Question about Locks & Locksmithing
How to change belt on ilco 008b mini-mite key machine
    Scholar:
  • 101 Answers
To remove or install a belt on the Ilco 008, the shaft must be slid out of at least one bearing. If there is a guard cover over the pulley, remove it. Loosen the setscrew(s) on the cutter shaft pulley, and slide the shaft to the left. Mine is an older model, with no guard and the belt can be changed without removing the shaft completely.
After putting a new belt around the pulley, slide the shaft back into the right-hand bearing.
Be sure the pulley set screws are aligned with the flats on the shaft and that there is minimal end play and the cutter turns freely. Tighten the set screws and stretch the belt over the motor pulley.
Posted on Apr 22, 2014
How to make a house keeping authrization key
I don't know whether this can be done. I recommend that you contact Kaba Ilco directly for assistance:
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Oct 11, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
What's your problem?I HAVE A LOCK THAT KEY WILL NOT LOCK ITS ALWAYS OPEN
I urge you to contact Kaba Ilco technical service and talk to a technician.
Here is the contact information:
Oct 08, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Code dont work,key rod dont seem to work,cant change code.
Yours is an unusual problem. Therefore, I suggest that you call Kaba Ilco during regular business hours for assistance. Toll free: 800-849-8324 Be sure to have the model number and any other pertinent info on your lock ready if you call.
On the net:
1-800-849-8324 (option 3, and then option 6)
Good luck--and please provide feedback if this helps!
Aug 11, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Code was forgotten and need to reset somehow. is there any way to do it by myself?
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Go to the right-most column on the manual grid page, labelled "TIPS", and there you will find the files with the programming instructions.
As you will see, there is a reference in those instructions for the need for a DF-59 key. A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
Also, there is a need for a spanner wrench. The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Kaba-Ilco Customer service can be contacted from this link:
Jun 20, 2011 | Simplex Kaba Ilco Unican 1011 keyless...
Lost combination on the unican 1000! How do i get it back or set a new number in it?
I will give you several sources of information for you to pursue.
First is a link to a chart where you can download PDF files for your lock ( the L1000):
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=l1000
There is a link on that page where you can download and install Adobe Reader in order to open and view PDF files, if you don'ta already have it installed on your computer.
Aditionally, here is a link to a website wherein it is described how to change the combination on the unican lock:
http://www.lilocksmith.com/keyless_Locks/unican1000.htm
May 17, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
How to extend or reprogram kaba machine expired date for authorised master key?
I can't help you directly, but I will steer you to further information.
May 11, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
HOW DO I CHANGE THE COMBINATION
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
Sep 29, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Reset combation without a combation kaba
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
Sep 29, 2010 | Simplex Kaba Ilco Unican 1011 keyless...
What key blank fits a brinks 5575 safe
My program shows 3 possible key blanks if it is a tubular key that fits this safe then the blank # would be Ilco 1137B, If your key has cuts on both sides of the blade then it would take an Ilco 1626, If it has cuts on only one side of the blank then it would take an Ilco 1531 I hope that helps if you have any more questions you can contact me thru my website at www.jambrilocksmith.org Bob
Mar 25, 2009 | Computers & Internet
Locks & Locksmithing Logo
973 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
