SOURCE: 1991 eagle talon
simple!!!!!! pull the old one out and install the new one reverse of the disasembly. if that is to hard take it to a mechanic. besides that the water pump is on the opposite side of the timeing belt. the timeing belt doesnt cover any of the bolts for the water pump.
SOURCE: fuel pump not coming on on 95 eagle talon
check fusible link #4. it is the pink, 30amp one, at the top left corner of the underhood fuse/relay box.
i doubt its the fusible link, if it was it would cause alot more than your fuel pump to no work.
it is most likely a relay so check the fuel pump relay and the ASD relay.
(click for full-size)
SOURCE: up my boost on 97 eagle talon
Hello, I wouldn't up the boost without supporting mods. The stock motor will take 18psi of boost, but you run the chance of over heating your internals, hitting fuel cut, leaning out your fuel mixture to much, and all sorts of other bad news.
SOURCE: No spark, Coil test ok and so does cam sensor
i think those had ignition control module problems.........
SOURCE: eagle talon has no spark.
i have the same problem with my car i put a crank and cam sensor, a whole other coil pack, and an ignition control module the only thing i have left to do is put a computer in it. if you find a solution email me at [email protected]
