Question about HP LaserJet 9050 Printer
Loud noise from tray 4 on hp lj 9050
I keep hearing a whirring noise coming from tray 4 when printing.
  • 199 Answers
SOURCE: HP LJ 1200 chirps or squeeks
replace toner cart
Posted on Feb 27, 2009
  • 102 Answers
SOURCE: HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Posted on Jul 03, 2009
  • 37 Answers
SOURCE: Hp LJ 9050 is printer
The printer probably has one of two problems; either your toner cartridge needs to be cleaned according to the printer's cleaning program, or it is nearly out of toner. A third issue may be that the cartridge needs to have its alignment adjusted. If so, you will see fuzzy, out of focus lines. If you will try to print a piece of graph paper, (available on most spreadsheet programs,) you will be able to tell if there are a.) fuzzy lines or crooked lines, meaning your printer needs to be aligned; b.) incomplete lines or faint lines, meaning your cartridge is nearly out of toner, or; c.) smudged or incorrectly colored lines; meaning your cartridge needs to go through a cleaning cycle.
Posted on Mar 31, 2011
BaronVonNuke
  • 1915 Answers
SOURCE: HP 9050 MFP keeps asking
You need to check the paper types you have assigned and the paper types that users are requesting. Print out a configuration page and make sure that Tray 4 shows as plain paper. If it does not then check all the stops. The 2000 sheet tray 4 units are noted for having the stops not engage and this causes the printer to think that tray 4 is custom media. You can also go into diagnostics and print a paper path test for each tray to ensure that all the trays are working.
Posted on Apr 21, 2011
SOURCE: Major problems when trying to print, Jamming alot & grinding noise
Maintenance Kit will not solve the grinding noise. You have what is called a Swing Plate Issue. The plate is located easily on the left side of the machine after you remove the fuser. Those gears become warn and make that sound. Sometimes you can get by removing just the gear that you can see (black plastic gear) and replacing it with a new one.
Posted on Oct 23, 2011
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
Change default paper tray HP LaserJet 9050
When you click Print then right click on your HP ptinter - click Properties - Paper Quality tab - click Paper source and select Tray 2 - Click OK - then OK to print.
You can change the paper type in Tray 2 into Tray 1 and vice versa to save going into Properties to change the Tray selection.
May 31, 2012 | HP LaserJet 9050 Printer
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
HP 9050 MFP keeps asking for tray 1. Configuration is set to use tray 4 first, but everytime a print job is sent to the printer, it requests load paper in tray 1. How do I get this problem fixed?
Apr 21, 2011 | HP LaserJet M9050 MFP Printer
HP optional 2000 sheet tray 4 problem.
Uninstall and then reinstall the drivers for this printer and then upgrade the firmware.....it will work....goodluck!
Jul 29, 2010 | HP LaserJet 9050 Printer
Not fusing
Make sure the two blue levers are in the down position on the fuser. If the problem persist try another fuser .
Apr 03, 2009 | HP LaserJet 9050 Printer
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
Hp lj 1200
How much Price HP lj 1200 at Sisney- Astralia?
Aug 16, 2008 | HP LaserJet 1200 Printer
HP 2430tn lj printer with 13.20 jam inside top cover error
What is the exact error message shown on the display ?
Does it makes any strange noise when you start it up ?
Dec 31, 2007 | HP LaserJet 2420 Printer
HP LaserJet 9050 Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
