Question about Lands Phones
Need to show my number on cell calls
Show number on networks on calling out
    New Friend:
    Problem Solver:
  • 9 Answers
Its different for each model phone whats yours?
Posted on Apr 22, 2014
cnavarro
  • 2460 Answers
SOURCE: Call fordwarding
I forward my office phone by dialing 72# and the number.
Your office phone may be on a system that did the forwarding, or you may have to CANCEL call forwarding (73#) before you can set it.
Carl
Posted on Sep 01, 2008
SOURCE: Can I forward an incoming call to an outside line?
External transfer to Mobile 1. Transfer 2. press 1 and external # 3. Wait for ringing 4. press feature then transfer 5. hang up
Posted on Oct 06, 2008
  • 16 Answers
SOURCE: how to I forward incoming calls on my phone to a cell phone 3?
Call forward, off-premise is available on the NEC Electra Professional phone system if you have the Level II system (metal cabinet, not plastic) and you have system software level 700 (7.00) or higher. To get your system software level, press <FNC> - 3 from any display telephone when idle. The procedure to forward is (with phone idle): press <FNC> - dial 60, dial trunk access code (usually - 9), dial telephone number, press <FNC>. Additionally, your station class must be set to allow this feature (by default it is not allowed) and you may need trunk-to-trunk capability turned on in system programming (which is also, by default, not allowed). Hope that all helps.
Posted on Dec 31, 2008
TallBourbon
  • 30 Answers
SOURCE: how to forward calls to cell phone
this depends on your service from your carrier. call forwarding is pretty much the standard now with phone service providors. they shoul dhave the codes you need to dial to do that ( such as *72 then the number) you may call them and ask
Posted on Jan 07, 2009
MaMa Jams
  • 94 Answers
SOURCE: Call forwarding
Your options are...
Option 1: Hit 7 then 2 then #. You'll hear an interrupted dial tone. Then dial the number you're forwarding to.
To cancel hit 7 then 3 then #.
Option 2: Hit * then 7 then 2. You'll hear an interrupted dial tone. Then dial the number you're forwarding to.
To cancel hit * then 7 then 2.
Posted on Jan 29, 2010
I want to be able to call people and have my phone number show up. Instead of show Restricted.
DO THE FOLLOWING THINGS:
MENU>SETTINGS>CALLING/PHONE>CALL>SEND MY CALLER ID>"
CHANGE IT TO SET BY NETWORK OR SHOW"
THATS IT.
HOPE THIS MAY HELP
Mar 15, 2012 | Verizon Communications Cell Phones
How to hide my number in samsung e2121b
Hide or Display Your Number on Samsung GT-E2121B
1.Go to your menu and select Settings (round gear wheel thingy).
2.In the settings environment, select item no 6 - Application
3.In the Application environment, select item no 1 - Call
4.In the Call environment, select item no 1 - All Calls
5.In the All Calls environment, select item no 1 - Show my number
6.This gives you the following three radio button options:
i.By network
ii.Send
iii.Hide
Select iii. Hide, then exit to return to your phone interface. All calls will not display your mobile phone number to the recipient.
To reverse this and display your number in subsequent calls, repeat the whole process and at step #6, then select i. By Network. Your mobile phone number will now display to call recipients for all calls.
Jan 02, 2012 | Samsung Cell Phones
When I get calls I cant see the incoming number it only shows call how do I get the number to show to see who is calling
This is the problem with the SIM card. You need to get a new SIM card from your network provider.
Also, please insert some other sim card in phone and check if it shows the number.
May 23, 2011 | Nokia C3 Cell Phone
I need the call barring code for nokia 7100s-2 for incoming calls. I need to bar a particular mobile number from calling me
call barring and number blocking is a network dependent service. u have to contact ur network operator to block any number from calling u.
Mar 03, 2011 | Cell Phones
No number or contact name on incoming call.
Hi, I had the same problem few days back. I am using Nokia N95 with a Vodafone service. Any call I receive simply showed "Call" and on checking the call log, says "No Number". this problem is not with the phone, but with the network. I checked with the Vodafone customer associate, I got to know I din't submit my documents to them which is required on an yearly basis and so my phone had this problem. So if u r also having same problem as I had, try contacting ur network service associates and they could help you fixing the problem.
Aug 19, 2009 | Nokia E71 Smartphone
Managing incoming calls
HI,
Nokia 6111 and Nokia 6300 are the ultimate phones and I like it very much.
SOLUTION:
1.Go to "menu". 2.Then select "settings" by scrolling down. 3.Inside "settings" menu, go to "call settings". 4.Inside call settings we can see various options to select that contains reject/show busy/divert.we can choose any one from them.
SOME TRICKS: Hiding your Mobile/ Cellphone Number
1.Go to: Menu > Tools > Settings > Call > Send My Caller ID >
"'Yes', 'No' or 'Set By Network'" to follow the default settings of your home network.
It works only with very few network who provide you facility of “Private Number”
Apr 17, 2009 | Nokia 1100
Caller id will not show on incoming calls. it will not show number or name just call. i have tryed all settings please help
I had the same problem with my phone on the Orange network. I called Orange service help desk and they sent me a service message which once read and deleted, corrected the proble so that i can now see who is calling.
Mar 15, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
Reciving calls
for this problem you will need a sim update from your network provider.
Dec 31, 2008 | Nokia 5310 Cellular Phone
I have sony ericsson k750i i have problem my phone if i want to call someone but i don't want let the people see my number in there caller id. when i go to setting and click call it shows me show or hide...
The problem is not on the phone but with the network provider. some network providers dont alow you to hide your caller i.d for security reasons
May 18, 2008 | Ericsson Cell Phones
Call Barring
easy solution
please throw ur mobile
Sep 29, 2007 | Siemens CF62
Lands Phones Logo
14 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
