Question about Microsoft Xbox 360 Console
WhiteVeil91@gmail.com Wont let me sign in on xbox live . it says there something wrong with my account ? please help
  • Microsoft Master
  • 3,278 Answers
Xbox live has changed its protocols, online users will not need to do anything but if you have not been on for a while you will need to update xbox if this dont work log into xbox live on internet and follow the online setting page.
Posted on Apr 23, 2014
  • 23 Answers
SOURCE: xbox live
THINGS TO TRY loadTOCNode(1, 'whattotry'); Direct connection with a modem only loadTOCNode(3, 'whattotry'); 1. If you are connecting to Xbox Live by using a modem that is connected directly into your broadband socket, your IP address settings are obtained from your ISP. Set your IP address in Network Settings to Automatic. 2. If you use a static IP address that you obtained from your ISP, you must manually enter this address in the Dashboard. Contact your ISP for their static IP address if you do not know it. If the IP is not static, continue with the rest of the troubleshooting. 3. Power cycle the modem. 4. If your ISP requires PPPoE settings, verify that you have entered them correctly. 5. If your ISP does not use PPPoE authentication, do not use these fields in the Dashboard. Shared connection with a modem and a router loadTOCNode(3, 'whattotry'); 1. Power cycle both the modem and the router. 2. Try connecting the Xbox 360 console to Xbox Live by using the modem only. This eliminates any configuration problems on the router. • If this setup works without the router, there is a configuration issue with the router. See the router's documentation or contact the technical support group. 3. Verify that your router's DHCP service has been enabled. See the router's documentation or contact the technical support group. 4. The IP address that you entered in the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If your ISP requires PPPoE settings, try to connect with only the modem after you enter the PPPoE settings in Network Settings. • If you can connect, see your router documentation to configure the PPPoE settings correctly on the router. 6. If you are receiving an IP conflict error in the More Info section, turn off all the devices on the network. Try to connect with only the modem and Xbox 360 console connected. • If this works, there is a configuration issue on the routers DHCP server. See the router's documentation or contact the technical support group. Shared connection with a gateway device (combined modem and router) loadTOCNode(3, 'whattotry'); 1. Make sure that the device is turned on. 2. Verify that there is activity with the blinking lights sequence WAN, ADSL, and Internet connected power. Note These names will vary from model to model. 3. Power cycle the gateway device. 4. The IP address that you entered in to the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If you are receiving an IP conflict error in the More Info section, turn off all the other devices on the network. Try to connect with only the Xbox 360 console on the network. • If this test works, there is a configuration issue on the gateway DHCP server. See the router's documentation or contact the technical support group. Shared connection with Microsoft Windows Internet Connection Sharing loadTOCNode(3, 'whattotry'); 1. Verify that you can browse the Internet. If you cannot browse the Internet, Internet Connection Sharing is not configured correctly. 2. Power cycle the modem. If the modem does not have an on and off switch, unplug the modem from the power outlet. You cannot follow this step if you are using a USB modem. Instead, go to the next step. You must follow this step if you are switching the modem between the Xbox 360 console and a computer. 3. On the computer, click Start, click Run, type ncpa.cpl, and then click OK. 4. On the View menu, click Tiles. 5. If the connection is listed as Firewalled, the firewall may have to be configured. See your firewall documentation. 6. Enter manual settings in the Dashboard for IP address, subnet mask, DNS address and gateway: • IP Address : 192.168.0.2 • Subnet mask : 255.255.255.0 • Default Gateway : 192.168.0.1 • DNS server (Primary): 192.168.0.1 • DNS server (Secondary): 192.168.0.1If none of this works you might be banned. If you modded your xbox360 or for downloading game saves from the internet to boost you gamer score. You might be banned!
Posted on Oct 17, 2007
bestdarngood
  • 3037 Answers
SOURCE: xbox live subscription code
you should be able to either call xbox or email them the problem and they will be able to help you, you just bought the 3 month subscription I believe and if it isn't working, then it is there problem, that you need them to fix, maybe give you a different code
Posted on Mar 19, 2008
  • 5 Answers
SOURCE: i am unable to sign into to my live account?
