Question about Troy Garden
Troy bilt 17.5 hp Pony Riding Mower,only works in fourth Gear
The belt was new,broke in less than fifteen minutes.When I brought the mower from service center,I noticed that only fourth gear would work.I could move the gear shifter to the eight speed position no difference,I lowered the deck to mow and engine stalled.I as all my power equipment,I had a hobs meter installed at new purchase.The mower only has 31.6 hours! I have had four belts installed since new 2008.The repair technician said that a lot of Troy Bilt Ponys had numerous problems related to my situation.Any suggestions and a how to instructions,will be very appreciated.The authorized repair center ,told me it would cost me about another $200.00 to access the problem.By profession I am a Airline pilot.I understand the necessity of regular maintenance Has there been any recalls of this matter? Thank You.Terrence Latronis
  • 711 Answers
The bearings may be bad and freezing up, this will cause the belt to smoke and tear up as well as make the pulley wobble . Does it smell like burning rubber ?? If not then you have a pulley out of line and or a pulley that's cracked or broken. Also check and make sure the deck pins are all in place and the locks are down on the quick release on front and side of deck. While the blades are disengaged turn all the blade hubs (shaft spindles) and pulleys to see if the turn fairly easy. Check for play or wobble in the pulleys and blade hubs (shaft spindles), bearings and blade shaft attach to these pulleys. Also check the idler pulley(also called the tensioner pulley for wear and check to see that they are in alignment with each other). It may be a bad transmission shifter plate bearing. Check out this link for diagrams of your unit. Hope this helps, plese post solved on fixya.com.So I get credit more info.for a solved problem if it does. If not, check back and give me
Troy Bilt Parts
Posted on Apr 24, 2014
rtpflh
  • 546 Answers
SOURCE: I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Posted on Sep 28, 2009
  • 153 Answers
SOURCE: can i get a diagram
without more information i can only give you a link.http://www.troybilt.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10001&catalogId=14102&langId=-1#Error
if this dose not help please contact me back with more info like model, make, year and I will do better.
Posted on Jun 05, 2011
intower18
  • 957 Answers
SOURCE: I threw the drive belt
I had found a site where you can download the schematic diagram of your device so that you can install the belt. Just click_here so that you will re-directed to the exact site.By the way, you have lots of options to that site, just select the best for your concern.
Thanks.
Posted on Sep 13, 2011
SOURCE: I need to replace the drive belt on a Troy-Bilt 16S riding mower with a 42" blade deck and I do not have a model# or serial# on the mower (label under seat apparently came off at some point before I i
Lowes or Menards sell troybuilt they may be able too hook you right up.
Posted on May 05, 2012
  • 6468 Answers
SOURCE: Troy bilt riding mower will not move fwd in gear
check the linkage adjustment
Posted on May 21, 2012
Troy Bilt Mustang XP mower belt diagram
https://www.partstree.com/parts/troy-bilt/mowers-zero-turn-lawn-mower/17wfcacp011-troy-bilt-50-mustang-xp-zero-turn-mower-2013/mower-deck/
Aug 27, 2014 | Troy Garden
Mower belt diagram
Try Goggle it. belt diagram troy -----
Aug 03, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Mower slips in and out of forward gear but rides perfect in reverse;What do I need to adjust?
Reverse is a different gear set than forward gears. Sounds like forward gear set has a broken tooth. Not an easy fix.
Jul 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a troy bilt 17.5 hp pony riding manual lawnmower and my belt located above the deck keep jumping off track after engaging the blades a couple of times,do i need to tighte my belt,if so how?
Those units are self adjusting. No way to adjust it. It sounds like you have a bad idler pulley or a bad spindle bearings, which would cause the pulleys to be out of alignment.
Sep 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Need belt diagram for Troy bilt Pony. The drive belt just broke and I need to 1, buy one and 2, replace.
hi im having trouble on my troy belt riding mower it is a 42 inch im tring to change the belt we have it on but it not right please help me
May 15, 2010 | Troy-Bilt Pony Garden Tiller
Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Nov 30, 2009 | Mtd Garden
    Had to change the small drive belt that drives the transmission on a Troy-Bilt 42'' 17.5 HP Pony mower. Now it only has one speed forward, slow!! Didn't touch anything-got the OEM belt replacement. Any...
    You need to adjust the gas pedal. Info should be in the owners manual. I have it in my Troy Bilt Bronco manual. It say to adjust it in my book after replacing the trans drive belt. Maybe that will help.
    Aug 17, 2009 | Garden
    Troy bilt pony riding mower will go in reverse but grinds in forward where do i start
    have a troy-bilt riding mower. place a gear in neutral and park it.
    it dies instead idling. want to know why?
    Jul 17, 2009 | Garden
    Garden Logo
    98 people viewed this question
    Top Troy Garden Experts
    Jim Parker
    Jim Parker
    Matt Olenzek
    Matt Olenzek
    DROPNDEAL
    DROPNDEAL
    Are you a Troy Garden Expert? Answer questions, earn points and help others
