Question about Evenflo Generations
Evenflo Car/booster seat #25803681
Trying to figure out how to use car seat belts with seat. The shoulder strap instruction on side of car seat back does not seem safe.
sgregg
  • 133 Answers
SOURCE: Shoulder restraint adjustment
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
Posted on Jul 31, 2007
SOURCE: re-assembly instructions for evenflo triump car seat
been so long since I posted this, that I thought it was an imposter!
can't even remember my problem......
Posted on Aug 15, 2008
SOURCE: need manual for car seat/ booster
googled for free
Posted on Jun 18, 2009
SOURCE: evenflo discovery 5 infant car seat straps
Okay okay--do not do anything with the big pieces behind the babies back but the gold clips at the **** area..pop those out and shove that piece and the clip and the chest clip through the back of the strap hole--then reput the strap through the slot you wish then the gold pieces back through the bottom and of course pop the gold pieces back--again do not use the upper clips behind the back to do this :0)
Posted on Dec 21, 2009
SOURCE: Evenflo Embrace Backwards Buckle.
There's no way to fix it and Evenflo will not refund it if you're outside of warranty. We had the same problem. I think they need to be held accountable for a faulty product and stand behind it.
Posted on Apr 09, 2010
Hi, how do i attach the belt clip that comes with the evenflo booster seat?
If it is the one that is on the end of a strap, at the end of the strap is a loop.
Feed the loop thru a small set of holes in the back of the seat. The seat should have 2 small, close to eachother, holes. It goes in one, out the other and then slide the clip thru the loop and pull it back tight.
The only other design I know of uses a screw to attach the belt, the clip is on, to to a nub with a hole in
it on the back of the car seat.
If by "clip" you mean the little bracket that looks like an "H" you thread the car's seat belt thru it, where the belt goes up to the highest point, and use the H clip to keep that part of the car's seat belt away from the child and car seat by weaving it behind the edge of the car seat.
Use Evenflo's site to download a free manual and it shows you how to do it. All you need is Model number and date of manufacture and it will give you your manual. Save it to your computer. Click this link.
Evenflo Care Seat Manual Downloads
Mar 17, 2011 | Evenflo Baby Gear
How do I remove the head rest to convert this car seat to a booster? The back plate and the head rest are connected and held on by a metal bar on the back of the car seat.
This car seat does not convert to a booster. It becomes a "Belt-positioning booster". The back and headrest remain while using as a booster. You remove the 5-point harness and use the car's shoulder strap seat belt.
The belt positioning is done by the plastic parts at the top on either side of the seat.
Following is the link to get the instructions for this seat: http://www.coscojuvenile.com/usa/eng/Instructions
Oct 16, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
How do you remove the cover and belts on an evenflo car seat with this number on the side 25801158?
Turn the booster seat around to the back and locate the metal splitter plate that the harness is attached to. Remove both harness straps from the splitter plate. Locate the TensionRight knob located on each side of the seat in the front by the baby’s foot area. Turn the TensionRight knob to the back as far as it will go to take up the slack on the splitter plate strap. Pull both harness straps through the seat back to the front of the seat. Remove the harness strap from both sides of the chest clip and from the buckle tongues. NOTE: Please leave the buckle tongues locked into the **** strap for storage. Remove the harness strap from the seat. NOTE: Reattach the chest clip to the harness strap so they don’t get lost. Turn the booster seat upside down and locate the metal harness anchor. Turn the metal anchor sideways and push it through the slot to the front of the seat.
Sep 08, 2010 | Evenflo Generations
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
Evenflo car seat
1. Remove the cover on the back upright (8 phillips screws).
2. Remove the white plastic clips that retain the brass clip holding the shoulder straps in place.
3. Pull the brass clips away slightly, then, turn them and push through the slot where the shoulder straps go through to the front of the car seat.
4. Pull the straps through the lower seat cushion slots.
5. Wash and reverse steps above to put back together.
Jul 27, 2008 | Evenflo Generations
Booster
Remove straps and belt across the lap!
Nov 04, 2007 | Eddie Bauer Deluxe High Back Booster...
Jul 31, 2007 | Evenflo Embrace - Rainforest
Shoulder straps
You can contact EvenFlo directly, they will be happy to help you out: http://www.evenflo.com/ Evenflo ParentLink Department: 1-800-233-5921
Mar 31, 2007 | Evenflo Aura Traditions Travel System...
Evenflo Generations Logo
88 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
