Question about SAMSUNG EHS64AVFWE Stereo 3.5mm White Headphones with Volume Control
What colour wire does what with Samsung in ear earphones
I've stripped open a pair of these at the jack to fix them, but I can't remember which colour wire is left ear, right ear, and volume controls. There's red, black, green/brown and bare copper. Thanks in advance.
    Problem Solver:
  • 5 Answers
This is an educated guess.
You should have 4 rings around your 3.5mm connector. From the tip to the base of the connector....
#1 - left audio - Black
#2 - right audio - Red
#3 - Ground - bare copper
4# - Mic/volume - green/brown
The wires for the left and right channels (pins 1 and 2) and the ground, (pin 3) should run from the connector through the volume control, to each ear piece. The mic/volume wire should terminate at that control. although it could connect to more than one place within the control.
You may be able to open the volume control, gently, and see which wire stops there and which continue on through.
I hope this gives you enough information to complete your project.
Dennis
Posted on May 08, 2014
Well my earphones .. one side is not working which is the right ide it used to work when wiggling the wire but now even when wiggling wire it does not work . ??
Broken wire on jack. To fix it, you'll need to cut it open and solder in a new jack. The wires are usually so fine that it'll be difficult to strip; you might want to invest in a new pair of headphones instead.
Jul 18, 2011 | Audio Players & Recorders
The right ear speaker on my ipod ear phones no longer emits sound. Is there anyway to fix this?
If you are handy at repairing electronics, you can splice the white cord open and re-solder the wire if it is loose. However I NEVER use the iPod earphones - reason being is when I listen to a song on my iPod and the dial slips past 80% then speakers usually blow. I would buy a pair of Skullcandies, I have 2 pairs and they have never blown. They are only $14.99 at any Target/Walmart and you can definitely save yourself the hassle. Those earphones brand new at stores such as Radioshack are about $29.99, and are very mediocre.
Jun 01, 2010 | Apple iPod Earphones (MA662GB) Earphone ...
Sound comes only in one earphone..
your headphones probably blew in the one ear. Try another pair of headphones.the same thing happened to me. if that doesnt work the recepters in the ear jack youll have to have a professional to fix it
Feb 28, 2010 | Philips Audio Players & Recorders
One of the earphones doesn't always work you have to jiggle the wire near in the input plug and it will go on and off in the left earphone what's wrong and if possible how do i fix it
The wire in the plug or near it has broken. You can fix it if you know how to use a soldering iron. You will need to purchase a jack plug from your electronic shop. Determine where the break is and cut the cable below it. You will need to strip the end of the cable to get to the wires. There will be at least two coloured wires and two earths. Next with a sharp knife open the plastic barrell of the old plug. This should tell you where the wires connect on your new one. If in doubt remember that the earths will go together on the long metal piece of a 3.5mm plug. The two coloured wires (left & right) will go on the smaller lugs. If you get them wrong reverse them, but it will not hurt anything if you do. If the sound is spaced out after you have done connecting. Then a earth wire(s) is off. Make certain the wires only connect with the lugs they are supposed to and the solder doesn't short anything.
Jan 17, 2010 | Skull Candy Lowrider Headphones
Apple Ipod 4th Generation is only playing music through left ear jack. I'm confident it is a earphone/jack replacement issue. The problem occured when someone yanked my ipod from me and the ear bud cord...
Well, yes you are right there is no other issue than earphone. you can purchase the earphone from the below link -
http://cgi.ebay.com/ORIGINAL-Apple-4Gen-Earphones-Headphones-for-All-iPod_W0QQitemZ260523098037QQcmdZViewItemQQimsxZ20091214?IMSfp=TL091214234010r19836
Good Luck!!
Thanks
Jan 06, 2010 | Audio Players & Recorders
Sound from 1 side only!
your ear input female jack is stripped try another new pair of earphones if not you may have to take it in for service.
Nov 05, 2009 | SanDisk Sansa E280 MP3 Player
Right earphone wont work.
It is very likely that the problem is in your MP3 player and not your ear phones. If it is still under guarentee, then take it back to where you bought it. If not it may be that the earphone jack plug is faulty? It is a trade off between the cost of repair against the cost of a new one. These things are often glued together so opening it could break it anyway - sorry
Jul 02, 2009 | Nextar MA933A MP3 Player
My right earphone won't play
Sound not coming out of one side of the headphone is an indication of connection failure, so that means you have to see where its 'broken' from, either inside the headphone on on the wire somewhere. Usually it happens at the jack, especially if you use an ipod as it tends to get moved alot in pockets, etc..
If this is the case, you could try to cut the wire from where you suspect its broken, and get a 3.5mm (or whatever the original size is) replacement (Do-it-yourself) jack from Radio shack or electronics store.
THen you would have to cut the wire, strip the the rubber coating off, and then if applicable, carefully strip the very thin layer of further insulation thats on the wire it self. Otherwise you would directly connect the cables to the prongs/connections located on the replacement jack. And depending on the jack you would screw it in place or soldier it with soldier and soldiering gun.
If its broken in the headphone or at the headphone, thats much harder to do as you would have to open the head/earphone case and soldier it that way and get it back together in one piece.
Next time don't buy bose headphones and by something cheaper, bose isn't that great, skullcandy is pretty good too. Sennheiser is the best though in my opinion. albieit its expensive too..
Feb 23, 2009 | Bose QuietComfort 2 Consumer Headphones
Bad connection near the jack
DON'T BUY ANOTHER PAIR!!!! This is a very common problem with these earbuds.
Sep 04, 2008 | Bose in-ear headphones - Black with...
SAMSUNG EHS64AVFWE Stereo 3.5mm White Headphones with Volume Control Logo
386 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
