Question about Magimix 11535 Toaster
Magimix toaster Opened door to clean. Now toaster doesn't work at all
2 Suggested Answers
justinbur167
  • 257 Answers
SOURCE: Magimix 4 Slice Toaster Can not
Hello Pedelyfour,
I understand that you are having a problem with your Magimix 4 slice toaster, the retracting handle is not keeping the unit down. I am sorry that the only parts that are available to purchase without going thru warranty are the heating elements.
However, have you had this unit for more than three years if not it is still under warranty from the manufacturer. You will need to contact Goldseal Service at this number 01483 427411. They will be able to take care of the warranty and tell you where to send the unit too.
I would like to thank you for choosing FixYa.com
Justin
Posted on Mar 30, 2011
Cleaning magimix handle
Magimix Food Processor and Bad Customer Service
fussfreeflavours.com/the-tale-of-the-magimix-and-bad-customer-service/
Jan 12, 2012 - Magimix food processor review - the exorbitant cost of replacement ...time to find out how to clean the internal part of my Magimix 5200 handle.
magimix compact clean handle Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your magimix compact clean handle question. Get free help, tips & support from top experts on magimix compact clean handle related issues.
Food processor - Magimix
www.magimix.uk.com/page/faq/Food-processor/CS-5200-XL/
Magimix UK : FAQ Frenquently asked questions - Food processor. ... direction until the locking tab engages the top of the bowl handle. ... Never exceed the quantities recommended for your food processor model in the instructions for use.
Amazon.co.uk: Customer Discussions: Food processor bowl to
Jan 01, 2016 | Magimix Food Processors
How do I remove he base of a Magimix Vision Toaster?
Hi
There are a couple of reasons that this would be causing a problem
ring 01252 727755 BBS Ltd are the authorised repair and parts people in the uk see www.magimix-spares.co.uk, they can do a collection repair and delivery for £25
Dec 19, 2014 | Magimix 11526 Brushed Vision 2-Slice...
Have you clean a toaster.
Turn it upside down
There should be a trap door on the bottom
Open it and hit the toaster with your hand and loosen the crumbs up until it\'s clear
If it doesn\'t have the trap door
Rap it up in a towel and take it out side
Hold it upside down and hit it with something solid
Resist belting the out of it with a hammer or your toaster will require to be binned after it
If nothing like this works I would consider purchasing one that has the trap door on the bottom
Good luck happy bashing
Jan 04, 2014 | Kitchen Appliances - Others
My toaster doesn't give enough heat to use it
follow this test with multimeter, and fix it. God bless you
the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the power cord.. If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse.
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostat .
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements
Nov 08, 2013 | Hatco Conveyor / Toaster
Heat is low
please make this test with the multimeter.God bless you
the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the power cord If the oven doesn't work on its toaster and oven functions, test the main switch As needed, check the fuse .
If the toaster oven stays on when the door is opened, check the main switch (). If the oven doesn't heat, test the heating elements.
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
How do I remove knob from Magimix 2-Slice Vision Toaster with out damaging it?
Do not try to just pull it off, you will likely damage difficult to repair parts.
On the underside remove 6 pozidrive screws 3 each end (one under the crumb tray)
Standing on its base - open the doors and remove 4x countersunk torx T10 screws, near the top, that screw from the inside into the end covers.
Now remove the opposite end to the knob, (in order to learn how it is held). Pull the bottom away from the base to the left, around 5 mm, and slide the whole end cover upwards, it unclips at the top. The other end is not so easy of course because of the knob. Release the cover, as before. It is possible - with the knob at the top, pull the bottom of the cover out 5mm and push hard to slide it upwards as before. The cover will release from its top mount. Then slide the cover all the way up, as far as the knob slot will allow. This will allow you see and have access to the back of the knob and the plastic clip that holds it in place. Stand the toaster on its base, with the end cover lifted up it is easy to put your hand inside the cover from the top and putting your thumb and forefinger around the bar you can grip the plastic hook and ease it downwards whilst you use your other hand to pull the knob and its firmly attached bar away. It will be necessary to wiggle the knob up and down whilst pulling it outwards. The bar surface is not flat, it has ridges that hold it in place quite well, even without the clip, hence the need to work it up and down. That's all there is to it! Hopefully you haven't broken the clip off, but if you have, don't worry you will still be able to use the toaster with little impact. The attached photo shows a close up of the knob and bar just separated from the mechanism. This should give an idea of what you are up against.
What a fantastically well made machine this is, a real pleasure to work on.
Oct 07, 2013 | Magimix 11535 Toaster
Magimix toaster repair service in Cheshire
What is the problem with your toaster.
Mar 04, 2013 | Magimix 11535 Toaster
I have an Oster toaster oven 6260. Looks very clean. My son got it at a garage sale. Day 1 worked fine. Day 2 plugged in doesn't go on no matter what knobs are turned. Tried different outlets. ...
It is possible that the controller switch or the trigger is absent so that the coils do not get the power from the mains circuit. it will be best if you can remove the mains plug and start tracing with a multimeter in continuity range( ohms) so that the connection is confirmed.
Once it is found that the switch does not switch on the power or has lost the connection even when it is put to the ON position then you can salvage the swittch from the older toaster to be fixed on.
If the coils have opened it can also be checked with the meter , specially since you have one top element working.
So using the inventory of the two toasters you can get one working.
Jun 17, 2011 | Toaster Ovens
Magimix 11535 Toaster Logo
44 people viewed this question
Top Magimix Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Magimix Kitchen Appliances - Other Expert? Answer questions, earn points and help others
