Question about Mitsubishi WD Televison & Video
Channel does not exist
After changing lamp get channel does not exist error.
3 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Green Horizontal Lines on the Screen.
2003-2004 Model Year Grand WEGA Televisions:
Models: KF-42WE610, KF-50WE610, KF-60WE610, KDF-70XBR950, KDF-60XBR950, KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620.
As technology evolves, Sony continually looks to stand behind the reliability of its televisions. It has come to our attention that a very limited number of televisions manufactured between 2003-2005, after a period of time exhibit a stationary scribble / random line pattern on the screen. Click here to see photos of this symptom.
As part of our commitment to quality, Sony is announcing that for any owner of this model television who paid out-of pocket expenses on or before May 26, 2006 for an estimate or repair service to replace the optical block for this specific issue, Sony will reimburse the customer by mail for his/her parts and labor expenses. To receive reimbursement, please follow completely the directions and terms on the claim form for reimbursement; all claims must be postmarked by May 31, 2007.
In addition, for any customer who later experiences this issue on one of the affected models, Sony will cover the cost of the optical block repair at no charge through September 30, 2007. All other terms of the Sony limited warranty continue to apply.
Posted on Jan 23, 2008
SOURCE: no picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
Posted on Oct 07, 2009
Sharp aquos LC70LE650U 5 short flashes 2 long, no display
Try unplugging the unit and hold the volume up and channel down buttons down and plug the unit in. Let go of the buttons and the unit should come on up the service mode. There will be a small k on the screen. With the remote press the channel up button . This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. Use channel down to highlight that line and the curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged .
Nov 20, 2014 | Sharp AQUOS LC-70LE650U 70" 1080p LED-LCD...
I have a Symphonic model ST420FF along with a Phillips Universal remote. The tv used to work oerfectly but then the channel changed (we have a charter cable box hooked up). Now when I try to change the...
Can you use the menu buttons on the TV to navigate to the control panel to automatically or manually add channels? That would be a start to make channel 3 exist again.
Sep 20, 2014 | Televison & Video
Does the wd62628 have a factory reset button?
should be in the manual. Or you can look on line for Mitsubishi model wd62627 owners manual download.
Sep 09, 2014 | Mitsubishi 915p026010 Wd-62627/Wd-62628...
Mitsubishi TV having issues with HD channels
Unplug for a few then try it again you need to search channels again
Jan 27, 2010 | Mitsubishi WD-52525 52" Rear Projection...
How do i reset the lamp life for sony KDF-E42A10 ?
1) In standby mode, press the buttons on the Remote Commander sequentially, in rapid succession:
[Display] , Channel [5] , Sound Volume [+] , Power [ON]
2)To enter BE-micro service mode menu, press JUMP 2 times.
3) To display the lamp time, press Channel[4]
The screen displays:
“ Total lamp time is 14 hours”
4) To display the lamp time clear, press Channel[5]
7 times and Channel[1].
To reset the lamp time press Channel[3] > [MUTE] > [ENTER].
WRITE (Character color is red) is momentarily displayed and the lamp time is reset to “0”.
This worsk for other Somy retroprojection TVs as well, eg. KDF-E50A10 , KDF-E50A11 etc.
If you goto eserviceinfo.com you'll get the whole service manual
HTH!
zioanza
Dec 01, 2009 | Sony KDF-E42A10 42 in. LCD Television
Wbr 2310
By default the channel is set to 6. The Channel can be changed to fit the channel setting for an existing wireless network or to customize the wireless network. The Auto Channel Scan setting can be selected to allow the WBR-2310 to choose the channel with the least amount of interference.
Oct 06, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Freeview Box :(
This kind of interference can often be caused by remote pick up from energy saving lamps.
Mar 17, 2008 | Televison & Video
Sharp LC-32D43U
This unit probably has a bad power supply. It may also be shutting down because if this unit has recorded 5 lamp errors it goes into shut down. To eliminate lamp errors you can force the unit on in the service mode and look for lamp errors. To do this, you unplug the unit, and while depressing the volume up and channel down buttons at the same time, plug the unit in. Hold for 1 second and release. The unit will then power on and a small k should appear on the screen. If this does not happen then there is definately an internal failure that will require a sharp auth. service center. If the unit does come on with the k, use the remote and press the channel up button. This will produce a menu on the screen and you will note on line will indicate lamp errors. On the right side of that line will show the # of lamp errors. If it reads 0, lamp errors are not the issue, however if it reads 5, you can highlight that line by using the channel down button. Then use the curser right arrow to select the error and then again to reset them. Once the lamp errors have been reset to 0, unplug the unit and wait at least 25 seconds before plugging in. The unit will now power up normally and this may cure the problem for good. If this process corrects the problem and it occurs some time later or right away that will be an indication that either the unit has bad backlights or inverter has failed and will again require service.
Feb 07, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
