Question about Panasonic Office Equipment & Supplies
Image projected from the projector is shaking
4 Suggested Answers
SOURCE: Multi-media projection without image
A great deal of the time DVD players are very restrictive on outputting to multiple sources due to copyright protection. In my experience, if you use your laptops function keys to toggle output (For example, on my laptop, I hit FUNCTION + F4 to cycle between LCD,LCD+VGA,VGA), you should be able to disable the laptop's LCD display, only outputting via the VGA cable. It's worked for me with my HP VP6111 and Windows XP in the past. Hope this helps!
Posted on Jun 19, 2007
  • 75 Answers
SOURCE: Dell 4100MP Image Not Centered Thru Lens
No to your question. The lens is fixed it cannot shift horizontally only although there are projectors that can do this. I am sure you have the front foot retracted? I have had to do the same as you are doing or find a lower table.
Posted on Jun 05, 2010
  • 452 Answers
SOURCE: When I plug in the projector to the mains and to
Hi ;
  1. click right botton on your desktop
  2. choose Nvidea control pannel
  3. configure multiple displayer
  4. choose the second displayer projector and apply the change
Posted on Oct 19, 2010
Shaking image
the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe (clean) the Inductor.
Feb 10, 2014 | Artograph LED 300 Digital Art Projector
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
We use Power Point with our 4100 dell and many times when a new screen is selected the projected image shakes 2 or 3 times in less than a second. Then is fine untill a new selection is made. Almost looks...
This called syncronisation. try different resolutions on pc/laptop. it looks like projector does not like source's resolution.
Check the cable, and connectios!!!
Mar 07, 2011 | Dell 4100MP Multimedia Projector
How to write on wall with some image or photo?
If I understand correctly you want to project an image on the wall.
If this is correct, then open following links to Texas Art Supply:
http://www.texasart.com/tools/light-boxes-and-projectors/projectors/artograph-tracer-projector.html
http://www.texasart.com/tools/light-boxes-and-projectors/projectors/artograph-prism-image-projectors.html
http://www.texasart.com/search/index.cfm?searchstring=projector&store=ALL&x=22&y=13
How it works.
Place image on table.
Put projector over top of image.
Turn on projector, and image is projected to wall or piece of paper hanging on wall.
Trace image or paint directly on the surface.
Feb 12, 2011 | Cycling
Jun 02, 2010 | Dell 4100MP Multimedia Projector
Infocus LP120 projector with the shakes
if you are refering to the image shaking, you need to replace the colorwheel. if you mean the projector physically shakes, replace the fans and/or the colorwheel. they are the only 2 moving parts in the machine.
Oct 14, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Projected image appears to shake on the screen. How do you fix that?
replace the colorwheel. if the motor starts to go, the image will jump. try av solutions in ny. they're pretty good.
Jul 09, 2009 | InFocus IN2104EP Projector
Proima lx2, darkening of the image and slight shake
either the fly-eye lens or the light polarizer is fried due to excessive dust and heat. bad news: you'll have to replace the entire optical engine. worse news: infocus doesn't make them anymore. sorry.
Sep 02, 2007 | InFocus Proxima UltraLight LX2 Multimedia...
Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Feb 11, 2007 | Mitsubishi X490U Multimedia Projector
47 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
