Question about Kenmore Dishwashers
WON'T END WASH CYCLE/KEEPS ON RUNNUNG..IS THERE A CODE FOR THIS
CLEAN LITE WASH FLASHING/PUSHED NORMAL WASH/HEATED DRY 5 TIMES AND IT STARTE WORKING---BUT NOW IT JUST KEEPS ON RUNNING--IS THERE A CODE TO FIX THIS?
  • Kenmore Master
  • 3,247 Answers
If you cannot cancel the cycle then turn power off and back on.
Then try to program a short cycle from panel and see if it works.
I am assuming when you say that it keeps running you mean the water keeps churning and does not drain out.
If short cycle works ok then the dishwasher is not heating water to the correct temperature. Need to check thermostat or heater.
Posted on Apr 23, 2014
Amigaman
  • 248 Answers
SOURCE: 665.17019401 - Kenmore diswasher
It indicates a water temp problem. If water temp doesn't rise at a certain rate, by the heater, it goes into this error. Probably a problem with heater or wires to it.
Posted on Nov 22, 2007
  • 1003 Answers
SOURCE: Kenmore 587 High Temp/Heat Dry lights flashing, cycle not complete
REPLACE TIMER
Posted on Jan 18, 2008
johnychel
  • 796 Answers
SOURCE: dishwasher not running
hello sir.....
is the Start/Resume indicator flashing?
Opening the door or interrupting the power stopped the cycle. Close the door and press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
may be the motor has stopped due to an overload....as you have mentioned...many of the buttons were pressed...
The motor automatically resets itself within a few minutes. If it does not restart, call for service.
In Canada, call 1-800-807-6777, or your nearest designated
service center.
In USA ..Call the Whirlpool Customer eXperience Center
toll free: 1-800-253-1301.
If you need further assistance, you can write to us with any
questions or concerns at:
Customer Interaction Centre
Whirlpool Canada LP
1901 Minnesota Court
Mississauga, Ontario L5N 3A7
Posted on Feb 25, 2008
  • 338 Answers
SOURCE: Clean light keeps blinking and I can't start a new cycle
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
Posted on Nov 25, 2008
jsrock516
  • 5911 Answers
SOURCE: clean lite keeps flashing and will not start a new
This may or may not help in your situation, but the following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Aug 20, 2009
Kitchenaid dishwasher kuds30ivwh3 start light blinking. Dishwasher won't start.
Press these keys :
Heated Dry----> Normal-----> Heated Dry-----> Normal
All the l.e.d.s should lite up and then, if you push start, it will go from function to function. push the button 8 or 9 times, then
Reset the power to the unit via the circuit break, then run a normal wash cycle and see if it completes...
Nov 20, 2016 | KitchenAid Dishwashers
Why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
Rick
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Nov 17, 2011 | Maytag Dishwashers
Normal wash lite flashing
Hi, try pushing Normal Wash - Heated Dry - Normal Wash - Heated Dry. This should enter the diagnostics cycle and reset any faults. If it will not reset or enter the diagnostics cycle then the door latch assembly must not be engaging when you close it. You will need to check the door latch to make sure that the switches are engaging. If they are not, you will need to replace the door latch switch assembly.
Jun 27, 2011 | Kenmore Dishwashers
THE FOLLOWING BUTTONS WERE DEPRESSED.......NORMAL WASH, HEATED DRY AND LOCK ON......ALL THESE BUTTONS HAVE A STEADY LITE.....THE START/RESUME BUTTON LITE IS FLASHING. IHAVE HELD THE START/RESUME BUTTON...
Hi
Press and hold the NORMAL WASH-HEATED DRY button simultaneously & repeat this sequence for 5 times...this will reset the control. Hope this helps...please post back for further assistance.
Daniel
Jan 21, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Clean light flashes 7 times and will not run wash cycle I have replaced heat element
big guy this happened to me the other day do this it will reset computer you ready hit these buttons heated dry normal heated dry its a code all lites will then come on that resets computer
Aug 23, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Clean lite keeps flashing will not start whenstart
The thermistor beneath the accumulator inside the sump detects the water temperature as it begins the first 8 minutes of the main wash cycle. During this time, the controller expects the thermistor to detect the 2-4 degrees rise in the water temperature when the first 8 minutes is completed. If the expected temperature rise is not met, the controller will not be satisfied. It will shut the dishwasher down and blink the clean light 7 times. Press the heated dry then normal wash buttons in the same sequence two times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button. It will clear the fault and makes the dishwasher normal but will appear again if you have problem in either of the following:
  1. Heater and its circuitry
  2. Water filling
  3. Pumping motor
If the heater is not working, the water temperature will not rise then controller will shutdown the machine.
If there's no water entering the machine, no water will be heated and there's no way the controller through the thermistor can detect any rise in temperature.
If the pumping motor is not working, the water cannot circulate over the heater and be heated. Again, the controller will not be satisfied.
You can bypass this fault detection feature by filling the machine with either extremely cold or extremely hot water. Water colder than 62 or hotter than 160 degrees Fahrenheit will make the controller not to check for a temperature rise but rather continue on the next cycle.
Please let me know if the problem still bother you.
Dec 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Nov 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
E-2 error code on whirlpool duet dryer
“E2” flashes if the thermistor has shorted.
The thermistor monitors the exhaust temperature
and cycles the high-limit thermostat on
and off to maintain the desired temperature.
1. Turn the dryer off but keep the electrical
supply connected.
2. Make sure that the dryer is empty and that
the lint screen is clean.
3. Close the dryer door.
4. Select Heavy Duty, Timed Dry, More Time
or Less Time, End of Cycle Signal (Louder)
and Start.
5. If error codes E1 or E2 flash on the display
after 1 minute and the dryer turns off,
the thermistor, or the wire harness, is either
shorted or open. Check the wire connections
at the thermistor or the machine
control electronics board. If wiring checks
okay, replace the thermistor.
6. If the dryer seems to operate normally, remove
the exhaust vent and start the dryer.
7. Select the desired temperature cycle to be
tested, and select 20 minutes of Timed Dry
heat using the More Time or Less Time
pushbuttons.
Feb 25, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Whirlpool 24 in. DU1055XTP Built-in Dishwasher
I don't know if your dishwasher is the same as mine, but this solution may be what you need. For electronic panel dishwashers made by whirlpool (mine is a whirlpool but with a kenmore name on it), some of them can be reset by pushing in sequence the Heated-Dry button followed by the Normal-Wash button, several times in a row. that is... Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up. When all lights light up you can stop. The washer will then take 5-10 minutes to go through a diagnostics cycle, which is about 18-25 steps or so. You can bypass one step at a time by pushing the STart button. This may not apply to your washer, but is pure gold if it does. Good Luck!
May 26, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwashers Logo
144 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
