Question about Mitsubishi Heating & Cooling
Defective thermistor model msxy-fd10va-r2 - Mitsubishi Heating & Cooling
Ricoh Aficio 1015. Why is it not resetting?
Code 543 - Description: Fusing overheat error.
A fusing temperature of over 230°C is detected for 1 second by the fusing thermistor. - Causes: • Fusing thermistor defective • Power supply board defective
May 28, 2015 | Ricoh Aficio 1015 All-In-One Laser Printer
Kenmore Elite model 795.7904 error message ff
I believe that is a thermistor warning: thermistor is used as a thermometer electrically reads the temperature in your fresh food section and when it becomes defective it will alert you with the F F
Dec 03, 2014 | Kenmore Refrigerators
Refrigerator is freezing food and liquids with the controls set to their lowest setting.
This could be caused by a defective=> WR60X10052 Damper Control Assembly or could be caused by a defective fresh food thermister=> WR55X10027 Thermistor or WR55X10027 Thermistor. You will need to run the diagnostics found in the GSS25LGMA Service Manual I am here should you need me, Thanks John Tripp Appliance 911
Mar 19, 2014 | GE Refrigerators
How do i Measure the resistance of each thermistor
Dryer getting over heated. Check your exhaust vent for good air flow. Also your operating thermostat could be defective overheating the dryer and blowing your thermal fuse. To check resistance set your multimeter to ohms and connect your leads to thermistor make sure to disconnect the wires from the thermistor.
Mar 05, 2014 | Dryers
Error E04-01 Panasonic DP-4510
E4- 01
Fuser Warm-up Temperature
Possible Cause(s)
1. Fuser Thermistor dirty.
2. Thermistor position incorrect.
3. Thermistor defective.
4. Thermistor connector disconnected.
5. Fuser Lamp connector disconnected.
6. Fuser Lamp defective.
7. Fuser Thermostat defective.
8. Thermal Fuse defective.
9. SPC PCB connector disconnected.
10. SPC PCB defective.
11. Fuser temperature low. (Adjust F6-31)
12. Incorrect SC PCB is installed.
13. Incorrect SPC PCB is installed.
Aug 05, 2011 | Panasonic FP-D355DC Copier
Ricoh aficio 1045 - SC541
Fusing thermostat/thermistor open
Symptom: The fusing temperature detected by the
thermistor is below 10°C for 5 seconds
after the main power switch is turned
on.
Possible Cause:
• Fusing thermostat defective or out of
position
• Fusing thermistor defective or out of
position
May 25, 2011 | Ricoh Aficio 1035 Copier
I have a 36v ac 3640 cv charger with a burnt out thermistor i need to know rating for the thrmistor marked up on pcb as r2
hi mate i know its 2 years over later if u have red flashing led this normally fixes fault..replace R2 ON CHARGER,
www.uk.farnel.com then search this,,,:- B57236S500M
Mar 09, 2011 | Bosch Drills
Kyocera FS-2000D This printer comes up with error code 6120-0044336 at power on Is this a fuser error?
Yes it is a fuser error.
6120 Abnormally high fuser thermistor S temperature
*35/37 and 45/47 ppm printers (EUR/USA model) only
The temperature of the fuser thermistor S detects 250°C/482°F or more continuously for 3 s.
Shorted fuser thermistor S.
1. Measure the resistance. If it is 0 ω, replace the fuser thermistor S.
2. Defective engine PWB.
Replace the engine PWB
Mar 08, 2011 | Kyocera FS-2000D Laser Printer
Fan doesn't when 6pin cable between power supply and PA, is plugged in, however fan works when disconnected from PA board
The fan control receives two signals from the HCA2400 power amp module. Pin 4 is labelled POS+ and pin 5 is labelled POS-.
These two interact with T14,T15,T16,T17, and finally T7 which gates a -21 volt power to the fan.
From the schematic, it appears that if POS- is more positive than about 20 vollts negative the fan will be held off. It appears that the POS+ signal controls the speed and as it goes more positive, this would DECREASE the speed. Pots VR2 and VR3 are used to set these thresholds and I do not have setup instructions for those... I would be very careful about adjusting them without the procedure. . HOWEVER, first thing is to verify that you have -21 volts DC on pin 2 of the fan connector. With the HCA2400 disconnected, the POS- will drift to -21 volts and POS+ should drift to somewhere around -6 to -8 volts judging from the schematic.
Trying to trace these two signals on the HCA2400 is very difficult and the schematic does not show where they go... I did find that pin 5 does go to one of the thermistors on the heat sink labeled R2 and one side of R1 goes to pin 3 which is -12 volts by tracing an HCA2400 I have open. Pin 4 seems to go to the other side of R2 so then the R2 thermistor connects between POS+ and POS-.
The room temp (71F) resistance of R2 seems to be about 112 ohms and rises with increasing temp. It appears that R1 is involved with a signal sent to the power supply called OFF which probably shuts down the supply if the HCA2400 gets too hot... so R1 thermistor on the HCA2400 would have nothing to do with the fan... I can;t verify that R2 does more than connect to pins 4 and 5 of the connector... there may be biasing resistors on the HCA2400... I would find it odd that VR2 and VR3 would both be connected in series effectively with R2 thermistor... so I suspect there are additional biasing on the HCA2400 that one of the tweek pots conrols the ability to run and the other controls the speed above that... Please note that the resistance measurements of R2 are made on an HCA2400 that a hacker all but destroyed...
Nov 29, 2010 | Behringer Europower Pmp5000 Powered Mixer...
We have a code H 4 blinking model AL-1631 AL-1641CS
Please verify your fuser parts components,the heater lamp,thermistors and thermofuse.Your heaterlamp or the thermostat is in open circuit or the thermistors circuit is defectly.
Dec 11, 2009 | Sharp Office Equipment & Supplies
Heating & Cooling Logo
37 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
