Question about RCA RS1289 5-Cd Changer Mini Systemwith Surround Sound Speakers Shelf System
Good day am Aword Stephen and i have a RCA 5 disc changer that some one give to me wheni open the set i discovered that there is no power ic in it ,so am asking please it you all can give me the numb
I am a technician and i try to put in one tda2009a and there is only current in the set but not lighting up,,there are other ic i have that can fit,,all of them is TDAs power/audio ics but i don't know the right one please help me
  • AWORD STEPHENS
    AWORD STEPHENS Apr 24, 2014
    the set came with out the ic it is a (11) eleven pin ic 6 in the front and 5 in the behind
    Problem Solver:
  • 15 Answers
RCA RS2650 51 Service Manual free download schematics eeprom repair info...
Hi, go to the above site and you can download the service manual where you will find the IC you need, you have to sign up first before you can download. Best of luck.
Posted on Mar 10, 2015
SOURCE: stereo won't read cds
You might try running a cleaning CD in it (which cleans the lazer lens). These are available from Wal Mart and many other sources. If a cleaning doesn't get it going, then you may have a lazer that is weakening and might need to be replaced (sorry!). Hope just a good lens cleaning will do the trick.
Posted on Jan 10, 2007
SOURCE: rca compact stereo rs2657 cd door won't open
Mine was doing the same thing so I unplugged it and took the left side panel off to see what was wrong with it. I did this by removing the 2 screws on the left and the 3 on the back left side also.There was a cd stuck in it. It took some fenangling but I got it out and it works fine now. I know, I know. We as lay people are not supposed to do these things but it was out of warranty and would have cost me as much to have it repaired as to buy a new one. Good luck!
Posted on Dec 26, 2007
shaggyrat
  • 1224 Answers
SOURCE: Bought a display model RCA RS2657 5-Disc CD Changer Bookshelf Audio System
order from remotes plus or order from rca themselves
if system is aloted a universal remote should be able to control the system with little or no hasle
Posted on May 09, 2008
alfredo_krau
  • 62 Answers
SOURCE: my 5 disc rca changer is not reading the disc
Try to clean laser lens with CD cleaning disc. If it not helps, then Your lens must to be replaced.
Posted on Sep 06, 2009
  • 277 Answers
SOURCE: rca rs2653 a disc with no scratches will skip, tried cleaning
its the disktry the rubbers mite be worn
Posted on Dec 11, 2009
RCA 5 disc changer tray want open
It will be due to the end of the player
Aug 20, 2016 | RCA RP8078 5-Disc CD Changer
Won't play any disc on any of the 5 slots boom box also has casette player that records
Laser is either dirty, so a lense cleaning disc required. Or the cd transport is kaput. Uneconomical to repair if this is the case
Apr 11, 2014 | RCA RP8085 5-Disc CD Changer
My RCA RTD 206 5 disc changer wont play DVD's. It stays on Disc 3 or just says close. I called the # in the manual foe help, but its no longer in service.
If it plays the same disc without issues, you have a mechanical(or the electronics powering the motors and such) problem. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 20, 2013 | Audio Players & Recorders
Rca 5 disc changer
What model RCA changer?
Jul 19, 2013 | Audio Players & Recorders
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
My RCA 5 Disc changer (RP-8065) won't open.
Try to download the service manual to your set from net. It will have all details.
May 22, 2012 | Audio Players & Recorders
The unit seems to have power and makes 'start up' nouises. However, it will not change or recognise CD's. Is there a changer that could be stuck?
Look out for resetting the changer using the small hole in front panel.if this wont reset then try to remove power and switch on. if not remove the set and open the cover, slowly unwind the load motor to release the cd into the slot and eject. there after try to load for testing. if not check for failure of the load motor, connection of the motor line, failue of the motor drive link or slipping of the drive gears. check for the drive IC of the loading motor also. I hope this would solve. Good day
Jun 30, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
I have got a rca 5 disc changer rp 8055c it want play my cd
RCA 5 DISK CD PLAYER AND RADIO CANT HERE MUSIC LIGHTS COME ON CD PLAYS BUT NO SOUND.
HELP
Aug 16, 2009 | RCA RP8078 5-Disc CD Changer
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