Have you clicked test connection and have it tell you why it cant connect?? If it cant connect to the xbox Live and its not a connection problem, Live might be down, you could be banned, there may be an update you need. Most of the time you cant connect there may be a temporary maintenance for live. If you still cant connect call xbox customer support and ask about your account.
Posted on Sep 21, 2008
SOURCE: when i sign onto my xbox live account, the whole system freezes
My issue started when i downloaded a new demo called stickball. i don't know if it helps to know that, but consider what you were doing before the problem started.
Posted on Oct 11, 2008
SOURCE: cant connect to xbox live with vzaccess!! please help...
You have two options. Number 1, plug the 360 into a LAN port on your PC and set up the LAN connection to share the internet with the VZaccess connection. This will work as long as you are connected through vzacess manager.
Option number two, get an EV-DO router, wireless or wired, and use it to connect the xbox.
If using option 1, you may have to struggle at first with the IP settings. Make sure the LAN connection AND the 360 are set up to configure IP and DNS automatically. And make sure that you set the sharing options to include http and such. more help can be found by searching in Windows Help for ICS (internet connection sharing)
Posted on Feb 14, 2009
I changed my gmail password now xbox live wont play
Are you google and microsoft accounts somehow linked? I'd recommend clearing out any possible residue cookies, signing out of your accounts then restarting your system and trying to sign back in or simply contact Microsoft Support.
Feb 11, 2015 | Video Game Consoles & Games
I forgot my xbox password
If you can't sign in to an Xbox Live profile on your console, here are other ways to find your Microsoft account OR recover your password.
  • Go to login.live.com and try signing in with what you think is your Microsoft account (email address and password). If you can sign in, the email address and password you entered are valid. Next, go to Xbox.com and try signing in with this same information. If you're prompted to create an Xbox profile, the Microsoft account you entered is not currently associated with an Xbox Live account. Otherwise, you will sign in and see your gamertag in the upper-right corner of the screen. This email is associated with an Xbox Live account.
  • Check your email accounts for messages about your Xbox Live membership (search for messages about "Xbox Live" or "Microsoft billing"). This may help you determine which email address is associated with your Xbox Live membership.
  • If you have forgotten your password, when attempt to login, click the "Can't access your account?" link below the credential boxes and then select "I forgot my password." You'll then be brought through a step-by-step process to recover your account password.
Apr 03, 2014 | Video Game Consoles & Games
There is something wrong with my microsft account its not letting me log in and the code is 8015d003
You see the following error message when you try to sign in to Xbox Live:
Sorry, something's wrong with your Microsoft account. Go to https://account.live.com for help.
Status code 8015D003
This may mean that there's a problem with your Xbox profile.
Solutions
To resolve this issue, try the following solutions.
Solution 1: Verify your Microsoft account security information
  1. Go to Microsoft account. If you forgot your password or it doesn't work, reset your password.)
  2. Click Edit security info.
  3. Verify your security information. For example, verify the Phone number, Alternate email address, and Security question information.
  4. Sign out of your Microsoft account, and then sign in again.
  5. Try to sign in to Xbox Live again.
Solution 2: Clear the system cache
  1. Press the Guide button on your controller.
  2. Go to settings and select System Settings.
  3. Select Storage or Memory.
  4. Highlight any storage device, and then press Y on your controller. (It doesn't matter which storage device you select; the cache will be cleared for all storage devices.)
  5. Select Clear System Cache.
    Note Repeat this step three times.
  6. When you are prompted to confirm storage device maintenance, select Yes.
  7. Repeat steps 4-6 three times to fully clear the cache.
Solution 3: Move and then redownload your Xbox Live profile
Note If you want to use a USB flash drive or a USB hard drive to complete these steps, you must format the USB flash drive or USB hard drive for Xbox storage. (See USB flash drive support for Xbox 360.)
