Toshiba 32av635d wont star just red led no cliking
    Master:
  • 687 Answers
Most likely Main or Power supply PCB. I find that this model does not match American or European listings so I am not able to locate the correct part #s & pricing for you.
measure the voltages from the power supply, if all are present then the main pcb is the issue.
Posted on May 09, 2014
Wont star just red light no clicking
Sounds like main board fault. Contact the authorized service center for Toshiba. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 22, 2014 | Toshiba 32AV635DB 32-Inch Lcd Tv Dvb-t...
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
Red led blinking. tv wont turn on model number
Hi Rick,
First of all, thank you for posting your question here at Fixya.
My first advice is to unplug the unit from the outlet at least 30 minutes to reset itself and check if the symptoms still persists. If yes, may I know if it encountered before then there's some instances that the unit will power up after a few minutes of pressing the power button key?
Also, please double check the model number of your unit, if I'm not mistaken, it is 50H81 not 50H87.
Jdvillanueva
Jan 21, 2012 | Toshiba Televison & Video
My blackberry curve red LED light wont stop flashing even if i dont have a notification.
f you set Repeat Notification to NONE in your Profiles, you won't get the LED flashing. Do that for EACH message type in your active profile, as well as in and out of holster settings.
The Messages > Options > General Options > Display New Message Indicator setting refers to the "star" that appears on the folder when new mail arrives.
Mar 11, 2011 | RIM BlackBerry Bold Smartphone
I'm having trouble with my Toshiba 42HL196 TV. It won't power on. There is a flashing red light on front. I've read the manual and done everything it suggests with no success. I've checked inside the tv...
SYMPTOM: Won't turn on or intermittently won't turn on, Red LED Flashes.
CAUSE: Loss of Main Switched Power Sources. Standby power is OK.
SOLUTION: Replace Regulator IC Q820 with Toshiba Part # 23135094
Jan 18, 2011 | Toshiba 42HL196 42 in. LCD HDTV
How do i take the stand off a toshiba 32AV635D to wall mount ?
On my 32AV635D there are 4 Allen bolts in recessed holes on the back cover. Remove these (but no others!) and the stand just slides out. Under the base of the stand there are two more Allen bolts which fix the metal brackets to the stand. Removing these will enable you to pack the whole thing into its original box (which you kept) so you can put it on Ebay when you get a bigger model :-)
Sep 16, 2010 | Toshiba Televison & Video
We have a 32av635d toshiba regza television and can't find the aerial slot... Please help! (:
the slot is on the left hand side of tv not in the back or front. its on the side. its the same color as the plastic and sometimes it has a door in front of the input
Nov 09, 2009 | Toshiba Televison & Video
Toshiba 50" cinema series
Try to unplug and replug back the power cord of the
tv and turn it on again. Sometime this work.
Sep 09, 2007 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
