Question about Whirlpool ER6AHKXPQ Top Freezer Refrigerator
Estate Fridge, replaced bi-metal..now what?
Ok let me give alittle recent history about this fridge, about a month ago it would constantly run and would never stop and within a week it would need to be defrosted because the freezer part would be completely iced over. I discovered the defrost thermostat (bi metal) was faulty and bubbled and replaced it. Almost immediately after replacing it I noticed that the fridge would constantly leak water from the freezer to the fridge part below...It would be cool in the fridge and the freezer would indeed stay cold, but it would continue to leak. In fact I turned the theromstat down to a hair above being completely shut off, which seemed to have no bearing on the temp whatsoever, it was still very cold. Today, the fridge completely stopped. The lights in the fridge of course work, but nothing else does, no sounds period. I popped off the backing in the freezer and to my surprise there was NO ice, no frost, just pure metal and a TON of water. Im guessing since I replaced the bi-metal defroster that it never did allow a frost, it just continued to heat up and drip in the fridge below. Now, Im not the kind of person who would ask an ignorant question and make someone do all the legwork, I researched what I could and Im GUESSING its one of 2 things, the thermostat or the overload. Both are not very cheap, being that Im a broke mo fo I cant afford to just blindly buy both parts...Im wondering if anyone has any input or any tests I could run to pinpoint the actual problem. If neither the overload or theromstat sound as the problem, ill happiliy be proved incorrect if it means fixing this darn thing.
ps. also the condenser seemed to be warm when it was plugged in. not sure if that means anything. It is unplugged now.
Please help, I would greatly appreciate it!
thank you in advance,
Les
  • 85 Answers
Good u explain your prob beautifully, but i am thinking about how to reply you like u.
ok, 1st thing u say that u turn the thermostate down to a "Hair" level and there is no effect on the cooling it means that during the leakage of water to the friedge, thermostate is effected to that water n goes for sleep (i u have to replace it). and at the other side your overload is OK.
change your thermostate and enjoy....
good luck
shafky
Posted on Jun 20, 2009
I have a Daewoo ERF-334M fridge/freezer and the auto-defrost has stopped working. The evaporator gets covered in ice within about 3 weeks from it being manually defrosted. I've checked the resistance...
More than likely if your fridge has a bi metal, or a defrost timer, its one of those two issues. Leaning more towards the bi metal. If the bi metal is encased in ice and is reading more than 0 ohms its your bi metal. (small round sick that sits on the tubing) Your heater should be reading around 25 ohms or something like that. it should be fine. If it does not have a bi metal it works on a thermistor and then you more than likely have a electrical control board issue that not forcing the fridge into defrost. Lmk if you need more help!
Aug 04, 2013 | Refrigerators
Freezer not freezing, refrigerator not cold, frost on back wall of freezer, what do ii do?
You have an ice block if the fridge is not cooling and freezer somewhat is. There are a few options you have. First off the bi-metal defrost thermostat has to be replaced. This may be your only problem. The other two things you can check one it your heater. Once you remove the ice to can test the heater for continuity. The other is your defrost timer. Unfortunately you have a computer board that is your timer. You cant test this but you can see if it is working. If the box shuts everything down the fans in freezer and the compressor for 8-30 minutes than kicks everything back on chances are your board is fine. Now to fix your problem.
Option 1 only use if you have a backup fridge to put everything in. Transfer all your food to backup fridge. Unplug fridge for 48-72 hrs with doors cracked open and have towels surrounding the fridge for all the water. Remove back panel in freezer to check for ice block. **Remove back access panel and at the top of coils is your bi-metal. It has two wires going to it. Replace. Now to test the heater you will see the wires to the heater if you have a glass heats there is a pink and blue wire that run down your coils to the heater. Remove the heater and test for continuity. If you have a bar heater you will see two wires running up along the side of coils. You have a bar heater on this icebox. Chances are the heater will still be good. Now once everything is back together than give it a couple hours for temp to get back down before moving your food back.** If you have not heard the box shutdown. Dont put you food back yet give it three days and than check for ice buildup. If I block is forming again replace defrost board if not than it was just your bi-metal.
Option 2: If you dont have a backup fridge. Follow most of steps above once Ice is melted. Get a couple bath towels and a hair dryer. Now remove freezer access panel and with box unplugged start melting all the ice and letting a mojority of the water fall onto the towels. Now once all the ice is melted Take flashlight and look between all the coils. Ice can be hideing and your will have problems again. Now do everything between aristcrats above. Now if you have not hear the box shutdwon your board maybe out. Hopefully its just your bi-metal.
