Question about Jaguar 1998 XJ8 Base
VVT code P1396
Engine code P1396, VVT, after changing timing chains and tensioners on a 98 Jaguar XJ8 base model. Variable Valve Timing code has become problematic. I've tested all the connectors and the solenoids, triple checked the timing and torn everything back down to chain replacement a second time with the same result. There was no code before the chains were done. I've followed advice from other forums and done everything they said to check and I can't work out the VVT issue.
4 Suggested Answers
  • 3 Answers
SOURCE: 1998 jaguar xj8 timing chain
http://jeg.serverhouse.com/Jag_docs/Timingchain.pdf
Here it will show how to do the job step by step.
dssossg@aol.com
Posted on May 12, 2009
  • 3 Answers
SOURCE: timing chain replacement
Here it will show you step by step on how to do the job.
dssossg@aol.com
  • 14036 Answers
SOURCE: Jaguar xj8 2001 just completed timing chain &
DID YOU RECONNECT IGNITION COILS AND THE VARIABLE VALVE TIMING SOLENOIDS.CHECK SPARK PLUGS IF YOU GETTING SPARK AT SPARK PLUGS.MORE LIKELY VALVE TIMING OFF.
Posted on Jul 04, 2011
2005 jaguar s type gearbox fault light. Code read p1396
p1396 is a engine managment code. variable valve timing solenoid b malfunction, not a gearbox code. you really need to take your car to someone with access to suitable diagnostic equipment to help sort this problem out, hope this helps,
Aug 02, 2015 | Jaguar Cars & Trucks
P0022 for 2004 toyota sienna van
P0022 Toyota - Camshaft Position \'A\' Timing Over-Retarded Bank 2
Possible causes
- Dirty Oil
- Faulty variable valve timing (VVT)
- Faulty oil control valve (OCV)
- Variable Valve Timing (VVT) harness is open or shorted
- Oil Control Valve (OCV) circuit is open or shorted
- Damaged Engine Control Module (ECM)
Tech notes
If the engine oil is clean and the VVT and OCV circuits are OK, replaced the VVT to resolve the problem.
When is the code detected?
After the ECM sends the target duty cycle signal to the OCV, the ECM monitors the OCV current to establish an actual duty cycle. The ECM determines the existence of a malfunction and sets the DTC when the actual duty cycle ratio varies from the target duty cycle ratio.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Lack/Loss of power
- Engine rough idle
P0022 Toyota Description
The Engine Control Module (ECM) controls the Oil Control Valve (OCV) to regulate the intake camshaft angle. As a result of the angle change, the engine timing is advance or retard. Optimizing engine timing will help the engine improve torque and fuel economy, and the exhaust emissions decrease under overall driving conditions. The Variable Valve Timing (VVT) system includes the Oil Control Valve (OCV) and VVT controller. The ECM detects the actual intake valve timing using signals from the camshaft and crankshaft position sensors, and performs feedback control.
Aug 14, 2014 | Cars & Trucks
What is code 1388 on a jaguar 2001 and how to fixit
this indicates a problem with the variable camshaft timing and possibly requires reprogramming PCM module
assume the engine warning light is on? does the engine run normal?
Jun 25, 2014 | 2001 Jaguar S-Type
The timing gear tensioner on my stype jaguar 2001 was replaced after the chain guides broke...a common failure for that year with plastic tensioners...would it not be a normal procedure to check or replace...
Failure to change your oil every 4,000 at most,
takes out VVT Actuators
When you do the guides you do the tensioners
Again no oil flow & gunked up
You can see the VVT on scan tool parameters & also
should mess with fuel trim data
If you change the upstream O2 Sensors at 100,000,
spark plugs every 3 years & clean the MAF you at least
have a clean start, with the exception of the cam & chain issues
Aug 31, 2013 | 2001 Jaguar S-Type
Error code p1384 and 1396
Hi there:DTC P1386 - VARIABLE CAM TIMING OVERADVANCED
Possible Causes:
- Bank 2 VVT solenoid valve to PCM PWM drive circuit fault.
