Question about Toshiba 32AV635DB 32-Inch Lcd Tv Dvb-t Freeview Hd Ready 1366x768
Wont star just red light no clicking
Fuse are ok led green on in the control board
    Top Expert:
  • Toshiba Master
  • 74,136 Answers
Sounds like main board fault. Contact the authorized service center for Toshiba. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on Apr 22, 2014
No stop key indication and treadmill wont power on
Check the 2 fuses under the motor shroud. One should be a 10 Amp fuse, the other should be a 15 Amp fuse.
Is the red LED lit? If not, check outlet, check power cord for treadmill. With cord unplugged, check the connections on the motor control board for the AC input, which are marked AC1 and AC2.Plug cord back into the wall outlet, and check voltage at those terminals- it should be 90 volts or higher.
If those check out- replace Motor Control Board,
Dec 31, 2011 | Startrac Fitness Products Star Trac 4500...
Dell1110 Laser Printer. Changed Cartridge - New Fuse - Checked twice Simpson 260 No blown fuses on circuit board. (1) Fuse, (2) wire. No burn spots Red & Green lights blink after 10 sec of OR/GR...
If you have flashing RED and GREEN LEDs on your Dell 1110 your printer will need servicing by the Dell service department. It is hard to say what is wrong without looking at the printer in person but those two lights together spell trouble not easily fixed. It could be a damaged circuit board or component. This typically has nothing to do with ink, paper jams, etc.
Regards, Chris
Aug 17, 2011 | Dell 1110 Laser Printer
I have a Bowflex TC1000 that will not start. The console powers up, the red light on the power switch lights up and the green led and red led on the controler board are lit. A/C voltage to board is 120...
Check to make sure the yellow safety key is securely inserted into the console. If not, the control board will not send power to the motor. If this does not resolve the issue, check connections and continuity of wiring from console to control board.
Apr 20, 2011 | Bowflex TC1000 Treadclimber
Turn on benq pb6200 with new bulb all I get is humming and no led
same problem here. checked fuse, mainboard seems ok. nothing looked blown.
Jul 15, 2010 | BenQ PB6200 Multimedia Projector
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
No picture or sound
Remove the rear panel. With the TV on you should see a red LED near the center of the PCB. There should also be 5 green leds, 3 to the left a 2 behind. If there is no red leds, check the fuses. If there are no green leds or maybe 1 or 2, disconect PSD5. It's a connector on the left side of the power board that connects to the audio board. It's the 3rd on fro the back. It's labled. With that disconected, turn on the set and look for the green leds. If all 5 light, the power supply is OK and you have a problem beyond that. If they don't all light you have a bad power supply.
Jul 21, 2008 | Hitachi 50EX20B 50" Rear Projection...
Star deep fryer
FIRST THING I WOULD DO IS CHECK THAT THE MAINS RED LED IS LIGHTING IF NOT CHECK THE FUSE IN THE PLUG IF IT IS BLOWN THEN YOU WOULD HAVE TO LOOK AT THE ELEMENT AND CHECK IT FOR RESITANCE ABOUT 100 OHMS NOT A DEAD SHORT IF THIS IS OK THAN CHECK IF THERE IS A FUSABLE FUSE OR THE THERMOSTAT CONTROL MAKE SURE THAT YOU CAN HEAR IT CLICKING WHEN TURNING THE DIAL IF THERE IS NO SOUND YOU CAN ADJUST IT OR REPLACE IT
Jul 16, 2008 | Star 530FD Deep Fryer
Sony FWD-42PV1 -
I diagnosed the same problem on my FWD-42pv1 as a problem on the Y-SUS board. The fuse on that board was blown, and the board itself was bad (replacing the fuse was not enough to fix it). The symptoms were exactly the same - the LED cycling red/green, and then finally stuck at red.
With a new Y-SUS board, the TV has been working fine for a couple months.
Jan 26, 2008 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
No power up, 53udx10b. rear projection
You could replace C603 first and if this doe not do it then S901 maybe bad.
Sep 24, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Wont power on
Needs Convergence amps replaced. Also fuses around this board are out. There should be small pico-fuses open around this board(replace)
Aug 26, 2007 | Hitachi 55FX48B 55" Rear Projection...
Toshiba 32AV635DB 32-Inch Lcd Tv Dvb-t Freeview Hd Ready 1366x768 Logo
61 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
