Question about Eureka Boss SuperLite Bagless Upright Vacuum, 405AVacuum
I have a Eureka The Boss Power Plus vacuum cleaner and it has zero suction. Comes on fine, filter is clean, belt is new...no suction. Any ideas what's wrong?
  • brenriddle Apr 22, 2014
    There is no suction near the brush or the hose...
  • 33 Answers
SOURCE: download parts and operators manual
This owner's manual is available on the Eureka website. www.eureka.com Type in your model # down in the right corner, search & buy accessories.Click go, then choose either the 402A or 402A-1. It is the same owner manual for either one.
Posted on May 19, 2009
reddevil6
  • 1673 Answers
SOURCE: my eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Posted on Jun 17, 2008
  • 64 Answers
SOURCE: Eureka Boss - no suction in upright postion
when mine does that I find that the hose is not connected properly where it comes off to use the attachments.
If there is suction there, it is a straight shot to the floor unless it is loose where it fits together.
Posted on Dec 31, 2008
  • 46 Answers
SOURCE: Eureka the Boss SmartVac just turned off and won't turn on
Make sure it is not the electrical outlet that has tripped. If not then you basically have 3 choices. Cord, switch, motor. A service tech. should be able to diagnose.
Posted on Jul 25, 2009
nwj2468
  • 76 Answers
SOURCE: new Eureka 5893 BVZ looses suction
eureka is about the most helpless website ever!!! did u try cleaning the filters?
Posted on Aug 22, 2009
Eureka Rally 2 had great suction the first two times I used it and now faint. No blockage and new bag and clean filter. What coud it be?
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
REPLACING THE FILTERS
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
Dec 25, 2010 | Eureka Vacuums
Why does my vacuum leave a trail of hair on my floors when it's being pulled backward but suction up fine when it's going forward?
It is because the belt is worn and stretched. when you go forward there isn' t as much resistance and the brush can turn and pick up, but when you go back there is more resistance and doesn't pick up. You simply need to replace the belt. Here is the belt you need:
Eureka Boss 5849 Belts
May 20, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
Eureka the Boss Power Plus belt problem
it could be the beater bar (brush) has bad bearings at the ends or burs on the beater bar section the belt rides on,my money is on the bearings.
Jan 24, 2010 | Vacuums
New Eureka 5893 BVZ looses suction
Jul 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
BOSS 5851 Wide Track, 12 Amp
The top comes off to get to the belt and brush roll. Did you check the brush roll to make sure that the ends turn freely, or is one not turning, the belt is a lon life "U" part #61120A. The brush roll is what drives the vacuum, but if brush roll or belt is bad, then it won't drive it.
Feb 03, 2008 | Eureka 5849A Boss Bagless Upright Cyclonic...
Eureka the Boss bagless
Sounds like you have a clog somewhere. Check the filter inside the dust compartment, if is very dirty it won't allow ait to flow thru, Part #62132, DCF-H filter. Check the hose, take it off if you can and drop something in it to see if it comes out the other end, if it doesn't, then the hose is clogged. Check bown by the brush roll, the inlet may be plugged. Also if the belt is more then say 6 months old, you may want to replace it, I am sure it is strertched, part #61120B, extended life belt.
Jan 23, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Vacuums Logo
59 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
