Question about Sony MHCGZR888D MINI HIFI WITH 7 INCH LCD SCREEN-PAL/NTSC FOR 110-240 VOLTS
MECHA error when i turn on mecha error appear on screen then turn off
  • 3 Answers
SOURCE: shelf cds is blocked SONY CMT-HP7
To get the cds to play, and 5 to eject, you can try taking off the sides of the consul and using compressed air. As for the shelf problem, I'm not really sure.
Posted on Jan 19, 2008
SOURCE: "mecha error"?
i've dismantled my system found the top fuse had blown on the transformer also aligned the cd tray all works sweet now wahoo :)
Posted on May 29, 2008
SOURCE: despLady
HEY! This worked for me. I turned off the stereo, turned it back on, reset it to factory settings and popped out the disc changer. Then I rotated the cd changer with my hand. It started moving the cds by itself back and forth. It is now able to play cds.
Posted on Oct 09, 2008
SOURCE: sony up-dr 100 error 0007
This may well be a failure of the cutter switch sensor to reset. This worked for me.
Turn Off the Printer.
Remove both side panels and the plastic panel on the INSIDE of the DOOR on the right hand side. Then close the door and remove the plastic panel UNDER the door. This is held in place by two screws.
You will see a white gear on the bottom right hand side of the door. It is on the underside of the door. Turn this gear untill you can see the cutter move smoothly across the bottm of the door and return to the right side of the door. Listen for a click. This is the switch resetting. Close the door and power up the printer if you still get an error code 0008 or 0007 repeat the resetting process by turning the gear. BE SURE TO TURN OFF THE PRINTER!!
Posted on Aug 11, 2009
sparky1500
  • 1066 Answers
SOURCE: my cd player is saying
mechanical error. a moving part is either broke or physically jammed. remove the cover (dont touch anything inside) and look for broken or jammed pieces, ssuch as gears or belts.
do not get your hopes up- you will probably not be able to fix it, and it will probably be too expensive to pay a professional to do it for you. the player is probably trashed.
Posted on Nov 06, 2010
Mecha errror what is the problem of my sonny mini-hifi components when i turn on mecha error appear on the screen then turn off itself
It's a Sony problem, I hate to say. My amp does the same thing. Check your speaker wires for a short, if no short, then the auto protection circuit in your Sony is shot - mine was too, and it costs a fortune to fix it - cheaper to buy another one, I hate to say.
Apr 22, 2014 | Sony Audio Players & Recorders
How to fix mecha error on sony mhc-gx555
https://us.en.kb.sony.com/app/answers/detail/a_id/38877/~/the-stereo-system-malfunctions,-stops-responding,-or-displays-mecha-or
Jan 09, 2012 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Displaying an error message "mecha
http://www.fixya.com/support/t4093524-onkyo_dvd_changer_display_reads_mecha
http://www.fixya.com/support/t1119443-onkyo_dv0_cp702_error_mecha_err
These may help you.
May 07, 2011 | Onkyo DV-CP702 DVD Player
Me presenta mecha error 12 que sera por favor ayuda gracias
mecha error 11 o 12 significa k algo pasa con la cuchilla, debes de desarmar la impresora y ver si hay algo que la este trabando
Jul 09, 2010 | Kodak 6800 Thermal Photo Printer
MECHA ERROR 003
i need best solution for mecha error 03 kodak printer 6800
Mar 15, 2010 | Kodak 6800 Thermal Photo Printer
Mecha error
it says there is a mechanical error meaning that there is an internal part no longer functioning yo need a radio
Aug 20, 2009 | 2009 Hyundai Sonata
Kodak printer 6800 mecha error 11
this is error created at ur printers cuter unit , so open the frot cover and clean the all 3 sensors
Jul 03, 2009 | Kodak 6800 Thermal Photo Printer
Mecha error o3
Mecha error 03 is a malfunction of the main pinch motor. Ninety-Five percent of the time the problem is that the motor has failed. The machine will more than likely have to be sent in for maintenance.
Nov 27, 2008 | Kodak 6800 Thermal Photo Printer
Mecha Error 0005
oooohhhh k
1) when you turn the printer on does the printer make a lot a noise and then display "ready"
-If not there may be mechanical issues with your printer
Nov 13, 2008 | Sony UP DR100 Thermal Photo Printer
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
Sony MHCGZR888D MINI HIFI WITH 7 INCH LCD SCREEN-PAL/NTSC FOR 110-240 VOLTS Logo
23 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
