Imagistics cm4520 print booklet
  • 1,087 Answers
Posted on Apr 22, 2014
Shows status offline wont print
Replace with a new drum, clear your print que. reset network and printer
Aug 20, 2015 | Canon Genuine Oce Imagistics Fx3000...
Replacement ink
clean touch point of cartridge both side
Mar 31, 2014 | Pitney Bowes IMAGISTICS OCE IM3511,IM4511...
Imagistics cm4520 error codes
That is a rom error and will need a tech to look at.
Mar 30, 2014 | Konica Minolta Office Equipment & Supplies
How do you get ip address on Imagistics 6530
Usually printers are assigned static IP's, you can contact the network admin to get that normally.
Short of that, print off a status page in the menu, it will contain the IP address.
Mar 29, 2013 | Sharp Computers & Internet
I have a Minolta Di181 black and white copier. It started printing lines all through the paper and was a little dark. I bought another copy machine because this one is old. It is a imagistics zc25 this...
Well, you put your self into a pickel. With the Di181 you most likly neede a new drum and cln blade & a good cleaning. Now with the Imagistics, you may have the same problem, but you put Minolta toner into a Imagistics. Thats like putting oil into water and wonder why they don't mix? Now you need to replace the drum & blade & developer & toner and vaccum out all the toner and start off with all new. Good Luck
Jul 28, 2010 | Panasonic DP-8020E Black and White Copier
C180 says E2 and printer tray light blinks
E2 means paper miss feed press resum button the go to print
Oct 30, 2009 | Pitney Bowes C180 Copier
I am having trouble with booklet style printing -- under Vista
After a great deal of frustration and trying every permutation possible I succeeded amid an ever rising mountain of paper! . . .and find that I have to totally ignore the "Booklet printing" option . . . but ask it to print landscape; 1 page per sheet; flip on short edge.
Now I need to do the same to crack the sytem for the Cannon Pixma IP4000 inkjet.
Thank you for your consideration.
Sep 30, 2009 | Brother HL 5150D Laser Printer
Faxing problem Imagistics 2500
You're correct, it's the scanner. Finding out what exactly is wrong with it is a little more difficult. First check the easy thing, scan a sample paper 4 times, each time pushing it against a different one of the four corners, and see if the line goes away or changes when you change the location of the paper on the scanner. If that doesn't work, take off the glass plate and clean it and everything under it, then try again. If none of that helps, download the latest drivers.
Please rate, thanks!
Mar 13, 2009 | SMC Accessories Chembook 2500: Port...
Need help to connect my dell laptop to imagistics 2500 printer please
it is possible to set this multi-function fax/copy/printer for printing from your laptop. There is an available GDI driver from the manufacturer's website (http://www.oceusa.com) for Windows Vista 64 (exe file). Other than that it should install like any other printer.
Jul 01, 2008 | Computers & Internet
k24674
jasbo
jasbo
