Question about Acer ET.CV3WP.E05 LCD Monitor - V193WEJb 19" 5 ms Adjustable Display Angle 1440 x 900 16.7 Million Colors 250 Nit 50000:1 VGA Black
2nd monitor does not work with DVI to VGA converter cable. My video card has VGA and DVi ouputs.
Someone gave me the monitors to replace my old 4:3 sony monitors. there is no DVI input on the monitor so I am using a DVI/VGA conversion cable. As soon as it is plugged in it says there is no signal. Does this monitor not support a dual configuration? it will run 1400X900 and both monitors fuction correctly but will not run off the DVI output with converter cable.
  • 1 more comment
  • Kris Hansen
    Kris Hansen Apr 23, 2014
    SolidWorks certified video card (at the moment don't remember the brand or model). I was running dual monitor in 1280/1024 4:3 aspect with my sony's. I thought I was upgrading by going to 1440/900 resolution...monitors aren't as clunky but at least sony's has DVI input. Was just curious why the Acer won't work on the DVI convert to VGA. And I've tried at least 4 different cables of connectors.
  • Kris Hansen
    And yes, as I said earlier, my video card has VGA and DVI output. The Acer monitors only has VGA input. My 4:3 sony's had VGA And DVI inputs.
  •  Mike M
    Mike M Apr 23, 2014
    Take a look at this. http://www.reinmedical.com/en/knowledge-...
  • Acer Master
  • 3,320 Answers
What video card? Did you consider that the video card will only support 1 monitor?
Posted on Apr 23, 2014
  • 4 Answers
The problem could be in the adapter to the video card. There are different types of DVI connections. If the adapter does not have the proper set of pins then the card will not recognize that a monitor is connected at that port. Monitors themselves have no bearing on whether a single or dual monitor set up will work or not. Digital Visual Interface Follow this link, it may help you determine if the adapter you are using is correct for the graphics card.
  •  Mike M
    Mike M Apr 23, 2014
    the connectors are made with a key slot so that they cannot be be interchanged.
  • 105 Answers
SOURCE: Acer X193W not getting any signal when connected to 8600GT by DVI
If you know the cable and the place it was before
replace it and reboot the dude (Ps if you dont have the referce and instructions for the take a polaroid
Posted on Oct 19, 2009
SOURCE: connecting dvi cable straight to acer monitor
The cable box is probably outputting a resolution the monitor is not compatible with. Computer monitor and television resolutions are usually different, and not cross compatible in some cases.
For example, wide screen monitors are usually 16:10 aspect ratio, while TV is usually 16:9 aspect.
The AL2216wbd is a 1680x1050 display, while HD TV is either 720p (1280x720) or 1080i (1920x1080).
If your cable box is set to 1080i that would be too high for the monitor. You will need to set it to output at 720p, and even then you will probably get a vertically stretched picture since the monitor has a taller aspect.
Posted on Jul 28, 2008
SOURCE: Acer AL2002W Monitor
For DVI you need to probably upgrade your cheap graphics card, something not that expensive would be a ATI Radeon HD2400 Pro, it'll do. May want to check what pwer supply maybe required on your PC.
Posted on Feb 14, 2008
  • 3 Answers
SOURCE: Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Posted on Jan 30, 2011
budmrtn
  • 11361 Answers
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 31, 2011
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
Help Adding a 2nd Monitor to ALL-IN-ONE
Try using a VGA to VGA cable or a dvi to dvi cable because dvi-d and hdmi tend to lack the necessary pins to be converted to an analogue signal. A hdmi to dvi cable may also work
Jun 12, 2013 | Gateway One ZX4970G-UW308 All-In-One...
I would like to hook up my old monitor, product LT782s, model 700P, to my new monitor so I can have duel monitors. The cord has 2 screws to attach. The new monitor does not have any place for a "scr
You need to connect both monitors to a computer. Monitors do not daisy-chain (in general). The exception are some SCART-enabled monitors.
What is your source (desktop)? What is the make/model of your new monitor? Please add a comment with the video outputs/inputs for your source and second monitor.
Many newer desktops have two or three outputs. (Some video cards have display port outputs which with active adapters can support 2 monitors each.)
If your computer has two or more outputs and your new monitor has an input compatible with the extra output, get the appropriate DVI, DVI-HDMI or HDMI cable for your new monitor. See the next section if both monitors have VGA input.
