Question about Kenmore Refrigerators
Refrigerator plenty of snow in freezer
  • 884 Answers
Check door sealing properly, condenser clear and clean and not too high temperature around freezer. If fan fitted inside, check blades turning properly and not stuck in frost
Posted on Apr 22, 2014
Snow in freezer
After you defrost the freezer you will need to clean the coils underneath the frig and be sure that air can flow properly.
Apr 22, 2014 | Kenmore Refrigerators
"snow" in the freezer
YOU HAVE A DEFROST PROBLEM IF THE SNOW IS ON THE BACK WALL. ISSUES WOULSD BE --TIMER, DEFROST THERMOSTAT. OR DEFROST HEATER. IF THE SNOW IS SOME WHERE ELSE YOU HAVE A PROBLEM WITH A DOOR SEAL.
Nov 03, 2009 | Refrigerators
I have a kenmore refridgerator side by side. The freezer is beginning to have snow buildup (it is a self defrost) the refridgerator side is not cold
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Could you find a model number like 321.256489 for example then I can find the parts to look for. Sea Breeze
Aug 20, 2009 | Kenmore Refrigerators
Freezer suddenly is creating mounds of freezer "fluff"
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Sea Breeze
Aug 20, 2009 | KitchenAid KSRS25ILSS Side by Side...
It's snowing in my freezer!
it's not the filter. is there frost on the inside lower back of the freezer. or is it around the edge of the door are your ice cubes fuzzy can you here the fan running in the freezer
Jun 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Snows inside freezeer compartment of side by side
You actually have 2 problems here.
One the ice maker shutoff is defective. REPAIR is to replace the ice maker.
Two (snow) is a loose door seal, Outside air entering the freezer.
Feb 20, 2009 | Kenmore Refrigerators
Samsung side by side
Check for snow on the back wall of the freezer compartment, Air to cool the refrigerator is supplied from the freezer section. If the coil is frozen over the air circulation becomes retarded and the refrigerator suffers. Snow on the back wall indicates a defrost problem.
May 15, 2008 | Refrigerators
Maytag side by side
all the cold air is made in the frezzer section then blown to the refrig section, the frzzer needs tobe -5 or 0 degrees F, also post model and serial number
alot of time people think if it freezes water it is cold but that happens at 32 F
May 05, 2008 | Maytag MSD2656G Side by Side Refrigerator
Repair
Defrost system problem will be indicated by frost (snow) on back wall or cooling coil is located in the freezer compartment. Check freezer control setting. If it is set to cold for the freezer it reduces cold air to the refrigerator section.
Mar 26, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Refrigerators Logo
26 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
