Question about Mitel 5330 IP Phone
Tftp server unavailable - Mitel 5330 IP Phone
  • Joe Samuel
    Joe Samuel May 16, 2014
    @Roger, I have found the issue with the help of my networking friends that on the switch once I have the Voice vlan config from the port it worked. This phone doesn't take any voice vlan config on the port. works only on data config
    Problem Solver:
  • 6 Answers
Make it available :). The Tftp ip that is programmed in the phone or passed out by a dhcp server is unavailable or unreachable. Tftp is typically how the phone obtains it's config. Does your phone work? You can access the phones settings by holding down the blue key and restarting the phone. There you can verify your settings or change them.
Posted on May 15, 2014
Avaya 1403 firmware upgrade
Have you set your tftp servers? Is it downloading? Look at the TFTP server for any errors.
Jun 13, 2012 | Avaya 1403 IP Office 700469927 Digital...
The phone is saying that option 128 is missing im not sure what this means
This means that the phone is expecting to receive a tftp server address from the DHCP server to download it's configuration files, but the DHCP server is not providing this information. Please check with your Systems Administrator to make sure your IP PBX or another server is housing the configuration files and the tftp program or daemon is running, then have them add the tftp server setting to the DHCP scope for your network.
Feb 22, 2011 | Mitel 5224 IP Phone
Hi,i wanna use cisco ip phone 7940 as sip ip phone.when i power up the phone ,it can get ip from network,but finally,it shows "TFTP timeout"in display led.All the buttons can not be used.What...
the DHCP server should be providing the address of the TFTP Server as DHCP Option 150. The most likely problems are:
Option 150 not defined, or not the correct IP address of the TFTP Server.
Or possibly your TFTP Server is not functioning properly.
If you have not Option 150 defined, the phone will use the default gateway as the TFTP server address.
Cheers, Simmo99.
Dec 29, 2010 | Cisco 7940 IP Phone
PXE booting errors
I don't have any experience with this product but I am 99.9% sure your problem is with Option 67. This path is from the root as defined for the TFTP server, i.e. root for the TFTP service is not the same as root for the server proper.
Most likely it should be something like:
\Boot\GhostNBF.vfd
Jul 13, 2009 | Microsoft Windows Server 2003 Enterprise...
Looking 4 a TFTP server for upgrades
There must be a tftp server on your network, that must have files on the server that are needed top upgrade the firmware. Ask your admin, as they will have the IP address. I can refer you to a tftp program you can install on a server, if need be.
May 27, 2009 | Hitachi IP-3000 IP Wireless Phone
Hello all can you please help me on how to restore the configuration of my ASA 5520? thanx
If you are going for factory reset use the following commands
asa>enable
asa#write erase
asa#reload
Dont save the configuration when it prompts for it.
if you want to restore the configuration from the backup
1. You need to have a TFTP server
2. Locate the config file on your TFTP server
3. TFTP server should be reachable from ASA
then
asa#copy tftp flash
give the tftp server ip address
give the configuration file name (as exactly on the TFTP server)
reload
Apr 01, 2009 | Cisco ASA 5520 Firewall
Cisco 7960G IP Phone Problem
Try to manually reset the phone - **#"Settings" (this will unlock the configuration) + Network + menu under number "33" - erase the configuration. Then the phone configuration will be erased. Also you can manually set IP address and TFTP server
Sep 11, 2007 | Cisco 7940G IP Phone
Upgrade firmware on a cisco ASA 5500 firewall
This is for the pixes, I haven't upgraded an asa yet...should be close or the same
* find latest version of code, these are usually *.bin files located on http://www.cisco.com/cgi-bin/tablebuild.pl/pix
* confirm the flash and RAM requirements of the PIX OS software versus what the PIX has (”sho ver”)
* make sure you have a backup of the old PIX OS and PDM to the tftp server (or at least confirm the software is there)
Note: You cannot back them up from the PIX, so you will need to download them and put them on the tftp server * put in a change control form
* once change controls confirms date/time do the upgrade:
wri mem*** only if you save your configs via tftp wri net conf t ca save all copy tftp://your tftp server ip/pix635.bin flash:imageskip this if you don't use pdm copy tftp://your tftp server ip/pdm-304.bin flash:pdm *** if this is a failover pair, upgrade the other pair reboot
Sep 06, 2007 | Cisco ASA 5500 Firewall
Mitel 5330 IP Phone Logo
309 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Kelley Hopper
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