- Bank 2 VVT actuator oil supply fault.
- Bank 2 VVT actuator stuck.
The biggest issues with vvts are oil supply issues. Useally debris like oil sludge in oil pickup screen, loose bearing clearances as an engine wears, and oil passages blocked/partially blocked to and in vvts. The first (i always shoot for cheapest potential likely fix) use a good engine flush(2 bottle for our higher than normal capacity engines) follow directions on bottle. Change oil and switch to a 20-50w. Leave out 1 quart and add 1 qt auto ****** atf(highly detergent, more so than engine oil and wont hurt anything) while you have overly ******** cam codes, it may be an issue of apply and blockage that keeps pressure in vvts too long when supposed to release. Most times its ******** cams( like the 1 i am doing right now....try this first and go from there, rememebr to clears codes and give time, you may have to clear codes a few times as it may continue to reset.
DTC P1396 - VVT Solenoid Malfunction - (B bank)
Check HERE a TSB about this faylkt code.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jul 13, 2012 | Jaguar XJ8 Cars & Trucks
Jaguar xj8 2001 just completed timing chain & tensioner replacement. engine cranks won't start, what is the best trouble shooting sequence to use?
Jul 04, 2011 | 1998 Jaguar XJ8L
Aligning the valve timing mareks except twincam engine
Timing Chain, Sprockets, Front Cover and Seal REMOVAL AND INSTALLATION Crankshaft Damper and Front Oil Seal
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Accessory drive belt
    • Cooling fans
    • Crankshaft pulley and damper, using a holding fixture as shown
    • Front crankshaft seal Fig. 1: Crankshaft pulley removal tool - V8 9301jg12.gif
    To install:
  3. Install oil seal replacer tool JD-235 to the oil seal. Use the nut and bolt provided with the tool to fully seat the seal to the timing cover.
  4. For dampers which DO NOT utilize a spit locking ring:
    1. Apply a thin, even coating of Loctite® 648 to the damper bore. Do not apply it to the end faces or to the crankshaft.
    2. Install the crankshaft damper onto the crankshaft. Wipe off any Loctite that has squeezed out from the front of the damper.
    3. Install the locking tool to the damper. Tighten the bolt to 59 ft. lbs. (80 Nm), plus an 80 degree turn.
  5. For dampers which utilize a spit locking ring:
    1. Install a new O-ring seal to the damper.
    2. Install the crankshaft damper.
    3. Apply petroleum jelly to the damper bore and O-ring seal.
    4. Install the damper onto the crankshaft.
    5. Install the split locking ring onto the crankshaft, inside the center bore of the damper.
    6. Install the locking tool to the damper.
    7. Tighten the damper bolt to 266-285 ft. lbs. (364-386 Nm).
    8. Remove the locking tool from the damper.
  6. Install or connect the following:
    • Cooling fans
  7. Start the engine and check for leaks.
Timing Cover
  2. Drain the cooling system.
  3. Remove or disconnect the following:
    • Upper radiator hose
    • Water pump pulley
    • Accessory drive belt tensioner
    • Idler pulley
    • Crankshaft damper
    • Engine appearance covers
    • Mass Air Flow (MAF) meter
    • Air intake assembly
    • Ignition coils
    • Canister purge valve
    • Valve covers
    • Variable Valve Timing (VVT) solenoids
    • Engine harness retaining clips
    • Timing cover
    To install: Fig. 2: Sealant application points - V8 9301jg23.gif
    Fig. 3: Timing cover torque sequence-V8 9307jg01.gif
  4. Apply sealant to the 8 joints on the engine face as shown.
  5. Install or connect the following:
    • Timing cover with new seals. Tighten the bolts in sequence to 96-120 inch lbs. (11-13 Nm).
