Question about Nostalgia Electrics Kegerator Beer Fridge
Cooling issues Kegerator does not stay cold. Unit runs for a short time then stops. If dial is moved slightly in either direction, units starts again then soon stops.
  • 884 Answers
Sounds like the thermostat. can you bypass it (ie connect the two wires together) and make it run all the time? If so, replace the thermostat
Posted on Apr 22, 2014
Refrigerator not cooling as it should?
Check out these tips that I wrote about that...it is a great place to start trouble shooting your unit...and something thatyou can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 23, 2011 | Kenmore Side by Side Refrigerator
Refrigerator is not cooling as it used too. Freezer has some slight frost at times. Have set the dials for colder and more air flow to refrigerator, but have not set the dials as high as they could go. ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Jul 06, 2011 | Kenmore Side by Side Refrigerator
The kegerator will not get cold. It seems to cool slightly but it wont get cold any longer. It does sounds like the compressor is working .. i hear it turn on and off as it did when it was working...
heatman101
Mar 31, 2011 | Beverage-Air BEVBM23 Commercial Beverage...
The door on our older freezer was left open. 2days later I noticed it. The unit runs but comp hums but cooling coils are not getting cold them dial does not shut unit on and off. Without schematic I don't...
chance are that the frost has turned to ice if the unit started to defrost then got cold again.do a full defrost and then try starting from warm....
Sep 25, 2010 | Whirlpool Freezers
Room a/c works great for hours and then compressor just stops
the unit may be knocking off on defrost if the coil is getting v cold,
check for full airflow over the indoor unit/evaporator coil, check filters fan operation and coil condition. Likewise it may be overheating so check the same on the outdoor unit/condenser clean coil and fan operation.
Unlikely but the unit may be under performing and slightly short on refrigerant, not providing enough suction cooling to the compressor motor so the internal over temp klixon would cut it off for short periods, to cool the motor.
Jul 05, 2010 | Samsung AW1203B Air Conditioner
Older Superior Brand Kegerator Freezing
Sounds like the fan can be running backwards. I'm not sure of you exact model, but it has to match the air flow of the original unit. Do you remember? Some manufacturers use reversable motors and are some what easy to reverse.
Good luck and hope this helps.
May 08, 2009 | Danby DKC645BLS Compact Beverage Cooler
Dial
Guest, you got it right but this is typically not a problem on whirlpools now because the drain exits at a higher level. however if its the older with drian exit at bottom then definately make sure it goes up then down to avoid gravity drain.
adjusting the dial to fix indicates a potential timer issue. is the drain pump running (spinning) while filling?
Mar 15, 2009 | Whirlpool Inglis IP4400 Washer
Beverage air dd58 kegerator won't stay cold
The unit is probably low on gas again. If it lasts a month the leak may be difficult to find, as it may be a small leak. Those units don't hold a lot of gas. Have someone do a nitrogen leak check and fix the leak. If no leak is found, have them install a UV dye to help find the leak. :)
Jan 12, 2009 | Beverage-Air DD58 Beverage Cooler
Nostalgia Electrics Kegerator Beer Fridge Logo
155 people viewed this question
Top Nostalgia Electrics Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Nostalgia Electrics Refrigerator Expert? Answer questions, earn points and help others
