Question about Frigidaire Washing Machines
Water collects in tub when not in use - Frigidaire Washing Machines
  • Frigidaire Master
  • 5,323 Answers
A SIGN OF A BAD WATER INLET VALVE
Posted on Mar 31, 2015
3 Suggested Answers
SOURCE: water collects in tub
called for a under warranty repair on my Whirlpool GHW9400PW4
Posted on Jun 29, 2008
canbruce75
  • 1776 Answers
SOURCE: water appears to collect in the tub when the machine is not in us
This is caused by a faulty inlet valve solenoid. It is allowing water to run into the tub. The solenoids can be tested using a multimeter for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve will need replaced. See the attached photo for reference. Hope this helped and best wishes.
Posted on Aug 03, 2009
Ice Maker leaks water into the ice collection tub.
The ice maker is not metering the water correctly and it will need to be replaced. Here is the part to order.
Jul 06, 2013 | Frigidaire FRS26R4A Side by Side...
WATER WILL NOT PUMP OUT OF MACHINE
Here are some solutions for GE built dishwasher when water will not pump out of machine:
During the wash and rinse modes of the cycle, soiled water falls down the back of the tub and into the filter area. The water comes through the filter and back into the tub. During the wash and rinse periods all ( we hope! ) the water will pass through the filter. The soil will settle into the collection chamber and is held there. When the dishwasher goes into the pump out mode the water in the sump is pumped through the collection chamber. This closes the piston valve to the inside of the tub. The pump flushes the collection chamber of all the food soil and pumps it down the drain. A check valve is located in the drain line port. This valve allows the water to flow in the drain direction only and prevents the water from coming back into the tub. The drain line check valve must close in the back flow direction or the piston valve in the collection chamber may not reopen into the tub after the pump out is complete. Water should "fall" through the filter and go back into the tub....the heavier food particles go down into the chamber and are collected.
Jun 10, 2011 | GE 24 in. GSD3960LSS Stainless Steel...
The dehumidifier will run, but will not collect any moisture from the air. The screen has been cleaned, the tub is cleaned, but no water will collect.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 07, 2010 | Haier HD456 Dehumidifier
Water appears to collect in the tub when the machine is not in us
Aug 03, 2009 | Washing Machines
Water and odor collecting in our empty dishwasher after 4-5 days
A small amount of water may be normal.  Clean the filter at the bottom of the tub.  Sprinkle some baking soda inside between washes.
Jun 02, 2009 | Dishwashers
Delta tub tap only cold water no hot water or pressure for shower.
take handle off and adjust the nylon set ring it is to prevent kids from getting burned and is probably set wrong youll see teeth and a pointer just pull it out a little and turn it in the oppisite direction then push back in
May 09, 2009 | Delta Faucet Company Classic Collection...
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Will not drain
GE dishwashers will have a sump entrance screen ( #4 ) that should be removed and checked for any gookus, see 1 or 2 screws on the cover top, which is behind the lower spray arm. Almost all ( some newer GE dishwashers have a separate drain pump and motor - but for our purpose, we will talk about the most common GE dishwashers ) GE dishwashers have a drain solenoid ( #1 ) that can fail and stop the draining. If the solenoid cannot pull in the silver plunger, the drain port will not open to allow the motor and pump assembly to drain the water out. The solenoid can be ohmed with an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GE dishwashers have a self clean filter ( #3 ) inside at the back. The draining water must pass through a plunger in the self clean filter body. This can get clogged up, or the plunger may twist and distort and not allow the draining water to get past. The filter can be removed from the inside and the plunger will twist out of the self cleaning body for testing/checking. Next obstacle for the draining water in the back flush valve ( #2 ). This valve can twist or distort and block the water flow as well. The drain port will need to be accessed to check this flapper valve, the drain port will untwist from the self clean filter body. All hoses in-between the items mentioned above and the drain hose itself all the way to the house plumbing should be checked for restrictions.
Some extra filter, draining tips and pictures....
Here is a link for you to check out...I have all this info in my data base but since it is in PDF format it does not translate well to this format...
http://www.applianceaid.com/gedishdrain.html
I hope this helps...good luck and ggod day...please rate my effort......thanks....The Fang.
Mar 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Yesterday i got tiling done and lo here is the problem
Dont pay mason and have it redone to give proper slope to drain.
Jan 12, 2009 | Plumbing
Jun 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