If you have a more question or need further assistance please reply.
Aug 02, 2011 | Maytag MZD2766GES Side by Side...
Coils in freezer are freezing up and ice box is not cooling
Jul 31, 2011 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
Freezer drips water into fridge
There is drain tube that empies into a small pan at the bottom of the fridge. Follow it up to see where it connect and make sure its in place. If your freezer is constantly defrosting itself and wont keep your food frozen you might want to replace the bi-metal. The "bi-metal" is a small coin sized thermostat of sorts. Its easy to replace if you can splice wires together and wrap in black tape.
Remove the back panel inside the freezer and look for a quarter sizes disc with two wires coming from it. Cut the wires leaving enough to splice the new bi-metal into place and wrap each wire with black tape. This will fix 99% of the problems with freezers always in defrost mode and leaking water into a fridge.
Jul 18, 2011 | Whirlpool Refrigerators
I'm really pissed. Ive had my fridge fixed twice and its still doing the same thing. The freezer is not self defrosting and the fridge part is not getting cold. it was fixed profressionly two months...
Either the defrost control is bad or the heater is bad, Only two things that could be happening, ice building up on the evap. coil needs to be removed by defrosts cycles, not happening. Find a better Tech.
Jun 27, 2011 | Refrigerators
Model TFX30PP purchased 9-10 years ago. The refrigerator & freezer are not cold enough. There was frost built up in the back of the freezer. We defrosted it. Plugged it back in - fridge read in the...
What you have is either a bad heater or heater bi-metal thermostat most likely. I say that since the ice box is working correctly until that frost builds up. Have you checked them. Your heater should test good for continuity(not open or bad) but the bi-metal is a different story. It is open at 50 degrees f and it only closes or carrys voltage when it is sitting in a freezer at 25f. What it does is allow power to the heater when the timer or automatic control calls for defrost. The defrost cycle is around 20 to 40 minutes and power is constantly being sent to that heater the whole time. When it gets warm enough for frost to melt 50F then that bi-metal opens up and kills the power to that heater. If that heater was to stay on it would not be purty. For the rest of the defrost cycle the coils simply rest and drip.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 09, 2010 | Refrigerators
Freezer compartment of fridge freezer working ok but fridge section not cooling
ON ALMOST ALL REFRIGERATORS, THE FRESH FOOD SECTION GETS ITS COOLING FROM THE FREEZER BY AIR CIRCULATION. IF THE AIR ISN'T CIRCULATING, FINDING THE CAUSE WILL REMEDY THE PROBLEM. THE MOST FREQUENT FAILURE IS THE DEFROST CYCLE AND IS EASILY DIAGNOSED BY LOOKING IN THE FREEZER SECTION. IF FROST IS PRESENT ON THE BACK WALL, (OR FLOOR OF OLD MAGIC CHEF TOP MOUNT), THEN A DEFROST FAILURE HAS OCCURED. THERE ARE THREE COMPONENTS IN THE DEFROST CIRCUIT. THE CONTROL, THE HEATER, AND THE BI-METAL. FIND THE DEFROST CONTROL AND SET TO DEFROST. IF THE HEATER COMES ON, THE CONTROL IS BAD. IF THE HEATER DOES NOT COME ON, EITHER THE HEATER OR THE BI-METAL IS BAD.
TO FIND THE BI-METAL, FOLLOW ONE SIDE OF THE HEATER WIRE FROM THE HEATER TO A SMALL ROUND DISC WITH TWO WIRES COMING OUT OF IT. THAT IS THE BI-METAL.DETERMINE WHICH IS BAD WITH VOLTAGE OR RESISTANCE MEASUREMENTS.
Mar 27, 2008 | Refrigerators
GE Model PDS22MBRABB bottom mount
These fridges were made by LG they are very problematic, the defrost cysle does not work properly due to board defects and the fridge freezes up, I have replaced my board twice and the fridge has worked properly for 6 months max them the board shorts again, I talked with the LG rep he said scrap the fridge they are ****.
Nov 06, 2007 | GE Energy Star PDS22SIS Stainless Steel...
Whirlpool ER6AHKXPQ Top Freezer Refrigerator Logo
191 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
