Question about LG LRFD25850 French Door Refrigerator
LG refrigerator with slow water dispenser.
The only time since I bought this fridge that the water came out at a reasonable speed was when I first install a new filter. The faster water flow happens for about 2 minutes. Then it is right back to flowing very slowly.
SOURCE: LG Refrigerator water and ice dispenser stuck
We just had this problem and we fixed it by peeling off the soft rubber covering (the part you press the glass against)and then putting it back on. There is a plastic tab beneath that could get stuck if the rubber part gets an air pocket or bent out of shape. This took 2 minutes and worked like a charm.
Posted on Sep 15, 2007
antiochpc
  • 1314 Answers
SOURCE: My new refrigerator's ice maker and water dispenser doesnt work
Since this is a brand new unit, I wouldn't waste the time or money troubleshooting it yourself; contact the place you purchased it from and exchange it.
Posted on Jul 15, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
Todd_pdx
  • 22 Answers
SOURCE: Water dispenser slow flow after filter change
When you change your water filter you must purge the line to remove any air or it will continue to flow all over the floor use as large a container as possible it will require you to draw at least 2 gallons of water to purge air in line. Your inlet valve is the reason your water flow is slow it is clogged with sediment from your water supply it needs to be replaced.
Posted on Apr 02, 2009
SOURCE: water dispenser is working very slow the water is flowin very slow.
is the s water holder frozen?
Look behind the lower left prodcue box
if not it could be the despenser valve not
opening all the way
Is the ice maker working OK?
Posted on Apr 28, 2009
Why does the water from the dispenser run so slow from my lg french dioor fridge
Check the filter.. either on top right in fridge section or on the bottom kick plate.
Also check in coming water line for kinks
Jun 28, 2015 | LG Refrigerators
Water dispenser running slowly
Hello Cynthia;
My name is Peter. I am a retired field service refrigeration technician.
You have a water pressure problem. You need at least 60 PSI water pressure to open the solenoid valves. I suspect you are getting small ice cubes.
If you have well water you are not going to get the pressure for fully dispenser flow.
I have experienced bad water filters. One time our techs received a large shipment of bad water filters. Remove the water filter and test the water dispenser.
With low water pressure you may not want to use a water filter
Dec 08, 2014 | LG LFXS24623S 24.0 cu. ft. French Door...
Low water flow
Make sure the hose behind the fridge is not kinking up, slowing down the flow rate of water.
Nov 17, 2011 | LG LFX23961 (226 cu ft) Bottom Freezer...
The water dispenser is really slow coming out and it takes however to make ice. There is no kink in the water line to the fridge.
water stopped dispersing out of water dispense, No indication as to why. New filter was instlled, checked water line, no leakage indicated, ice maker had been making ice prior to this, turned off ice maker to avoid motor burn out.
Dec 26, 2010 | LG LRSC-26922 Side by Side Refrigerator
Water flow of filter too slow
When was the last time you changed the water filter? If the filter is clogged from long usage it will slow down the water flow. Filters should be changed 6-12 months.
Jul 11, 2010 | LG LFX25971ST Bottom Freezer French Door...
Replaced Water Filter - Now Slow Water Dispensed
If its should solved with an original spare part again then there could there be a marketing technical patent on some materials.
Aug 26, 2017 | LG LSC27931S Side by Side Refrigerator
Water Dispenser
The water does come out slow on these models. I know you said you replaced your filter with a new one and it is still not any faster.
I own a Kenmore Elite #596 73503 201. I have not changed my filter for approximately 18 months and when I timed how long it took to fill a 2 Cup measuring cup (liquid measure) it took: less than 45 seconds. Can you test yours and post back how long it takes with your fridge?
Feb 16, 2009 | Kenmore 73503 Stainless Steel Bottom...
LG LRFD25850 French Door Refrigerator Logo
1,253 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
