Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
No Audio and Video
TV won't show picture and the Power lights On.Anyone can help me fix this problem.
    Top Expert:
  • Sharp Master
  • 74,468 Answers
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Posted on Apr 22, 2014
2 Suggested Answers
  • 8457 Answers
SOURCE: TV won't show picture the
The main tv Tuner signal board have problems or it is dying or might be dead already.But sometimes this tv will still work and can be used,i have the same tv have the same problems it work for me all the times.By doing this process.Everytimes Power and OPC lights blinks.Just push the remote power switch again for tv to repower the tv power and OPC lights again,have go thought this process pushing power remote switch again have to do this like 3 or 4 times sometimes before the tv to work.Tries websites like Shopjimmy.com or Ebay.com to buy a whole new refurbish main tv Tuner signal board for the replacement.
Posted on Jul 30, 2011
Vizio P42 HDTV no picture
Try first unplugging power cable for thirty minutes, then plug back, this will drain power from TV completely and will reset it.
See if it works.
Oct 18, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
TV Problem: No Video but Audio works
Here are some basic treatment for a dark display.
  1. On LCD TV, Some time missing or lose LCD strip from PCB connector. Solution- Clean strip and connector.
  2. Some time missing LAMP, burning lamp is a major cause for dark display in LCD TV. If lamp problem with any display, Display show in sun lights. Solution- Check Lamp connection/connector. Clean connector or change Lamp.
  3. In CRT TV, Fly back is faulted. There are no high voltages. Solution- Change or check fly back, Check out put transistor.
  4. Some OLED Tv Use OLED lights for display shining and brightness. IF LED's or lamps are faulted there is no display in sun shine.
  5. Before starting Troubleshoot display problem you need to conform and trace faulted stage of TV.
  6. Don't Apply any miss use trick at home. Contact the professional repairing lab.
  7. If you are full fault to understand your TV problem. Tip more condition of your problem.
Jul 02, 2015 | Element Televison & Video
Vizio TV won't work. We get sound but picture is like distorted and now it won't show video
There are lots of common problems with flat screens that result in those symptoms. Some fixes are super easy and cost $.35 haha and others can cost hundreds not to mention if your doing it your self or not factor in labor. Lots of people sell tv s like that from $50 to $100 bucks and they sell quick! Hell I'd buy it if I had the chance. Could use parts or god forbid find an easy solution ( rare :( )
Mar 13, 2013 | Televison & Video
Ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
No picture, no sound
The green steady power light is a good thing, how old is the TV?
If you are routing your audio and video through the audio receiver, make sure that the inputs are correct on the display of the receiver, ie. IF you are planning to watch your DVR and it is hooked up on Component 1 for video and Coaxial 1 for audio, make sure that the receiver is still programmed for this in the input of TV/Video 1 or whatever the input. I have ran into this on countless occasions, simple fix, but a headache until it is tracked down. Double check the connection to the TV as well.
Nov 25, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Zenith Projection Tv Set Model number ZB4685T no Visual
Since this is a CRT based set, there could be a number of problems. What exactly do you mean when you say that the picture fades? Do you loose contrast and the picture gets lighter? or does the picture darken toward black?
Parts are still available, so this can be fixed. If youfeel you want to attempt this yourself, please supply additional info and we'll walk down the diagnosis path.
Dan
Aug 08, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Sony KV-36XBR250 - no picture, good sound
This is a common failure mode (which I now share), and has nothing to do with the picture tube or surge protection. From the forums I have searched to-date, it appears to be a failed component in the flyback circuitry, but Sony will not admit to an inherent defect. If anyone has ACTUALLY FIXED this problem, please post a reply. Guessing won't help anyone. Thanks.
Oct 24, 2006 | Sony KV-36XBR250 TV
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
16 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
