Linear algebra's problem
5x1 + 6x2 - 2x3 + 7x4 +4x5 = 0, 2x1 + 3x2 - x3 + 4x4 + 2x5=0, 7x1 + 9x2 -3x3 + 5x4 + 6x5=0, 5x1 +9x2 - 3x3 + x4 + 6x5 =0
  • Akarys Turganbekuly
    Akarys Turganbekuly Apr 22, 2014
    Find general solution of the given system of liner equation. Write general solution in terms of fundamental set of solution. What are the dimension and basis of Null space for a given system? 5x1 + 6x2 - 2x3 + 7x4 +4x5 = 0, 2x1 + 3x2 - x3 + 4x4 + 2x5=0, 7x1 + 9x2 -3x3 + 5x4 + 6x5=0, 5x1 +9x2 - 3x3 + x4 + 6x5 =0
2 Suggested Answers
NJFIRESTORM
  • 84 Answers
SOURCE: algebra college
Consider the following system of 3 equations in 3 unknowns:
x + y = 2
2x + 3y + z = 4
x + 2y + 2z = 6Our goal is to transform this system into an equivalent system from which it is easy to find the solutions. We now do this step by step.
  • Subtract 2*(Row1) from Row2 and place the result in the second row; subtract Row1 from Row2 and place in the third row. Leave Row1 as is.
x + y = 2
y + z = 0
y + 2z = 4
  • Subtract Row2 from Row3, and place the result in row3. Leave Row1 and Row2 as they are.
    x + y = 2
    y + z = 0
    z = 4 From the last form of the system we can deduce the following unique solution to the system:
z = 4, y = -4, and x = 2-(-4) = 6Equivalently, we say that the unique solution to this system is (x, y, z) = (6, -4, 4).
Posted on Sep 17, 2008
Is there a function for Linear Interpolation, if so, where do I find it? Thanks!
Sorry, I don't have that calculator, but let's see if we can work this out. "Linear Interpolation" means find the value of y for a given value of x from a line of best fit, within the range of values that you are given.
Hopefully, this helps. If not, let me know and we will explore more.
Good luck,
Paul
Apr 22, 2015 | Casio Algebra FX 2.0 Calculator
How to do gauss jordan
You should consult a Linear Algebra book. Besides, these calculator cannot handle matrices of dimensions 4x4 or higher . With matrices of dimension 3x3 and less it is probably easier to use the Cramer rules directly.
Nov 06, 2012 | Texas Instruments TI-30 XIIS Calculator
Edit Casio FX - 9860G SD have complex equations??
Thhe Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Apparently it will take coefficients that are real, and will give a Ma Error if any coefficient is complex.
Addendum.
The calculator CANNOT solve equations with complex coefficient. YOU can however convert the system of linear equations with ccomplex coefficients ( of the type you show) as a system of 4 linear equations in 4 unknowns; Split x into a real and an imaginary part, split y into a real and an imaginary part. Substitute Real(x)+iIm(x) for variable x in the equations; substitute Real(y)+iIm(y) for y in the two equations; do the algebra. In each of the original equations split the Real and imaginary parts. You should be able to derive 4 linear equations in unknowns Real(x), Im(x), Real(y), and Im(y).
Use the linear equation solver to obtain the solutions. Recompose x=Real(x)+iIm(x), and y=Real(y)+iIm(y)
Alternatively, after you create the system of 4 linear equations you can use the matrix utility to find Real(x), Im(x), Real(y) and Im(y) and recompose the x and y.
Mar 17, 2012 | Casio FX-9860G Graphic Calculator
Casio FX - 9860G SD have complex equations?? edit
The Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Addendum.
Mar 17, 2012 | Casio Office Equipment & Supplies
How do i calculate limits on my Casio fx-115es? Ex. lim x->3 for (x2'-0)/x-3
Sorry, but you cannot calculate limits of functions with this calculator. It does not have a Computer `Algebra System (CAS). For that you need a graphing calculator with CAS: Casio ClassPad 300, 300PLUS, 330, HP 48 GII, HP49 G/ G+, HP 50G, TI-NSPIRE CAS, TI89 Titanium, TI 92/92PLUS, TI Voyage 200 PLT. It is still a very good scientific (non graphing) calculator
However, you can calculate numerical derivatives, and numerical integrals, solve linear and non-linear equations.
Even though this post does meet your expectations, do not let that prevent you from rating it.
Jan 21, 2010 | Casio FX-115ES Scientific Calculator
Writing linear equations
Assuming that band A charges a flat price, their price would simply be
A = 600
Band B's price would be
B = 350 + 1.25X
where X = number of tickets sold.
Set them equal and solve for X to figure the break-even point:
600 = 350 + 1.25X
250/1.25 = X
X = 200
If you have fewer than 200 people, Band B is the better deal; more than 200, you're better off with Band A.
Dec 18, 2009 | SoftMath Algebrator - Algebra Homework...
Linear equation examples
  1. x - 4 = 10
  2. 2x - 4 = 10
  3. 5x - 6 = 3x - 8
  6. 2(3x - 7) + 4 (3 x + 2) = 6 (5 x + 9 ) + 3
Oct 16, 2009 | SoftMath Algebrator - Algebra Homework...
How do i show mapping diagram for algebra for these examples
if you x and y concepts in problem then try to form one equation such as in linear or quadratic or your choice and make sure of x and y concepts in algrebra as x and y co -ordinate directions in graph
Oct 04, 2009 | SoftMath Algebrator - Algebra Homework...
16 people viewed this question
jasbo
jasbo