If you have a desktop with only one video output, you may be able add a video card to support two monitors. (Depending on your computer, you may need to upgrade the power supply to support a video card.) Then get the appropriate adapter or cables to add the second monitor. (Note: if both of your monitors have only VGA inputs, check the specs for video cards carefully. Not all modern cards support analog outputs on their DVI, HDMI or Display Port connections. These digital outputs would require a digital to analog converter to give the VGA out.) However, if one of your monitors will accept DVI digital signals and the other VGA, add a card with one of each of these connections and a DVI cable to match. (This is an if needed extra; many monitors still ship with only a VGA cable.)
Then turn off your computer, open it and add the video card. Install the drivers with only one monitor attached. Then power down the computer and connect the second monitor. Turn on both monitors before turning on the computer again. Most of the time, the second monitor should be recognized (by Windows) and the appropriate refresh rate and resolution chosen. If not, you may need to enter the Display settings to set the monitor up.
I have seen some computers/video cards where only one output is initially enabled. You may have to go into the device settings to enable it. (Laptops often need their external video ports enabled in the BIOS.) Bad video ports/cards/cables do happen so RMA if needed.
The USB video adapter, http://www.newegg.com/Product/Product.aspx?Item=N82E16812225007 , can be added to a desktop to give a second VGA output but it isn't the best solution. USB bandwidth limits are significantly lower than those for a PCIe x16 slot or an old AGP slot.
I hope this helps. Please add more information about your system if you want more assistance with this problem.
(who has done dual monitors with older and newer computers. My old Pentium 4 with a Radeon x1350 video card was fine for driving a VGA monitor and an HDMI monitor (using a DVI to HDMI cable). My second generation i5 and P8Z68 motherboard system is also fine using the on-CPU video graphics for those same monitors. A video card would improve gaming but isn't required.)
Dec 13, 2012 | Computers & Internet
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
Hi,how do I know wheather I need DVI or VGA cables to connect CPU to a Monitor.I sold monitor when I got laptop now I want set up the Dell Dimension 3100 as aback up,so I'm looking at wide sreen monitors...
Most of the Widescreen monitors come with DVI as well as VGA connector. A VGA connector and DVI connectors are different in many aspects. First of all the DVI connector would be white in color and VGA would be blue.
VGA connector has 15 pins and DVI has 24 +1 pin
Sep 02, 2009 | Dell Dimension 3100 PC Desktop
Cannot get second monitor output to work on ATI Radeon X1200
A DVI-D signal is digital (whereas DVi-I is digital AND analogue) and can never be converted into a VGA signal without using expensive hardware boxes that convert the signal. These though tend to lose quite a bit of the signal quality. If I were you I'd look for a monitor with a digital connection, because I'm afraid this isn't going to work.
I'm sorry your problem can't be fixed...
Yannick.
@DickcanFixit: Catalyst 9.4 is the most recent.
May 30, 2009 | ATI RADEON Graphic Card
Monitor not working with converter
You have to make sure the DVI output of your computer supports analog video.
Check online for a DVI pinout. You will see the group of 4 or so pins to one side of the connector provide analog VGA. If your Video card (or cable) doesn't utilize those pins, then your monitor isn't going to be supplied the signal it needs.
Regards,
-Ben
Nov 18, 2008 | Computers & Internet
No connection to monitor
i would try the card in another mainboard, if available and watch the refresh rates. hope this is useful. and try other cards.
Nov 04, 2008 | Evga 512-P3-N862-AR GeForce 9600 GT GDDR3...
No signal
Weegee, Unfortunately you are trying to mix two different video types: VGA is an analog video interface found on most computers (except for latest with flat panel monitors, which are usually DVI). Your TV DVI interface is digital (although there is a DVI-A, which is an anlog DVI interface, it is unlikely that your TV has this). So, what you are trying to do probably won't work. I assume your computer does not have DVI output (otherwise you wouldn't have bought the adapter), but some monitors have VGA inputs; does yours? What kind of DVI adapter did you get? Is a DVI-A? Check out http://en.wikipedia.org/wiki/Dvi for info on DVI interfaces.
May 12, 2007 | iLO 3200 32 in. LCD Television
Acer ET.CV3WP.E05 LCD Monitor - V193WEJb 19" 5 ms Adjustable Display Angle 1440 x 900 16.7 Million Colors 250 Nit 50000:1 VGA Black Logo
114 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
