Question about Ski-Doo 2011 Expedition SE 1200 4-TEC
My 2010 1200 4 tech is running fine, but since the weather became warmer, it's not running too well, the throttle quits and shake, i lose all the power, runs like it's out of timing, and if i keep going, it just won' t go anymore, unless i let it cool down for a nite or so, coolant is full, fan is working, gas is full so is all the liquids, what do you think
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 220 Answers
If this is carborated i would ck the choke adjustment. If not try changing the ext.coil.
Posted on Oct 02, 2014
Dell E4310 usb port not working
The two most common problems with USB ports not working is they became lose and are not making a connection or missing drivers.
That being said USB have been nattily supported at POST for quite some time now some. You will probably want to get a computer tech. to look at it
Jul 23, 2014 | Dell Latitude E4310 Laptop
Car stalls while driving. Will start after about five minutes. Is not flooded. Doesn't usually do this until after it has been driven a bit. Does it more in warm weather. Check engine light sometimes...
I'd have fuel pressure tested. I had a 95' did same thing. Cold winter day, worked fine, as soon as it got warmer, or hot out, it would quit, and re-start 20 minutes later and go for a distance then die again. If I parked in the shade on a hot day, I'd get further before it quit for the first time. I started carrying a fuel pressure gauge with me. Cool in the morning my fuel pressure was up to spec @ 49-50psi. Once it got warm/hot out and it died, Hooked up gauge and it was at 2-5psi. Let it sit and cool off 20-30 minutes, pressure would jump back up and run good until fuel pump got hot again and then pressure dropped off and car quit. It sure sounds like the fuel pump, but the hard part will be getting the car to the shop at the right time, or they will need to let it run on the lot until it quits to confirm the pressure drop. One thing you can try is when car quits, have a can of WD-40 or quick start with you and a screwdriver. Loosen the clamp on the air intake hose where it connects to the front of the throttle body and pull it off. With vehicle off, turn throttle linkage so the plate opens up enough to spray WD-40 a second or 2 in the throttle body. Then try to start it. If it starts and runs momentarily, then you can be pretty sure it's fuel related and my guess is the pump needs replacement.
Apr 12, 2011 | 1996 Plymouth Neon
03 Neon SXT trouble restarting after being shut off
usually when this happens its either the: spark plugs/ignition coils; melted catalytic converter, or a blown engine. however it could be other things such as a bad engine temperature sensor
Jun 24, 2009 | 2003 Dodge Neon
1997 jimmy 4.3 liter hard start. Have to prime throttle body when
could be your battery is getting old they tend to lose performance in colder weather.
Jun 24, 2009 | 1998 GMC Jimmy
No spark when hot 84 goldwing
hay there i wood have a look at the ignion coil frist then check the pic up coils these have that afect wen faulty . next id be look ing at the igniter box but these are a bit hard to test
May 31, 2009 | 1985 Honda GL 1200 Interstate Gold Wing
1999 Grand Prix GTP. Catalytic convertor fine.
Make sure it always gets premium fuel...even with premium and especially in warmer weather the GTP will frequently perform the factory programmed KR (knock ******.) In WOT it is also more susceptible to running a lean condition with stock programming.
Things you can do to troubleshoot the problem and give more consistant performance with the GTP is run colder range copper core plugs and/or any brand of cold air intake, or even a stand alone 9" open element cone filter. Both are better than stock and provide more airflow even though the stock airbox was redesigned in '99. What else you can do is not limited to that but a start. Good luck.
Mar 08, 2009 | 2000 Pontiac Grand Prix
2001 Dodge Caravan SE 2.4L.. In cold Weather it starts then stalls and dies...?
cable is fine,can be the tps but try tapping on the idle air valve and see if the idle kicks up,it works like a choke and if its stuck its a big vac leak
Nov 05, 2008 | 1990 Dodge Caravan
Westinghouse fridge
cooler means coooler cabinet temperature...
Feb 12, 2008 | Refrigerators
Ski-Doo 2011 Expedition SE 1200 4-TEC Logo
340 people viewed this question
Top Ski-Doo Winter Sports Experts
Todd Arndt
Todd Arndt
ptpumpman
David Harrelson
David Harrelson
Are you a Ski-Doo Winter Sport Expert? Answer questions, earn points and help others
