Question about Ryobi ZRRY26500 26-cc 17-in Curve Shaft Gas Trimmer
Throttle assembly need to know how the throttle assembles back on the shaft. specifically the spring that holds the trigger
I need to reconnect the throttle cable inside the poulan 446T trimmer motor chamber and am not exactly sure where it goes
ahh a poulan !! I'll bet that the throttle trigger assembly is loose enough to slide around on shaft ? if so first before you try to reconnect anything , your gonna need to get that back to factory position , (look for marks on shaft) once you do that its just a matter of moving the "L" shaped piece on the end of throttle cable up and then down thru the "D" shaped chrome piece's hole that's on top of carburetor , there should be only one hole that it will reach so there's no problem there after that retighten the trigger assembly and your done
Jul 21, 2015 | Garden
How to disassemble the throttle/trigger assembly on at Husqvarna 150BT blower.
Internal or external snap rings usually require a special pair of pliers to remove. In absence, you might try a very pointed pair of needle nose pliers or even a pair of dental tools or similar. Once the ring begins to dislodge from its groove you should be able to work it out. Reinstallation might require the specific tool.
Oct 03, 2014 | Husqvarna 150BT 50CC Gas Leaf Backpack...
1995 h-d sportster 1200 shifting shaft spring
remove the primary cover,stator and clutch assembly. remove the hardware that holds the shifter shaft assembly. and change the shift shaft centering spring on the shift shaft itself.
Sep 19, 2012 | Motorcycles
A Part broke off from my Yardman weedeater YM4570 the part that has two parts and are held by two springs which turns and expands when accelerates
The Yard-Man YM4570 is a nice 4-cycle gas trimmer.
It's hard to tell from your description, but the part you are referring to could possibly be related to the throttle assembly:
Throttle Housing & Trigger Assembly
Part Number: 753-04234
Throttle Trigger Spring
Part Number: 791-182690
You can get the part numbers and Operators Manual at MTD Products... click here:
Operators Manual
Nov 14, 2011 | Garden
Took throttle assembly off of my 2005 sportser. spring came off and i can't figure out how it goes back together.
The only spring that I know of that is at the throttle assembly on the handlebar is a tension spring that goes on the throttle lock tensioning device on the bottom of the throttle housing. It the thumb screw on the bottom of the throttle that you can turn to lock the throttle in a particular location or put a resistance on the throttle. It holds enough tension on the screw to keep it from turning and falling out.
Good Luck
Steve
Apr 03, 2011 | Harley Davidson XLH Sportster 883...
It runs wide open all the time im wondering where idler arm setting is at
It sounds like the govenor spring has become disconnected or the clamp on the governor shaft has become loose and allowed the linkage to get out of adjustment. If problem has occurred suddenly it could mean the governor gear assembly inside the engine has broken and means the engine will need to be dismantrel to replace the governor gear assembly.
Check throttle linkage to see if spring is attached at both ends, one end on the throttle linkage and the other at the fixed point on the engine or to the end of the speed control lever. With engine stopped the spring should hold the throttle wide open and hand pressure on the linkage shoud be all that is needed to move throttle shaft closed to the idle position with no binding in the movement of the linkage.
If spring is OK and while engine is running, linkage should be able to be be moved to bring engine back to idle. If porblem has occurred gradually, then linkage will need re-adjusting. Loosen adjusting clamp on governor shaft, then holding linkage in wide open throttle position rotate shaft as far as it will go in the opposite direction to that requred to close throttle to idle . Re-tighten clamp.
Dec 11, 2010 | Coleman Powermate Premium Plus 6250W...
How do I replace the starter pull rope on TB70SS?
You must first remove the shaft assembly by removing the Torx/Flathead screws that hold on the trigger. Then you remove 3 screws that hold the engine to the shaft. Next you can remove the shaft assembly and you will see 4 or so screws holding the black surround around the clutch. You need to remove this to get to the pullstarter. Once you get to the pullstarter make sure not to release the coiled spring or you'll have a hell of a time putting it back in. Typically that are behind the pullstarter assembly.
Aug 15, 2010 | Troy Bilt Tb70ss Gas Trimmer
I took apart my new stihl ms 210 the throttle assembly anyway, where does the black wire connect to? there is a red wire connecting to a metal bracket that is coming from the same hole the black one is i...
On the Master Control Lever, you will notice a round reciever on the left side of the lever shaft. This holds the round terminal of the black wire in place. As the lever is rotated upward, the shaft brings the terminal of the black wire into contact with the flat brass spring (which belongs ON TOP of the lever shaft) and thereby stops the engine.
If the throttle trigger is pulled each time the lever is set to choke, this will never again be an issue. However, if the lever is pushed all the way down to choke and the throttle trigger isn't pulled, the linkage will malfunction again.
ALWAYS pull the throttle trigger before you set the choke.
Hope this helps,
Dolf-
Oct 14, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Husqvarna 365 order to install trigger, throttle catch and spring
Here's a link to the husky parts list.
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
Mar 23, 2009 | Husqvarna Garden
Ryobi ZRRY26500 26-cc 17-in Curve Shaft Gas Trimmer Logo
37 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