    • VVT solenoids
    • Valve covers
    • Ignition coils
    • MAF meter
    • Crankshaft damper
    • Idler pulley
    • Water pump pulley
  6. Fill the cooling system.
Timing Chain 6 CYLINDER
    • Valve cover
    • Timing chain cover
    • Variable Valve Timing (VVT) sensor
    • Crankshaft Position (CKP) sensor
  3. Rotate the crankshaft until the triangular arrow indent on the driveplate is visible through the access hole.
  4. Install the Crankshaft Setting Peg JD 216 into the CKP sensor location.
  5. Install the Camshaft Locking tool JD 215 on the camshafts.
  6. Remove or disconnect the following:
    • Camshaft sprocket mounting bolt by loosening it
    • VVT mounting bolt by loosening it
    • Camshaft Locking tool JD 215
    • Primary timing chain tensioner and backing plate
    • Primary timing chain guide
    • VVT unit and exhaust camshaft sprocket
    • Secondary timing chain tensioner and guide
    NOTE: Keep all valvetrain components in order for assembly. To install:
  7. Prepare the timing chain tensioners for installation by using a paperclip or other wire to unseat the check valves and compressing the pistons into their bores.
  8. Install or connect the following:
    • Secondary timing chain guide. Tighten the bolt to 89-124 inch lbs. (10-14 Nm).
    • Secondary timing chain tensioner. Tighten the bolt to 89-124 inch lbs. (10-14 Nm).
    • VVT, secondary timing chain and exhaust cam sprocket
    • Primary timing chain guide. Tighten the bolt to 10-12 ft. lbs. (13-16 Nm).
    • Primary timing chain tensioner and backing plate. Tighten the bolts to 89-124 inch lbs. (10-14 Nm).
    • Primary timing chain slack, eliminate it by placing a wedge between the primary timing chain tensioner and the guide shoe
    • Secondary timing chain by applying counterclockwise force to the exhaust camshaft sprocket. Fig. 4: Apply force in a counterclockwise direction when tightening the sprocket mounting bolts - 6 cylinder 9301jg03.gif
    • Exhaust and intake VVT sprocket bolts. Tighten them to 85-92 ft. lbs. (115-125 Nm).
  9. Remove the tools and wedges.
  10. Install or connect the following:
    • CKP sensor
    • VVT sensor
    • Coolant outlet pipe
    • ECT sensor connector
    • Radiator and heater hoses
    • Valve cover
  11. Fill the cooling system.
  12. Start the engine and check for leaks.
Jan 28, 2011 | 1999 Jaguar XK8
I need to know how to set thte timing chain
Discoverd this indepth expalaination of process steps involved in the installation of the timing chain from an ASE certified technician. I hope this helps. See the repair manual on the link below.<br /> <br /> Link: <a href="http://www.2carpros.com/forum/2002-jaguar-xj8--gearbox-default-appear-on-dashboard/2000-jaguar-xj8-timing-chain-replacement-vt218070.html">http://www.2carpros.com/forum/2002-jaguar-xj8--gearbox-default-appear-on-dashboard/2000-jaguar-xj8-timing-chain-replacement-vt218070.html</a><br /> <table id="table14" style="BORDER-RIGHT: #000000 1px dashed; BORDER-TOP: #000000 1px dashed; BORDER-LEFT: #000000 1px dashed; BORDER-BOTTOM: #000000 1px dashed" bordercolordark="#000000" width="100%" bordercolorlight="#000000" border="0"> <tbody> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"><span class="name" roundtrip="0" lastvisited="3">By <a name="755408"></a><b roundtrip="0" lastvisited="0">Dave H</b>,<b> </b></span><span class="postdetails" roundtrip="0" lastvisited="0">Certified ASE Technician</span></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="100%" roundtrip="0" lastvisited="6"></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"></td></tr> <tr> <td style="BORDER-LEFT-WIDTH: 1px; BORDER-BOTTOM-WIDTH: 1px; BORDER-RIGHT-WIDTH: 1px"> </td> </tr> <tr> <td colspan="2"> <span class="postbody" roundtrip="0" lastvisited="77">PRIMARY TIMING CHAINS (NON-SUPERCHARGED) <br />NOTE:The 4.0L V8 has no engine timing alignment marks on the crankshaft or camshafts. Engine timing is achieved by installing the Crankshaft Setting Peg (303-531) and Camshaft Locking Tool (303-530). With the crankshaft setting peg in position, ensure the timing flat on each camshaft is in the uppermost position before installing camshaft