Question about Dito Dean Food Prep BKP-440 Bermixer Handheld Blender
Frozen shaft bermixer model 103 - Dito Dean Food Prep BKP-440 Bermixer Handheld Blender
How can I find a new Bamix old model spice blender/chopper
Bar mix products made millions for world wide sales
kitchen aids that change design so often
they cant support a large parts division
(R&D is geared to sell the next better barmix product )
if you cannot find a new old part
or super ceeded shaft from the next model up
or used drive shaft for sale online
look for a complete used bar mix spice blender/chopper
some people collect barmix units for a hobby or collection
and sell double ups
when you say old model
if the shaft is plastic ....... its .unfix able
its a heat molded construction process
Vintage Bamix M122 2-Speed Hand Held Food Blender Mixer-Chopper
Sep 16, 2016 | Bamix Blenders
Kitchenaid mixing shaft falls out w/ use
If it is model 5KPM5 then there is a pin through the shaft inside the planetary that engages the pinion gear. There is a circlip above the gear clipped to the shaft that holds the gear into engagement with the pin. I've not seen one drop the shaft out in my life, the circlip would need to pop off & the gear would need to jump up and then the pin would need to slide out. All the bits would be there inside the planetary waiting for you to discover them.
Nov 16, 2012 | KitchenAid Professional 600 6 Qt. Stand...
Shaft does not turn still vibrates
Same happened on mine. It is a M100. I pulled off the blade and guard (screws off the opposite way to normal), lifted the black rubber seal on the shaft as far out of the way as I could and cleaned it out. I then put a little WD-40 down the shaft and waited a while and twisted the shaft a little with pliers to work in the WD-40. After a few minutes it ran and fairly quickly came up to full speed.
Nov 08, 2009 | Bamix Deluxe Handheld Blender
Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
<span
Lo siento si mi español es malo - Yo uso un traductor. Contacto Dito Dean y debe ser capaz de conseguir un manual. Número de teléfono Dito Dean debe estar en la propia máquina. Por lo general, será sellado en la parte posterior o inferior. Buena suerte! :)
Aug 27, 2009 | Dito Dean Food Prep BKP-350 Bermixer...
Whisk blade on BAMIX hand-held blender is frozen!
try to gently twist the blade up and around the shaft with a pair of pliers. I've loosened mine by pushing and pulling on the blade with the pliers. be sure to use caution so as not to wreck the blade.
Mar 17, 2009 | Bamix Mono Single-Speed Handheld Blender
Bamix stick blender Handle vibrates but shaft does not turn
Old food residue and juices will have got into the shaft bearings, and have dried out enough in 9 years to stop it turning. Starting with the simplest solution, try immersing the shaft in hot, or even boiling, water nearly up to the top of the metal shaft. CAUTION - DON'T BURN YOURSELF! Let it stand in the water for a few hours, and then try turning the shaft by hand (with the machine unplugged, of course). This could be repeated a number of times. You may also be able to unscrew the blade guard after this treatment, bear in mind it has a left hand thread, so if you are looking at it from the bottom, turn it clockwise to loosen. Be careful not to lose any seals or springs when it comes off.
If this doesn't work, support the Bamix upside down, and pour a small amount of WD-40 into the blade guard, so that it pools around the end of the shaft. Leave to stand, and the oil should slowly seep into the bearings, dissolving the food residues. Again, try this a few times.
If neither of these work, the Bamix will need to be dismantled to clean the shaft and bearings. This is really beyond the scope of this forum and requires some experience of this type of work.
Mar 13, 2009 | Blenders
Philips Hand blender
My wife picked ours up at a rummage sale, and we've grown to love the little thing for making single servings of banana milk shake. (half a frozen banana, cover with milk, a drop of vanilla, and about one minute with the hand blender blade!) When my youngest boys dropped ours, I gathered up the pieces of plastic that connect the attachments to the motor shaft, and carefully super glued them together. I then wrapped the plastic piece with fine nylon thread and a thin layer of super glue and placed it back onto the motor shaft, then let it sit for 24 hours. It is now permanently attached to the motor shaft and good to go. Too bad Philips doesn't care enough to support their customers with a part their engineers designed to break and save the rest of the product. I'll remember this about Philips products when I buy an HDTV.
Aug 14, 2008 | Philips HR1358 Handheld Blender
Dito Dean Food Prep BKP-440 Bermixer Handheld Blender Logo
304 people viewed this question
Top Dito Dean Food Prep Blenders Experts
eyecam
Marvin
Marvin
Ross Keen
Are you a Dito Dean Food Prep Blender Expert? Answer questions, earn points and help others
