Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Error message on start up
Loggings application stopped working and was closed. The culprit is supposed to be update kb929777 but I cant find it on my PC
  • Denis Stephenson
    Denis Stephenson Apr 22, 2014
    Why oh why are you still using Vista?? and have you got sp2 installed?
  • Anton Trdi? Apr 24, 2014
    on boot time (when logo dissapears) just start hitting F8 i choose last known good configuration
    Champion:
  • 245 Answers
On boot : (when logo dissapears) just start hitting F8 and choose last known good configuration from the menu ... that will fix it , but when you are back in windows delete the specified kb929777 from list of updates (control panel->windows update --> from left side panel choose list of updates, search by installation date or by kb, then click and deinstall)
Posted on Apr 24, 2014
  • Microsoft Master
  • 1,381 Answers
3 Suggested Answers
  • 30 Answers
SOURCE: unable to start pc
It's a BSOD(Blue Screen of Death) error. Just try re-installing the operating system. If it does'nt help , check your RAM.
Regards
Grydor
Posted on Feb 10, 2008
mahjid
  • 202 Answers
SOURCE: wen i start my pc on windows vista i reveive
get Win Vista CD, boot from cd and click on repair my computer, here the system will try and fix it, if it does'nt then use the same process to restore the system to a particular time (mind you not COMPLETE RESTORE), you won't loose any save files. good luck
Posted on Jun 09, 2009
Updater has stopped working ... error message pop up
turn it off in startup .
clik your start run
type msconfig
look in top right for startups
unchek
SoftwareUpdater.exe apply close restart system
Aug 03, 2014 | Microsoft Windows 7 Home Premium 64BIT...
After clicking print to PDF a schedule, Suretrak shows error message that says Suretrak Application Manager has encountered an error and needs to close. No other info.
I would try reinstalling the software. Sounds like a file got corrupted. If that does not fix it:
Have installed the latest patches for SureTrack?
Have you updated Windows?
If so, did the problem start after one of the updates?
Mar 11, 2010 | Primavera SureTrak Project Manager 3.0 for...
What is an ArcCon ac application error0xc00000006?
What you describe falls under the general category of svchost.exe issues. Svchost.exe is used by your computer to access the registry and check the services to load during system startup.
arccon.ac is an ArcSoft Connect Notifier. There are two possibilities why its happening:
  1. Microsoft releases regular security updates that are installed automatically on your computer by the Automatic Updates feature, which is enabled by default on your computer. The Svchost.exe Application error usually appears due to a problem with a recent update.
Closing the error message might freeze your computer. To fix this error, perform the following tasks.
  1. Open Control Panel, select Performance and Maintenance, and then select Services.
  2. In the System Properties dialog box, open the Automatic Updates tab.
  3. Next, select the Turn Off Automatic Updates option.
  4. Select Apply and then OK to accept your changes and exit the System Properties dialog box.
  5. Restart your PC.
  6. Ensure that you are connected to the Internet and then select the Windows Update command from Start > All Programs to manually update Windows.
  7. After the update is complete, enable the automatic updates again from System Properties > Automatic Updates.
This should rectify your application error. However, if the error keeps reappearing, then you might turn off automatic updates permanently and manually perform Windows updates at regular intervals.
Errors Caused By Virus Infection
Let's hope that this isn't the case. Lengthy procedure but if you are still having trouble, we'll cross that bridge when we get to it.
Dec 09, 2009 | Computers & Internet
"close other video streaming application to start video"
The same thing happened to me. But I believe this happened because I upgraded my Vista from 32-bit to 64-bit. How I solved it? The same way someone earlier suggested: update the driver:
1. Start the device manager (Click Start, type "device", and then click on "Device Manager" which appears as part of the search)
2. click the + next to "Imaging Devices"
3. Right click the "Integrated WebCam"
4. Click Properties
5. Click the option "Update Driver"
6. Automatically the updated driver will be loaded.
7. Restart your computer.
Hope this works for you.
Jul 22, 2009 | Dell Studio 1737 Laptop
Can't launch camera software after updating. windows XP
Always Start an Application in Administrator Mode on Windows Vista. Many utilities need to be run as administrator in order to function properly. All shortcuts in Windows Vista have a special property that you can set that will allow the application to run as Administrator. To set this property, just right-click on any shortcut, and click the Advanced button on the Shortcut page to get to the Advanced Properties dialog. You’ll see a dialog with a checkbox for “Run as administrator”. From now on, the application will always run as administrator if you use the shortcut to launch it.
Dec 06, 2008 | Computers & Internet
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Problem Event Name: APPCRASH
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Code: c0000005
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Sep 18, 2008 | Computers & Internet
Critical component is either missing or cannot start
Have you tried a soft reset or hard reset yet P ? How about a ROM update ? Seem like one of your applications on the Ipaq is having a conflict so try to remove them 1 by 1 and pinpoint the exact culprit Did you have the programs installed on the main Ipaq memory or a SD card if you have one ?
Sep 11, 2005 | HP iPAQ RX3100 Pocket PC
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