locking tool. Variable camshaft timing unit may also be referred to as Variable Valve Timing (VVT) unit. <br /><br />NOTE:Special Tools Required: Crankshaft Setting Peg (303-531), Camshaft Locking Tool (303-530), Chain Tensioning Tool (303-532), Primary Chain Wedge (303-533) and Variable Camshaft Timing Oil Control Unit Setting Tool (303-654). See Fig. 232-Fig. 236 . <br /><br />NOTE:"A" bank refers to the right/passenger side of the vehicle and "B" bank refers to left/driver side of the vehicle. <br /><br />NOTE:Each door glass automatically drops 12 mm when the door is opened or when the convertible top is raised or lowered. It is important that windows are lowered before battery is disconnected to allow doors to shut properly. <br /><br />Removal ("A" Bank) <br />Tips Click a link to view tip <br />Tech1Tip: special tool <br /><br /><br />Remove timing cover. See TIMING CHAIN COVER (NON-SUPERCHARGED). <br />Remove the variable camshaft timing oil control solenoid. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Remove the variable camshaft timing oil control unit housing retaining bolts and remove the variable camshaft timing oil control unit housing. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Remove and discard the variable camshaft timing oil control unit housing "O" rings. <br />Raise and support vehicle. Remove the bolt which secures the Crankshaft Position (CKP) sensor to the flywheel housing. Remove the CKP sensor and allow it to hang free under the engine. Remove the torque converter bolts access grommet from the flywheel housing. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Install the crankshaft damper bolt (old one) to the crankshaft, hand-tight only. Rotate crankshaft until the triangular arrow indent on the flywheel is visible through the access hole. See Fig. 144. Confirm that the timing flat on each camshaft is uppermost position. <br />Position the crankshaft so that the Crankshaft Setting Peg (303-531) engages fully into the timing slot. Install and tighten the bolt to secure the crankshaft setting peg. See Fig. 145. Remove the crankshaft damper bolt from the crankshaft and lower the vehicle. <br />Install the Camshaft Locking Tool (303-530) to the "A" bank camshafts, aligning the shafts slightly as necessary. Loosen the bolt that secures the exhaust camshaft sprocket and the bolt that secures the variable camshaft timing oil control unit. See Fig. 146. Remove camshaft locking tool. <br />Remove the primary chain tensioner bolts, primary chain tensioner and tensioner backing plate. See Fig. 147. <br />Remove the primary timing chain tensioner pivot bolt and remove the primary timing chain tensioner blade. See Fig. 148. <br />Remove the bolt which secures the primary timing chain guide. Noting the position of the primary timing chain guide, remove the primary timing chain guide from the upper retaining pin. See Fig. 149. <br />Remove the primary timing chain from the variable camshaft timing oil control unit and from the crankshaft sprocket. Clean and inspect all components. <br />Installation <br />If "B" bank timing chain was removed, see INSTALLATION. If not, go to next step. <br />If previously removed, install the timing chain sprocket to the crankshaft. The teeth of the "A" bank and the "B" bank timing chain sprockets on the crankshaft must be out of phase with each other. If they are in phase after installing, remove the sprocket, turn it on its vertical axis and reinstall sprocket. See Fig. 150. <br />Install the chain tensioning tool to the exhaust camshaft sprocket. Reposition the sprocket (and the variable camshaft timing oil control unit) for the most advantageous position for use of the tool. See Fig. 151. Remove the tool. <br />Install the primary timing chain into position over the crankshaft sprocket and the variable camshaft timing oil control unit. There must be no slack on the drive side of the primary timing chain and the sprockets must not be rotated on the camshafts, or the tensioning tool may not fit. See Fig. 152. <br />Install the primary timing chain tensioner blade to the cylinder block. See Fig. 148. Install the pivot bolt and tighten specification. See