jun 19, 2013 | Vestax Handy Trax Turntable
My vestax doesn't start at all - is the tonearm damaged?
This is a belt driven turntable. It is very possible that the belt between the motor and platter has either broken or slipped off.
Consult your manual for instructions on how to access and replace the belt. Since it appears it isn't even trying to start, it is probably not just slipping.
If the belt isn't the problem - you could see if you see the drive motor running when activated. If the motor isn't running, there may be a problem with the motor, tone arm or something else.
Hopefully, the belt is the problem. Good luck!
Sep 21, 2010 | Vestax Handy Trax Turntable
How do i remove my stylus from the vestex handy trax
http://www.turntableneedles.com/search.asp?keyword=handy+trax&search=GO
use strong fingernail or similar to unclip the red plastic straight down. above is the needle you seek.
Apr 19, 2010 | Vestax Handy Trax Turntable
I have problem with tonearm on my vestax pdx 2000 turntable , no connection with needle , but when I make contacts of the needle wet it sometimes help a bit , but I should do it always to make it work. ...
I'd be checking the weight and height settings of the tonearm. Heres a link to the manual for the deck. There's instructions in there about how to setup up the tonearm properly. Don't be afraid to experiment with it. Just remember, too much weight will wear out your vinyl really quickly. Not enough weight will sound like **** and skip easily. Have fun!
http://www.vestax.com/v/info/support/pdf_players_manuals/VOM-PDX-2000E.pdf
Dec 15, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Vestax Handy Trax
Oct 11, 2008 | Vestax Handy Trax Turntable
Sl-dd33 turntable
If your needle just started to skip across the LP, then that means your stylus is damaged/worn and needs to be replaced. It's very hard to see the diamond tip on the stylus, and it might not even be there at all. So checking it might not yield any results. This is what happens when the needle is worn. It will skip across the record.
- OPTiC
Turntable Technician
www.1200s.com
Aug 27, 2008 | Audio Players & Recorders
Technics SL 1600 MK2
Your tonearm is damaged. More than likely the bearings on the tonearm have been damaged. Unfortunately, there is no easy fix for this. You'll have to have the tonearm replaced, however, parts for the SL1600MK2 have been discontinued. The tonearm for the SL1200MK2 might fit it, but you will need to do some retro-fitting in order to make it work properly. Something only a qualified service center could perform.
Hope this helps some.
DIGITAL ANALOG THERAPY
May 29, 2008 | Technics SL-1200MK2 Turntable
The spin of the tonearme doesn't works softly.
hex screw hole under the tonearm you have to seperate the tonearm from sitting on the base, then tighten back down homie
Oct 20, 2007 | Vestax PDX-2300 Turntable
Vestax Handy Trax Turntable Logo
117 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Electric Dime
Electric Dime
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
