Question about Garden
Ride on mower makes buzzing sound in engine but wont start
  • 742 Answers
Sounds like your starter solenoid is buzzing. This means either the battery connections need to be cleaned, or the battery needs charged and possibly replaced. Check the connections at the starter and the solenoid. The solenoid is usually mounted to the back of the dash plate. If you have access to a load tester check the battery after charging and see if voltage is at 12.6 volts and that it passes the load test. Hope this helps, plese post solved on fixya.com.So I get credit more info.for a solved problem if it does. If not, check back and give me
Posted on Apr 24, 2014
Testimonial: "It was the starter motor spinning and not engaging with the bigger drive cog, this was due to 3 teeth missing at the point it had stopped"
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
thabrain
  • 76 Answers
SOURCE: murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Posted on Oct 28, 2008
  • 11 Answers
SOURCE: Craftsman mower
charge the battery sometimes they come not fully charged if not push down clutch/parking brake sit on seat becouse of dead man switch and then crank it over
Posted on Sep 26, 2008
  • 10 Answers
SOURCE: my westwood ride on mower, model 2012 wont start.
Could be a few things, First, you say it's getting fuel, but is the fuel fresh? It may have water in it and act like your engine. Did this problem just start happening? Did you happen to ride over something that may have sheared the key on the flywheel? This would throw the timing off on the engine. If you can try to start it while spraying gas into the carb throat and it keeps running, then it could just be a dirty caburetor or a misadjusted carb float. Good luck, Bill
Posted on Dec 21, 2009
SOURCE: Craftsman riding mower clicking noise - wont start
RIDING MOWERE JUST CLICKS AND WON'T START HOWEVER IT WAS RUNNING FIND JUST 5 MIN. BEFORE I TURNED OFF.
Posted on Jun 11, 2010
Starts but wont drive
Sounds like your drive belt came off the pulley. Look at the bottom of the engine. If you see a loose or broken belt, that's the problem.
Aug 29, 2016 | Poulan Garden
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Help! Husqvarna YTH2348 Riding Mower. Wont start, just clicks. Changed battery, solonoid, starter, and 20 amp fuse. What else should I try?
make sure the key is off and see if you can rotate the engine by hand some to make sure the engine is not locked..
It's the only thing left to try,
Jun 02, 2015 | Husqvarna Garden
check all wire connections to the battery and the starter and check the battery for being a good charge. the buzz sound is from not enough voltage or current getting to the starter.
Apr 22, 2014 | Briggs & Stratton Garden
Turn key starter wont turn over engine
Sounds like the battery is too dead to start it, try charging the battery to see if it improves. Check the battery connections to make sure they are clean and tight. Hope this helps
Apr 20, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
24 hp Briggs Stratton sears riding mower engine wont start unless you use start fluid cleaned filter have flow to engine
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Feb 12, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
Rover ride on mower makes clicking and or buzzing sound when u turn key but wont turn over
Either the battery is flat or the solenoid has failed. You can test the solenoid (which you can find by following the positive battery lead) by using an insulated screwdriver to short across the solenoid terminals (directly connecting the battery to the starter motor. Be careful though, as the engine may start, so make sure blades and transmission are in neutral!
Sep 15, 2009 | Briggs & Stratton Garden
Mtd riding lawnmower won't run
my mtd lawn mower wont start . when I turn the key there is a buzzing soung where the battery conectors are near the shifter but the starter is hot and getting juice
Sep 28, 2008 | Garden
Craftsman mower
Aug 27, 2008 | Craftsman Garden
Garden Logo
483 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
