Question about Brother MFC-J4510DW All-in-One Inkjet Printer 35 PPM, 6000x1200 DPI, Color, 128 MB, Wi-Fi, PC/Mac
Faded print - Brother MFC-J4510DW All-in-One Inkjet Printer 35 PPM, 6000x1200 DPI, Color, 128 MB, Wi-Fi, PC/Mac
  • Brother Master
  • 783 Answers
Clean the corona wire again using a q-tip moistened lightly with water or glass cleaner. Try carefully shaking the new toner cartridge back and forth to evenly distribute the toner inside the cartridge.
Wipe the scanner window (inside the machine close to where the drum rotates) clean with a soft, lint-free cloth. See page 74 of the user manual.
Power down the printer and clean all silver contacts on the toner cartridge, drum cartridge, and corresponding contacts inside the printer body.
Re-seat all components ensuring the drum cartridge is fully inserted and try printing again.
Here is a link to your user manual Page 91 for troubleshooting image problems. http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Posted on Apr 22, 2014
Yellow ink faded on one side of copy
Ink News - How To Correct Faded Prints From Toner ...
www.inkpal.com/ink.../tips-to-correct-faded-prints-from-toner-cartridges...
Rating: 3 - ‎12 votes
Mar 30, 2012 - You should particularly suspect this if the prints are faded on only one side and if the printer is not telling you to replace the toner cartridge.Missing: yellow
HP Officejet 6500 Printers - Fixing Print Quality Problems ...
support.hp.com/us-en/document/c01641184
Jan 16, 2016 | Office Equipment & Supplies
Print is fading from receit
Welcome to the real world. Fading receipt print is chronic. In this high-technology world, the only reason I can think of for using that fading, heat-produced print is to rip off the customer.
*No returns or warranty without receipt*. Months later you manage to find your receipt but it's so faded it's unreadable. A lot of good it does you but it sure helps out unscrupulous retailers.
There needs to be a law that receipts last ten years...
Apr 18, 2015 | Office Equipment & Supplies
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
My CP1515n colour laser is giving faded colours.The left side of the print is very faded whereas the rest of the print is slightly faded
There are two reasons for faded prints. Firstly, faded print could be due to exhausting toner.
If it you have faded prints even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust/ toner dust accumulated at the laser reflecting mirrors inside the printers,
which partially blocks laser beams and requires cleaning/ servicing by a professional.
Hence, it is recommended that you get the printer checked/ serviced from authorized service center.
Hope it helps! Good Luck!
CreativeTECH
Feb 26, 2011 | HP LaserJet CP1515n Printer
I have a HP 7590 printer and it sometimes skips line or some of the lines are faded when printing black .
Perform the following steps to reduce or eliminate faded or grainy lines:
  1. Print at a higher quality setting.
  2. Verify that the paper you are printing on will lay flat. Paper that is not laying flat can cause banding when the paper transitions over the rollers or cause the print cartridges to scrape across the surface of the page. Check the top sheet of paper by removing it from the all-in-one and placing it on a flat surface. If the paper does not lie flat, bend it in the opposite direction to straighten it. Figure 3: Faded or grainy bands in print caused by paper that is not flatc00178858.gif 1 - Faded or grainy bands due to roller transition with paper that is not flat. 2 - Faded or grainy bands due to print cartridge scrape on paper that is not flat
Jan 06, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
Sir ihave printing problem when i print a page on the left side margin impression faded there is some faded portion of teflon roller crieate this problem please assist me how to solve this problem ...
sir ihave printing problem when i print a page on the left & right side margin impression faded please assist me how to solve this problem regards KULDEEP SINGH BISHT
Aug 09, 2010 | HP LaserJet 1020 Printer
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Brother MFC-J4510DW All-in-One Inkjet Printer 35 PPM, 6000x1200 DPI, Color, 128 MB, Wi-Fi, PC/Mac Logo
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