TORQUE SPECIFICATIONS. <br />Push the primary timing chain tensioner piston into the tensioner body to provide clearance for installing the primary timing chain. Insert a thin rigid wire through the hole in the end of the tensioner piston to displace the ball from the non-return valve seat. See Fig. 153. With the wire in position, press the piston fully into the tensioner body. Remove the wire. <br />Install the 2 primary timing chain tensioner bolts to the primary timing chain tensioner and locate the tensioner backing-plate on to the 2 bolts. Align and install the primary timing chain tensioner to the cylinder block and to the mating slot on the rear face of the primary timing chain tensioner blade. See Fig. 147. Tighten the primary timing chain tensioner bolts to specification. See TORQUE SPECIFICATIONS. <br />Use a Primary Chain Wedge (303-533), or 2 if needed, between the primary timing chain tensioner and primary timing chain tensioner blade, to take up the slack in the chain for tightening of the variable camshaft timing control unit and exhaust camshaft sprocket. See Fig. 154. <br />Using the chain tensioning tool, apply force to the tool in an counterclockwise direction to tension the chain on its drive side. See Fig. 151. While applying opposing force to the sprocket and chain, tighten the exhaust camshaft sprocket bolt to specification. See TORQUE SPECIFICATIONS. <br />Using the Variable Camshaft Timing Oil Control Unit Setting Tool (303-654), rotate the variable camshaft timing oil control unit fully counterclockwise to the fully retarded position. See Fig. 155. <br />Check that the primary chain wedges are still in place. While applying opposing force to the sprocket and chain using the chain tensioning tool, tighten the variable camshaft timing oil control unit bolt to specification. See TORQUE SPECIFICATIONS. Remove the chain tensioning tool and the primary chain wedges and camshaft locking tool. <br />Raise and support vehicle. Remove crankshaft setting peg. Install the CKP sensor and bolt to the flywheel housing. See Fig. 143. Tighten the CKP sensor bolt to specification. See TORQUE SPECIFICATIONS. Install the access grommet to the housing and lower the vehicle. <br />WARNING:Check that the ring dowels are engaged squarely. Fully locate the assembly as much as possible by hand. Failure to follow this procedure may result in damage to the vehicle. <br /><br />Install NEW "O" rings to the variable camshaft timing oil control unit housing. Lubricate the "O" rings and the bushing. Install the variable camshaft timing oil control unit housing. See Fig. 142. Install the variable camshaft timing oil control unit housing bolts. Tighten to specification. See TORQUE SPECIFICATIONS. <br />Install the variable camshaft timing oil control solenoid. See Fig. 141. Install and tighten the variable camshaft timing oil control solenoid bolt to specification. See TORQUE SPECIFICATIONS. <br />Install the timing chain cover. See TIMING CHAIN COVER (NON-SUPERCHARGED). </span><br /></td></tr></tbody></table>
Aug 26, 2010 | 2001 Jaguar XJ8
My 1998 XJ8 Jaguar won't start
I think your right sounds like it jumped time or the belt broke. they have a timing belt..
Dec 10, 2008 | 1998 Jaguar XJ8L
XJ8
The Jaguar v8 does not have a rocker arm or push rods, this is an overhead cam type engine.
4 cams on top of the heads which are driven by the timing chains, which are driven off the crank.
If your noise appears from the lower end, the most common issue is a main bearing in which case the car will need an engine. (the bearings go bad due to lack of oil circulation, the oil pick up tube in the oil pan gets clogged)
If the noise is upper and the car seems to run rough then the upper timing chain tensioner has broken and the chain has jumped causing the timing to be off.
If you start the car and you have a bad upper noise then the chain could be broken and by running the car you definitely will have valve damage.
JPTCAT
Sep 26, 2008 | 1998 Jaguar XJ8L
Jaguar 1998 XJ8 Base Logo
Top Jaguar Heating & Cooling Experts
rdjagger
 Mikey
Mikey
ray gallant
Are you a Jaguar Heating and Cooling Expert? Answer questions, earn points and help others
