Question about GoVideo R6640 DVD Recorder
Can't get it to record
I just bought a R6640 and after setting it up initially, I was able to record something on the RW disc that came with the recorder. I immediatly erased it, and the disc now reads blank. Now I'm trying to record something again, and it won't record whether I press record on the box or the remote. I'm just trying to record something off the cable box. The cable runs from the wall to the cable box, the cable box connects to the 'antenna in' on the recorder, a line runs from the 'antenna passthrough' to the TV. The red, white, yellow cords go from 'audio/video out' on the recorder to the inputs on the front of the TV. Can you tell me what I'm doing wrong?
If your cable box is digital it should have the yellow, white, red rca jacks in the back run those to the rear a/v input on your recorder then cycle through the input switch on the remote until you see the picture. (i have the same model i hope you have better luck with yours...i can't record on any new 4x or slower +rw disc i had mine since 2006 i should've got a sony!)
Posted on Dec 12, 2007
How do you delete videos from your sony handycam DCR-DVD405
This Sony camcorder uses mini-DVDs to record and there are certain restrictions when DVD is used, it is not like videotape. For a DVD-R disc, you cannot delete video once it is recorded because this type of disc is a record once only. Depending on which other disc type you use and how it was initialized, you MAY be able to delete video. For a DVD+RW disc, or a DVD-RW disc initialized in VIDEO mode, you can delete the last scene IF you have not removed the disc and not recorded any new video. For a DVD-RW disc initialized in VR mode, you can delete anytime. And here is how:
Turn on camcorder and press PLAY. Select the video or still image tab that contains the data you want to delete. Touch EDIT. Touch DELETE. Select what you want deleted. The selected scene is marked with a checkmark. Press and hold the image on the LCD screen to confirm. Touch RETURN to go back to previous screen. Touch OK - YES. You cannot recover data once deleted. There is also a DELETE ALL to delete all video or images.
Mar 22, 2011 | Sony Handycam DCR-DVD405 Camcorder
I have a DVDR70 DVD recorder and i have been experiencing problems with philip DVD+RW discs. Seconds after recording starts it comes up with 'Disc Error' and no matter what i seem to do all the discs of...
if you didn't experienced same problem with different brand of DVD+RW discs, than it could be a bad batch of discs you have there. I would return them to where ever you bought them from, and get your money back - or swap them for different brand
Nov 22, 2010 | Philips Televison & Video
The dvd wont initialize blanc discs so that i can record with it.i have used different disc as well
Do you mean it won't format/initialize the disc? Alternative possible problem, when you put in a disc, does it not recognize that a blank disc is in the unit? Only DVD-RAM discs need formatting. DVD-RW discs need to be initialized. DVD-R disc do not need either formatting or initializing. (This unit does not write to DVD+R or DVD+RW discs.)
In the case of DVD-RW discs that can't be initialized. Check if this has already been done (or if you need to unfinalize the disc).
If the new disc is not being recognized as a blank disc, the recorder may not be recognizing the disc (dirt, scratches or manufacturing issue) or the recorder is not focusing on the disc properly. In the first case, clean the disc or try a different type of disc (Samsung claims that their discs will be most compatible). In the second case, the unit may need service.
I hope this helps.
(usually tracking and focus problems will be seen on both recording and playback (even with commercial discs).)
Oct 30, 2010 | Samsung DVD-R155
When I insert a new DVD RW it says can not read disc check disc. The camera will not give me the option to initialize disc either. These are brand new discs that I am using. I can record with older disc...
You have to be sure you bought the correct disks. Look in your manual or your camera. You could use DVD-RW or DVD+RW. They are not universal. You have to use the correct version. You also may want to try a DVD-R or DVD+R. They are cheaper but are not re-recordable. They are not erasable either. A good thing if you don't want to "accidentally" erase your movies!
Dec 18, 2009 | Canon DC210 DVD Camcorder
Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw) that formatting dvd-rw issue. i found that dynex dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
May 28, 2009 | Toshiba DRW2 DVD Recorder
DVD disc tray keeps popping out
I had mine for 2 years and within the first 12 months the tray would not always pop out when I wanted it to. Then finally the machine would not recognise the disc type. Its in getting fixed but although the dvd drive and associated pcb have been replaced the guy says it still can't recognise the dvd disc type. Still trying to work it out.
Mar 25, 2009 | LG DVB418 DVD Player
Does not recognize a blank DVD
I bought DVD-R 1-16xspeed made by TDK which work fine.... it seems to be a bit of a mine field of discs available but I do remember these were recommended by Samsung via a leaflet in the box.
Apr 03, 2008 | Samsung DVDR120 DVD Recorder
Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
GoVideo R6640 DVD Recorder Logo
75 people viewed this question
Top GoVideo Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