  1. Move your profile to a USB flash drive or USB hard drive. To do this, follow these steps:
    1. Plug the USB drive into your console.
    2. From the Dashboard, go to settings and select Storage.
    3. Select All Devices.
    4. Select Profiles, and then select your gamer profile.
    5. Select Move.
    6. Select the Memory Unit that you want to move your profile to.
      Note A Memory Unit can be a USB flash drive, a USB hard drive, or the Xbox 360 Hard Drive. Be sure that you move the profile to a USB flash drive or a USB hard drive.
    7. Remove the Memory Unit from your console.
  2. Redownload your profile. For details, see Download, move, or delete your Xbox Live profile.
Sep 27, 2013 | Thorogood Boots 534-6333 Womens Code 3...
Hi my name Raymond Carrasco My Xbox wont let me sign into xbox live it says I have to have security check and I know my password but it says something is wrong with my Microsoft account my email is ...
Retrieve your password by forgetting your password tab and check your email which you given while signing up XBOX LIVE account. This will help you in this regards
Thanks
Sep 24, 2013 | Microsoft Video Game Consoles & Games
Locked out of my Xbox live account
I know its really annoying.I required a password for my account and evertime i try to sign in it says something is wrong with you account and i could not use security proofs.Pleaz help us microsoft experts cuz i cant even use my account.Itry calling xbox customer support bot they are helpless and i also try giong to xbox.com/support and there usless as well.Well thats all igot and please help.
Nov 13, 2012 | Microsoft Xbox 360 Elite Console
Ummm i got suspended due to my payments but my mom got a new card how do i fix it
Change payment for an Xbox LIVE membership
Xbox LIVE purchases and membership renewals are charged to the payment option that is associated with your Xbox LIVE account. Use the following steps to add or change a payment option that is associated with your Xbox LIVE account. If you want to remove a payment option, please see Remove an Xbox LIVE payment option.
Show all Console steps: Add or change a payment option
  1. Sign in using your Xbox LIVE gamertag.
  2. Go to My Xbox, and then select your avatar.
  3. Go to Account Management, and then select Manage Account. profile_mngacctgold.jpg
  4. Go to Your Memberships, and then select the membership that you want to change (for example, Xbox LIVE Gold). profile_acctmgmtgold.jpg
  6. Do one of the following:
    • Select Add Credit Card to add a new credit card.
    • Select Add PayPal for information about how to add a PayPal account at xbox.com/accounts. PayPal is not available in all regions. For a list of supported regions, please see Using PayPal with your Xbox LIVE Account.
    • To edit an existing payment option, select the payment option.
Computer steps: Add or change a payment option You can also you can add or edit Xbox LIVE account information using the Microsoft Billing and Account Management website. Here's how:
  1. On a computer, go to https://billing.microsoft.com, and sign in using the Windows Live ID (email and password) that is associated with your Xbox LIVE account.
    Note If you don't know your Windows Live ID or password, please see Manage your Windows Live ID.
  3. To change a payment option, click View/Edit next to the payment type that you want to change. billing_personalinfo.gif
  4. Now you can add or edit a payment method.
    Edit a payment
    Click Edit payment method information and update your payment information. billing_editpaymethod.gif
    Add a payment
    Click Use a different payment method to add a new payment method and follow the on-screen instructions. billing_usediffpaymethod.gif
Jul 21, 2011 | Video Game Consoles & Games
Hi i have just set up xbox live set my account up but it wont let my sign in on the end of it do i need to do something else
kindly create a windows live ID by signing up in the website www.live.com
you can use your only personal email by choosing use your own email
May 31, 2010 | Microsoft Xbox 360 Console
Xbox 360 unable to get live
i cant find out to put the xbox up to this
Sep 21, 2008 | Microsoft Xbox 360 Console
I am unable to sign into to my live account?
Sep 20, 2008 | Microsoft Xbox 360 Console
Xbox LIVE
Either go to Xbox.com and sign into your account that way. Which I hope you registered your account with an email or password if you didn't then you wont be able to sign in. I always buy the 1 year + 1 month free cards that is like 45 bucks from my local gaming store which is very helpful. If you can't find a way to sign in and change the information to the other credit card then Im afraid you will have to make a new gamertag.
Mar 14, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
