Question about Toshiba estudio 305 Copier
There no mentusb2.o in the directory - Toshiba estudio 305 Copier
  • Toshiba Master
  • 1,087 Answers
"Store the update program loader (mentusb2.o) in the root directory, and store" Is that the directory you mean? The 'root directory' is a computer term Maybe goto here:
http://fyi.toshiba.com:81/KB/file_uploads/7802/es455-manual-update-instructions.pdf
Posted on Apr 22, 2014
In vista how to use the del command
open a dos prompt.
to make a directory type md "name of directory"
to remove a directory type rd "name of directory"
to change from one to another type cd "name of directory"
to go up one directory type cd..
to change drives type cd drive letter
All commands are typed without quotes
Mar 20, 2014 | Microsoft Windows Vista Home Premium with...
Can you retreive the last number of a person calling you
Using the Call Log or Directories
You can make a call with the call log or directories as follows:
Outgoing Call Log
Incoming Call Log
Extension Number Directory
System Speed Dialing Directory
Personal Speed Dialing Directory
Calling with a call log or directory
While on-hook
>Press Left or Right
until desired log/
directory appears.
>Press ENTER.
>Press Up or Down until
desired item appears.
>Off-hook
To cancel or exit, press cancel or exit.
Clearing the log information
>While confirming the log information
>Press "CLEAR".
Storing the caller's information for the Personal Speed Dialing Directory
>Press Up or
Down until
desired item
appears.
>Press STORE or
ENTER.
>Press STORE or
ENTER.
>Press "EXIT" or
PAUSE.
To enter characters, refer to "Entering Characters".
Apr 15, 2011 | Panasonic KX-T7630 Corded Phone
Cannot find directory in commamd prompt
you want to open commamd prompt? press start+R and type cmd
Oct 26, 2010 | Computers & Internet
How do i restore the directory
If you want to restore the directory hierarchy that contains the examples and sample programs that shipped with the calculator
  • Press [alpha][alpha] to lock the alphabetical keyboard.
  • Press [TEACH] then [ENTER).
  • The programs and examples will be restored.
If you want to create a directory (from scratch)
  1. Press [Right Shift Cyan key] and [HOME] to get back to the main directory.
  2. Press [Right Shift Cyan key] [VARS] to access (MEMORY) management
  3. Press the [D:New] tab
  4. The new variable screen opens
  5. Use the DownArrow twice to move cursor to the third line (_Directory)
  6. Press [C:Chk] to put a Check mark to the left of Directory
  7. The screen will change to show [Name and Directory]
  8. Use Up Arrow to move cursor to the first line (Name)
  9. Press [A:edit]
  10. Enter the name and then press [F:OK]
Once the directory is created you can use the Memory management to copy OR Move objects from other directories to the new one.
May 10, 2010 | HP 48gx Calculator
In RPL mode, put the object on the stack. Enter the name you want for the directory (must not conflict with an existing object) between ticks and press STO.
Mar 18, 2010 | HP 48gx Calculator
Clue finders math adventures says cannot creat directory
I found the answer to this problem. The problem is the install tries to write to files in the c:\Documents and Settings\All Users\Documents directory. For some reason, that directory had lost the ownership. Try searching for "my documents access denied". For XP home, I had to boot in safe mode, then take ownership of the directory. Once I did this, the install could write to the directory and it installed!
Apr 21, 2009 | Learning Company, Inc. Clue Finders Math...
How do I enable the company directory on the NorStar Meridian M7310 phone?
When you add a voicemail there is an option for DIRECTORY, say YES and that will set up a directory.
Feb 18, 2009 | NorStar Meridian M7310 Phone
DNS
DNS is the primary name resolution service for Windows Server 2003. Active Directory depends on DNS for domain controller location, and DNS influences Active Directory domain naming. Thus, to fully understand Active Directory, it helps to understand how DNS acts as an integral component in the design of Active Directory.
DNS provides Active Directory with both a name resolution service for domain controller location and a hierarchical design that Active Directory leverages to provide a naming convention that can reflect organizational structure.
Typically, a DNS domain namespace deployed to accommodate the Active Directory mirrors the Active Directory domain namespace. In cases where there is an existing DNS namespace prior to Active Directory deployment, the DNS namespace is typically partitioned for Active Directory, and a DNS subdomain and delegation for the Active Directory forest root is created. Additional DNS domain names are then added for each Active Directory child domain.
DNS data is used to support the location of Active Directory domain controllers also. During or after the creation of the DNS zones used to support Active Directory domains, the zones are populated with DNS resource records that enable network hosts and services to locate Active Directory domain controllers.
PS: As sourced from Microsoft Technet Site
Jul 24, 2008 | Microsoft Windows Server Standard 2003 for...
Active directory
An application directory partition is represented by a domainDNS object with an instanceType attribute value of DS_INSTANCETYPE_IS_NC_HEAD combined with DS_INSTANCETYPE_NC_IS_WRITEABLE. This domainDNS object represents the application directory partition root (NC head), and is named similar to a regular domain partition, for example, "DC=dynamicdata,DC=fabrikam,DC=com", which corresponds to a DNS name of "dynamicdata.fabrikam.com". An application directory partition can, therefore, be instantiated anywhere a domain partition can be instantiated. There is no NetBIOS name associated with an application directory partition.
It is possible to nest application directory partitions, that is, an application directory partition can have child application directory partitions. Searches with subtree scope rooted at an application directory partition head will generate continuation references to the child application directory partitions.
An application directory partition replica can only be created on a domain controller that is running on Windows Server 2003 and later and only while the Domain-Naming FSMO role is held by a Windows Server 2003 and later domain controller. In a mixed forest that has both Windows Server 2003 domain controllers and down-level domain controllers (Windows 2000 domain controllers or Windows NT 4.0 primary domain controllers), an attempt to create an application directory partition replica on a down-level domain controller will fail.
An application directory partition also has a corresponding crossRef object in the Partitions container of the configuration partition. The crossRef can be pre-created manually before creating the domainDNS object. The pre-created crossRef object must have the attribute values shown in the following table or the partition creation will fail. If the crossRef object does not exist, the Active Directory server will create one when the application directory partition is created.
Jul 09, 2008 | Microsoft Windows Server Standard 2003 for...
Regarding ActiveDirectory Services in Windows system
Active Directory (AD) is a technology created by Microsoft that provides a variety of network services, including: using the same database, for use primarily in Windows environments. Active Directory also allows administrators to assign policies, deploy software, and apply critical updates to an organization. Active Directory stores information and settings in a central database. Active Directory networks can vary from a small installation with a few hundred objects, to a large installation with millions of objects (though not easily [3]).
Active Directory was previewed in 1996, released first with Windows 2000 Server edition, and revised to extend functionality and improve administration in Windows Server 2003. Additional improvements were made in both Windows Server 2003 R2 and Windows Server 2008.
Active Directory was called NTDS (NT Directory Service) in older Microsoft documents. This name can still be seen in some AD binaries.
There is a common misconception that Active Directory provides software distribution. Software distribution is run by a separate service that uses additional proprietary schema attributes that work in conjunction with the LDAP protocol. Active Directory does not automate software distribution, but provides a mechanism by which other services can provide software distribution.
Jul 01, 2008 | Microsoft Windows Server Standard 2003 for...
Toshiba estudio 305 Copier Logo
342 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
