Question about Ricoh Aficio 450 Copier
WHAT IS HDD - Ricoh Aficio 450 Copier
  • 4 Answers
Hard Disk Drive - identical to the one in your computer (but probably a different size). It is where the images are stored when making copies. If you have a failure, then it is probably reporting that it cannot read or write to the hard disk.
Posted on Apr 22, 2014
No boot hd disk error
HDD not Detecting only Some region, if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
More Technical Help TechSupportMart
Feb 05, 2014 | Seagate Barracuda 7200.7 40 GB Hard Drive
PC not detecting HD
HDD not Detecting only if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
Thanks..
More Tech Support Contact
http://www.techsupportmart.co.uk/
Feb 05, 2014 | Transcend StoreJet Computers & Internet
Toshiba 451c "can not find HDD data" message
Had the same problem and solved inserting and extracting the card a whole bunch of times and blowing hard inside the slot. You can also try using the rubber to clean the contacts of the SD. God luck.
Nov 22, 2013 | Toshiba Office Equipment & Supplies
Copier reads e7-03
E7
Content HDD trouble
Detail
HDD connection failure
If the HDD responds an error or does
not respond for 30sec, it is judged as
an error. (Other than the system area)
Data abnormality in the file
management area (when the cluster
chain is broken)
Cause
HDD is not installed properly to the ICU
PWB.
HDD does not operate properly in the
ICU PWB.
ICU PWB trouble
Check and
remedy
Check installation of HDD to the ICU
PWB.
Check connection of the harness of
HDD to the ICU PWB.
Use SIM 62-2, -3 to check read/write of
HDD.
Replace HDD.
Replace ICU PWB.
Aug 05, 2011 | Sharp MX-2300N Color Copier
Can't install XP. After "hit enter to install" get "can't find HDD". Tried new HDD/memory, no luck. Can't boot from any option on "safe mode" screen. Sony VAIO...
> cannot find HDD
> tried new HDD
Using the new HDD should have "solved" the "cannot find HDD" problem, if you assume that the motherboard is functioning correctly, and if you assume that "use HDD" is "enabled" within the "BIOS SETUP" mode on the computer.
So, either:
* the "new" HDD is defective,
* the motherboard is malfunctioning,
* the BIOS SETUP has been set to "ignore" the HDD.
May 15, 2011 | Computers & Internet
I forgot hdd password how to unlock
Toshiba highly recommends the customer to fully understand what HDD Password is and once registered please keep your "PASSWORD" in a safe place.Your HDD password is different from your BIOS Password. Your BIOS Password is stored in the computer, but your HDD Password is stored in the HDD unit itself. So even the HDD unit is removed from one computer and attached to another, the HDD password is required to access it.If you forget your HDD User Password, TOSHIBA will NOT be able to assist you, and your HDD will be rendered COMPLETELY and PERMANENTLY INOPERABLE. TOSHIBA will NOT be held responsible for any loss of data, any loss of use or access to your HDD, or for any other losses to you or any other person or organization resulting from the loss of access to your HDD. http://aps2.toshiba-tro.de/kb0/TSB6B01MC000CR01.htm
Dec 07, 2010 | Toshiba 80GB MK8037GSX 2.5" SATA II SATA...
I have a hdd quantum fireball lct 10 3.5" series with the serial number 973006916882 papxx power req 5/12v 600/900 ma. My question is about the capacity of this hdd since it is not written as I want to...
my hdd was install in IBM pc. Aftr that i am install my hdd in my assemble machine. My hdd is good condition.In BIOS HDD property is show perfect but when i want to format my HDD maybe fdisk or winXP CD my HDD is not work properly from this time. Please help me..........
May 20, 2010 | Computers & Internet
Hdd won't go into right size hdd enclosure case
Hi there
Sorry to say that you need to return your drive to your supplier !
you have purchased a Sata HDD and the one you require is an ide hdd
Regards
Al "alstech"
May 25, 2009 | i-rocks IR-9200 USB 2.0 2.5" HDD Enclosure...
Same problem
You didn't tell what happen to your HDD after you set the jumper?...what to your HDD?..is it not detect?..Have you tried to change your IDE CABLE, instead changing the jumper settings to you HDD?..
Feb 25, 2008 | Intel D865GBF Motherboard
Ricoh Aficio 450 Copier Logo
20 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
