Question about HP Office Equipment & Supplies
Hp cp 1415n colour run - HP Office Equipment & Supplies
How do I fix 58.04 Error on CP 4525
Hi chifundo mtambalika,
I would be happy to help you with your CP4525. I understand you are seeing error 58.04. I found something you may find helpful, please use the following link to take a look:
cp4525 error 58 04
I hope this helps.
I work on behalf of HP.
Jul 03, 2015 | HP COLOUR LASERJET CP4525DN Printer
Hp 1415
EROR COOL-DOWN MODE PRINTER HP 1415
Nov 16, 2011 | Office Equipment & Supplies
Hp laser jet cp3505 printing only black and white pages.not printing colour
Its mechanical mis alignment problem,remove main motor assm which is located right side,you will find out four gear wheels row enguaged with other gears.. Upper 1st gear drives the mono catridge, remain three ment for colour catridge drive. Open this mechanism & absorve that each gear having align markings marking.If this alignment got distrubed you will get quality issue. Its very easy to understand to match each gear, take help of service manual suits clj 3600,3800. Try it...if fails try it up to sucess.... Best of luck..Vinay.
Sep 05, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
HP colour laser jet CP2025. Prints colour on test sheet but not from pc. It was printing colour until wireless was installed - is there a connection?
Your driver is not sending color data. Either your driver is set to print in geayscale, or you are printing through a monochrome driver to the IP address of the CP 2025
Jun 30, 2011 | HP Laserjet Cp2025n Printer
Am confused,i want to buy a colour laserjet printer and left with only two options which one should i buy btn hp1600 and cp1525
hiii
Its depends on your printing needs.Printing quality almost same these two printers. If u buy hp 1600 u will get more pages than cp 1525.But u should think about the toner cost. Check your local market price for each toners.Here i will give u the toner model numbers for ur required printers.
hp 1600 - q6000- black,q6001,q6002,q6003 each three colours.- Page yield 2500 pages for black ,2000 pages each colours.
hp cp1525- ce-320a(128a),ce321,ce322,ce323- Page yield -2000 pages for black,1300 each colour pages.
So I am sure hp 1600 toner very costly than 1525 toner.If u dont have huge volume printing better i suggest u buy cp 1525 model.Also this model offering wirless printing .
U can refill this toners lowest cost and getting good results.
sooooooo cheeeeeeers up........select your new printer. best wishes..........
Jun 14, 2011 | HP Color LaserJet 2600n Printer
Hey! I have just installed my HP Colour LaserJet CP 1215 Printer to my Laptop which is istalled Window 7. However, the printing speed is too slow . How can i fix it? I 'll appreciate your help.
We have found this is in some cases and the solution that seems to work best is to download the HP Universal Print driver and install it instead of the driver that comes with the printer.
May 19, 2011 | HP LaserJet CP1215 Color Printer
My printer is hp laserjet cp 1515n. After printing some documents it writes "printing cool down mode" and begins working very slowly. Please help me
1515n - I have the Magenta colour 'shadowing' the blue test. A mirror image of the blue text. [slightly staggered] Black is fine. Applies to all Word docs when printing in blue - can you help please?
I only use genuine cartridges.
Thanks
Jules Radstock
Jul 23, 2010 | HP LaserJet CP1518 Printer
Ghosting when using HP CP2025N
Bad drum unit poor fusing or paper type try to print paper type cardstock as type, this increases fuser temp and slows printer for better quality.
-Carl, please let me know if this helps.
Jun 25, 2009 | HP Laserjet Cp2025n Printer
23 people viewed this question
Seeker5211
Seeker5211
