Question about Braun Impression KF 600 Coffee Maker
My KF 600 started leaking water all over the counter before it starts brewing, can't open it, can i fix on my own
Can it be repaired
2 Suggested Answers
SOURCE: Braun KF 600
I am thinking about purchasing this model; so I am very interested in your report.
We are replacing a Braun KF 145 that's about 8 yrs old.
We had a similar problem that was solved by taking care with the coffee filter basket. Always close the basket firmly in place before you place the carafe in position. The overflow problem only occurred when we placed the carafe first and then closed the filter basket.
Maybe the same mechanics apply with the KF600.
Reed
Posted on Feb 04, 2009
It leaks water under the right side of the brew basket.
Leaks water when brewing ground coffee with a My K-Cup ...
https://www.ifixit.com/.../Leaks+water+when+brewing+ground+cof...
iFixitWhen I use the My K-Cup filter to add my own ground coffee and brew it, after it ... the machine starts leaking water at the same time, so typically the mug beneath the ... in the lid that has the needle opening in it (half sphere perforated basket below it). ... thewater could simply flow over the coffee, and go right down the sides.
Stop Leaks - www.My-Cap.com © 2015
www.my-cap.com/stop-leaks.html
Jan 01, 2016 | Coffee Makers & Espresso Machines
Cuisinart DGB coffeemaker
Does the water leak out before or after the brew? Can you leave water in it without starting a brew cycle, or does that leak as well?
Jul 21, 2008 | Coffee Makers & Espresso Machines
After it is done grinding and starts to brew it leaks coffee all over my counter. I have tried stopping it after the grind turning off the grind and just brew and putting it on strong and less cups. But...
Try taking the lid to the carafe and soaking in vinegar/ water. Then use as strong a jet of water as you can get from your faucet to blast the crud out from the chamber in the lid. You'll have to try different angles, they did not make that part easy to clean. (I have the same one). Also try taking the grinding basket lid and separate the 2 halves, they just click together and make sure nothing is stuck in there. Good luck!
Mar 01, 2011 | Cuisinart DGB900BCU Grind and Brew 12Cup...
Saeco Vienna machine...after brewing a couple of cups of coffee, water leaks from somewhere and comes out underneath the front grilled tray and onto the counter. Can I do the repair with the proper parts?
Depending on your ability to do some technical and minutious manual work, unmounting and remounting the machine is feasable.
Concerning the leaking, what I've seen most is a leak from the seal under the water tank. Any leaks coming form there would occur even though no coffee would be dispensed. (i.e: Idle mode)
If leak is ONLY occurring when brewing cofee, I would check the following:
1- Check if the water inlet on the back of the brew unit is filled with residue (the inlet looks like the end of a smoke pipe)
2-Open the machine, take out the interior, and verify the water tubes coming in and out of the boiler. They both should be sealed with 2 small o-rings. After time, o-ring tend to expand under heat and may start to leak.
Hope this helps
Feb 27, 2011 | Saeco Vienna De Luxe Espresso Machine
DCC 2400 COFFEMAKER LEAKS CONSTANTLY. ALL OVER THE COUNTER. HAVE CLEANED IT. IS IT FIXABLE SHOULD I TRASH IT?
I had this problem.
The Fix:
There is a valve in the centre of the carafe lid (If you shake the lid you can hear the valve rattle). This valve becomes gummed up with heavy coffee oils over time and sticks causing part of your brew to pour onto your counter. The fix is to simply clean the oil out of this valve. I cleaned mine by soaking it overnight in a water/bleach solution then blasting hot water into it. You can clean it more thoroughly if you pop off the bottom lid part that extends into the pot. It is a snap fit. Before you take it off note the orientation.
On my lid this valve was coated in heavy, greasy coffee oils. After this cleaning your pot should not leak when brewing.
Another problem is the stiffness of the lid making it sometimes very difficult to open and close and if not fully closed coffee will leak while pouring. This o-ring binds against the carafe. To fix this, locate the 'O' ring in that same part the extends into the carafe on the bottom of the lid. put a drop or two of vegetable oil on your finger and apply a thin film around this ring once every three weeks or so. Your lid will open and close smoothly and beautifully.
Happy brewing!
Feb 22, 2011 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee in Cuisinart grind and brew ends up all over counter
once and a while the filter door will come ajar and make the coffee leak all over. (allways try to jigle it open after closing, because fine grounds will make the door not close right) Also if the carafe is not in all the way you'll geta mess too!
Jun 29, 2009 | Cuisinart Thermal DGB-600 Grinder
The machine leaks water all over the counter when starting brew
My keurig did the same thing, the rubber grommet around the part that punctures the cup gets grounds on it and prevents a complete seal. Pop of the grommet and clean it and it will be good as new.
Mar 14, 2009 | Keurig B70 Coffee Maker
Braun coffee maker starts brewing, then stops after a few seconds
ijustam1
I have the same machine, Braun KF180 12 Cup Coffee Maker. In normal operation the brew cycle is stopped when the water reservoir is empty. The only way the coffee maker knows if that is true is when the water-brewing heater gets too hot. Your brewing heater is probably encrusted with calcium deposits if you have been heavily using the coffee maker. Vinegar will work but it is weak and you will have to cycle this solution through many many times. You should instead use "Lime Away" or "CLR" and let it sit there in a brew cycle or multiple brew cycles for a while. NOTE: Remove the filter when cleaning this way and when the brew cycle is complete, rinse thoroughly -- your taste buds will let you know if the machine is not rinsed thoroughly. -- Good Luck!!
Jan 22, 2009 | Braun FlavorSelect KF 180 Coffee Maker
Braun KF 600
Reed
Mar 28, 2008 | Braun Impression KF 600 Coffee Maker
DGB-600 will not brew
The unit has either wiring connection problem internally or the internal motor is blown, it can only be found once the appliance is opened.
Dec 12, 2007 | Cuisinart DGB-600 Coffee Maker
Braun Impression KF 600 Coffee Maker Logo
37 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
