Question about LG Televison & Video
Head Doctor OSD reports "clean heads"
Hi, my LG VHS GC290SW1F will not play. Even though heads have repeatedly been (tape) cleaned, still get OSD error. A while back, had tape-jam which involved removing cover and unwrapping tape. Could this have damaged head/s?
  • LG Master
  • 5,056 Answers
Yes it could well have. Depends also on how you clean the heads. The best method is to take of the top cover of the VCR and with some Servisol Video 40 spray - spray and wipe with cotton buds all the surfaces the tape touches. You might have to do this several times. More if the video is in a room where someone smokes! If that doesn't work the Video head might need to be replace.
PS you can't get the Servisol at places such as Maplin (UK) or Radio Shack (USA) and online sites such as Amazon and E-bay.
Posted on Apr 27, 2014
  • 8 Answers
SOURCE: Pictures not showing(VCR)
Place a dollar bill between your thumb and the heads,press gently and turn the head back and forth with the other hand...cleaned a many vcr heads this way..
Posted on Dec 17, 2008
  • 125 Answers
SOURCE: Philips DVP 3200V/37
Hey there, Here are some ideas; I would clean it one more time to make sure that its nice and clean try playing a different tape on your VCR and check the channel on your VCR, and thats if you are using a channel 3 or 4 on your VCR, concur with each other. Meaning if you have Channel 3 on your TV you should have Channel 3 on your VCR. Thats a really old method. If you use a coxial cable unplug it and replug it in again sometimes there is no contact at one of the ends therefore disconnecting or connecting it again would help. Just see if that works and usually that was the problem when i use to have problems with my VCR. Let me know if that works out for you alright.
Posted on Oct 04, 2008
jerryg50
  • 1667 Answers
SOURCE: Very snowy picture when recording or watching video tape
If there is snow from the VCR only when the tape is being played, it is possible that there is a head clog or dirt on the heads.
If the head is clean and there is still snow from it, this means that most likely it is faulty.
A service tech who is experienced at servicing VCR's can connect a scope to the pre-amp test points, and run his calibration tape. With this he should be able to look at the signal carrier envelops on the scope and see if there are any faults.
At the same time, he will also see if there is a fault with the head pre-amp area. I've rarely seen any faults in the pre-amp area.
An experienced tech who works on VCR's can change the head for you. This is time consuming because he will have to go through all the guide and tracking alignments with the scope and test tapes.
A problem with most VCR models, unless it is a high end industrial model, most manufactures are no longer supplying replacement parts. They are telling the people to buy a new machine.
In reality, it may not be cost effective to service your VCR. You may end up buying a new one.
Jerry G.
Posted on Jun 14, 2008
SOURCE: DVD player /video cassette recorder
I bought an used VCR mitsubishi HS-U446. I want to know how to program it to my Sanyo TV so that I can play tapes
Posted on Jul 31, 2009
SOURCE: Samsung VR5508 VHS VCR doesn't record a TV program.
I do still need assistance with my VCR problem, however, I do not want to sign up for a plan. I will find someone local to me for this problem.
Thank you anyway.
Posted on Jan 14, 2010
Vcr hi-fi light blinking
You just have a dirty main video head. You can get a head cleaner tape or you can buy a tin of Servisol Video 40.
To clean with the Servisol, remove the top cover of the VCR. You will see a big shiny video head. Spray that head with the cleaner. You can also wipe it over with a cotton bud if it is very dirty. It's a good idea to clean all the surfaces that the video tape touches. If you don't know which, when you first take off the cover with the VCR on power, put a video tape in a press play then watch where the tape runs. Eject the tape, then clean with the spray and a cotton bud. You can even spray the cotton bud and then clean with that if you are not happy just spraying into the unit.
Make certain that the sprayed areas are dry before trying a video. It dries very quick anyway.
Jan 29, 2014 | Panasonic Pv-7451 Omnivision Vhs Vcr W/...
JVC HR S8000U S-VHS VCR switch from stereo to mono during playing.
try to do a player head cleaning. just be careful doing this..
thanks
Aug 04, 2008 | Televison & Video
NO SE VE
If You are not getting a video output from the LG player , get yourself a head cleaning tape ( wet type ) and run it for 15 seconds and then try playing a good tape with out any fungus on the surface.
Mar 10, 2011 | LG MG64 VHS VCR
My Mitsubishi HS-HD2000U D-VHS is only playing back in mono and not stereo/Hi-Fi .
you need to remove upper cover and clean tape head area by a clean **** of oslo band paper. any clean white band paper can do. don't use clothe, it can damage head chip.
Apr 05, 2010 | Televison & Video
Vcr doesn't record sound. Though it plays back
Needs cleaning. You can either use headcleaner cassette ( not always effective ( If you can find the type with micro-filament brushes they're more expensive but far more effective and last forever ) ) ; or alternatively do it manually ( sometimes neccesary ) ; unplug unit, remove the cover and clean all the surfaces that the tape comes into contact with ( using Q-tips and head cleaning fluid ( most effective ( when done thoroughly ( have to keep at it until absolutely no trace of black carbon comes off on Q-tip ) ) ) .
Oct 15, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
LG RC195 dvd/vhs combo
Do you just get a snowy screen when you playback? I think the first thing to try is to clean the video heads. Either try a head cleaning tape, but these are not always the best thing, better still is to remove the lid & carefully using a head cleaning fluid (isopropal alcohol) & a thin piece of card or head cleaning stick (NOT a cloth), carefully & gently wipe the heads which are on the round silver drum. Do not use too much pressure or you will damage the heads, give it time to dry (couple of minutes) & then try playback.
Jul 20, 2009 | LG Televison & Video
VCR acting strange with audio and playing
It sounds like the audio control head is at fault.
If all prerecorded tapes (movies) play with audio level jumping up and down, is is likely that the audio head is dirty. The audio head in the VCR looks very similar to a head of an old audio cassette player.
First, try to clean the audio head by running a VHS head cleanning tape. The cleanning tape will usually clean the path of all tape mechanisms..
Good Luck
Feb 25, 2008 | Panasonic PV-V4523S VHS VCR
DVD RECORDER + VCR
this shows that your tape needs to be cleaned we have vhs cleaner a liwuid type and dry type just play this and it will clean your tape head. the tape is stock up inside due to dirty tape head. does this answers your problem?
Dec 03, 2007 | Televison & Video
VHS Recording Tape
not much of a help but sounds like your record head is bad on the vhs heads,
use cleaning tape try that, if that fixes great, if it helps but not fully there, you might have to clean them by hand with very soft paper town and rubbing alcohol rub side to side very easy , if none of the above work you have a bad record head or record board, not worth repair vs cost
good luck
Aug 25, 2007 | Philips Magnavox 20MC4304 20 in....
Televison & Video Logo
71 people viewed this question
Computer Repairing
Computer Repairing
