Question about Refrigerators
Have a frigadaire SxS Model FPH52386LF2 won't defrost cannot locate defrost control board
  • 50 Answers
Most likely not board needs defrost terminator/thermostat.
control board is underneath.
Posted on May 04, 2014
4 Suggested Answers
SOURCE: I need to replace the adaptive Defrost Control
Its Located in the top right inside corner of the refrigerator section near the back wall & to the right of the water filter.Its tough to get out but only takes about 10 minutes to replace the part
Posted on Nov 19, 2009
Testimonial: "great help"
aasc
  • 1606 Answers
SOURCE: Where is defrost timer in maytag MSD2756GEQ SxS
Inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control
Posted on Jun 13, 2010
2coolrick
  • 560 Answers
SOURCE: Refrigerator does not cool. Coil
. Look inside the freezer compartment for your circulation fan . This fan should run when the unit is in a normal operation mode. You should be able to hear it running making a whirring sound when you open the freezer door . If you do not hear it running , replace it . If the fan it's OK then your problem is going to be in the defrost control circuit or associated components .
Posted on Feb 23, 2011
DEFROST TIME CLOCK GE GSH25J, WHERE IS IT LOCATED?
Hello:
Your model does not have defrost timer, instead the defrost is controlled by Main control board located on the back of the fridge..
Part # WR55X10942
PS.. Most common defrost problem on this model is not the board. Its either defrost heater or defrost thermostat..
Jul 15, 2017 | GE Refrigerators
Where is defrost timer location on fridgedaire mod # ED25DQXVN00
Your mechanical defrost clock timer is located in the control panel where the rotary knobs are for the ED25 model given which is a Whirlpool SxS, For the Frigidaire Mod FRS, your defrost control will most likely be located in the long housing running down the center wall (front to back) of the fridge near the outlet vent, this is an electronic adaptive defrost control. Pleazer Appliance...
Apr 18, 2014 | Frigidaire FRS26KR4A Side by Side...
How can I manually set the defrost timer on my Kenmore 596 series refrigerator?
If the defrost timer is a control board, then you won't be able to manually set it, get the model number from inside the refrigerator and go to www.partselect.com and there you will be able to get a full illustrated blow out of the machine and locate the part your looking for
Sep 05, 2012 | Kenmore Refrigerators
How to remove defrost timer
need complete model # to give correct help but most kenmore sxs ref / the defrost timer is located in the control panel . two screws to remove an un plug it .. reverse to install .. some older models are locaded behind the toe grill . same two screws.. mm
Oct 23, 2010 | Kenmore 52282 / 52284 Side by Side...
Jun 13, 2010 | Maytag MSD2758G Side by Side Refrigerator
Not cooling/freezing good
sounds like a defrost problem. defrost system consists of defrost timer or defrost control board,defrost heater,and defrost thermostat. most maytag sxs refrigerators have a circuit board in charge. part no.61005988 adc board.change the board and yer in business...
Jan 11, 2010 | Maytag Refrigerators
Freezer works but refridgerator does not . light works and coil fan woks
Since you did not mention the manufacturer breand, or if it is a top freezer/ bottom food section, or if it's a sxs- I can only give you some general diagnosis:
Top freezer model and sxs
1. Are your controls in the proper setting?
1. Check to see if there is any "snow formation" on the evaporator cover. If yes, then you most likely have a defrost issue
2. Is defrost drain clogged ( top freezer model). If defrost drain is clogged then water can "spew" over into air diffuser and cause an airflow issue
3. Make surer you are getting air flow into the food section i.e. the fan in the freezer blows the freezer air into the food section. You might havve an air difuuser that is not opening
Affordable Appliance Repair
(949) 855-0788
Jun 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
How do I force a defrost on a ge sxs gss20iepcww It is not a touch pad control ref. It has 2 knobs
on all ge electronic models produced since 2000 the main power lead to the main board can be jumped to test either defrost or compressor operation.to do this unplug the unit and locate the 3 wire plug (usually blue in color) .unplug the harness from the board and create a jumper wire to by pass the board.the terminals on the board will be identified as line,compressor and heater.to put unit in defrost install jumper between line and htr or def .this will ck the defrost sys.once unit is plugged in with jumper in place the heater will come on.if the heater does not come on look for a defective heater or defrost t/stat.hope this helps.
Jun 03, 2009 | GE Refrigerators
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
